dvdauthor-0.6.9 January 16, 2004
- cap maximum # of tmapt entries to 2040
- convert filenames from UTF8 to locale
- strip out END marker from program stream (clean up mplex output)
- allow more than 512 chapters/titles
- fix handling of programs (not chapters)
- make VMGM IFO scanner deal with lowercase filenames
- fix handling of text subtitles that use frame #'s as timecodes
- fix bug in mpeg audio header scanning
- languages must be in lowercase
- better audio gap setting
- fix PAL/NTSC issue
- rename dvddirgen to dvddirdel to better reflect purpose
- better support for nonstandard frame rates
- don't set seamless flag for cells with commands or stilltime
- bounds check #cells/vob, programs/pgc
DVDAuthorGUI *0.5.2 24.02.2004
- Lots of little things corrected and optimized
- Moved iso creation option to under the FILE menu
- Added the experimental AVISynth script generator
- replaced mplex with the latest cvs (as of 2/19/2004)
- Allowed the listbox to resize with the window
- Added GraphicsMagick support in the menu editor. The gui now generates the png subpictures itself (using graphicsmagick), allowing the user to select their own colors in the menu editor (Instead of the icky green ones)
- added progress bar when dvdauthor is compiling the vobs (progress bar doesn't report the status of mplex unfortunantly)
- removed the Visual Basic runtime files to make the archive smaller. If an error occurs when starting dvdauthorgui, download the runtime files here
