AviSynth - Aktuelle Version
  • Avisynth 2.56 released
    Release notes:
    Summary of changelist (with respect to v2.55)
    * Added options to DirectShowSource (seekzero, timeout and pixel_type).
    * Added DevIL support for RGB32 to ImageSource.
    * Added Russian language documentation. Thanks to Fizick and his team. Well done.
    * Added Merge() filter. Includes very fast iSSE pavgb code for weight=0.5.
    * Added MergeARGB(), MergeRGB() filter.
    * Added ShowRed(), ShowGreen(), ShowBlue() filters.
    * Added operator MulDiv(multiplicand, multiplier, divisor).
    * Added AssumeScaledFPS(multiplier, divisor, sync_audio) maps vi.MulDivFPS.
    * Added gamma option (ala ColorYUV) in RGBAdjust.
    * Added Spline16Resize, Spline36Resize, GaussResize and LanczosResize(tap=xx)
    * Added options to ShowFrameNumber: ShowFrameNumber(offset=10, x=360, y=576, font="georgia", size=24, text_color=$ff0000)
    * Added integer offset to ShowSMPTE: ShowSMPTE(offset_f=10)
    * Added options to ShowSMPTE: ShowSMPTE(offset="00:00:00:30", x=360, y=576, font="georgia", size=24, text_color=$ff0000)
    * Added Fractional resampling support in ResampleAudio().
    * Added Limiter(show=show_luma/show_luma_grey/show_chroma/show_chroma_grey) shows out of bound luma/chroma; *_grey makes the rest of the pixels greyscale.
    * Added offsets and analyze option (ala ColorYUV) in RGBAdjust.
    * ConvertTo*(Matrix="Rec709, PC.709, PC.601") conversions supported.
    * ConvertFPS()/ChangeFPS() copies FPS from a 2nd clip.
    * GreyScale() RGB supports Matrix="Rec709, Average"
    * Support for [vfr content in DSS]: DirectShowSource("F:\Guides\Hybrid\vfr_startrek.mkv", fps=119.88, convertfps=true) turns vfr into cfr stream by duplicating frames (patch by Nyaochi).
    * A lot of bugfixes and optimizations.
    * Cache improvements.
  • Update -> Avisynth 2.5.6a
    Release notes:
    This is a minor update to the source to correct a problem
    in avisynth.h The installable file has been rebuilt to make
    sure it match the accompaning source. There are no
    substantive changes.
    http://sourceforge.net/projects/avisynth2/
  • New build! (The off-line documentation is up to date.)
    AviSynth 2.5.7 Alpha1 (March 26th):
    Additions:
    * Added portugese translation (by RoLon), and partly french translation (by JasonFly)
    * Subtitle multi line text, set LSP arg and use \n. (foxyshadis, tateu)
    * xxxFPS("preset") string preset FPS values. (Tritical)
    * Better avisynth_c cdecl/stdcall mismatch detection and protection (Tritical).
    Bugfixes:
    * Fixed ConvertAudio SSE2 to Float alignment test.
    * Fixed (auto)LoadPlugin altname generation. (Tritical)
    * Fixed SaveString memory block overrun.
    * Fixed $Plugin!Functionname!Param$ bug. (Fizick)
    * Fixed registry handle leak on $PluginDir$ lookup. (Dave Brueck)
    * Fixed memory leaks avisynth_c.
    * Fixed returning locked/protected VBF's to LRU. (Tritical)
    * Fixed runtime mixed SEH/C++ exception handling for XPsp2. (Tritical)
    * Fixed CAVIStreamSynth::Read audio buffer overrun. (Avery Lee)
    * Fixed DLL handle leak in LoadPlugin. (Tritical)
    * Fixed Assert("text") no longer parses % args.
    * Fixed number parser returning inaccurate float conversions.
    * Fixed ConvertFPS() blend mode not processing of chroma planes.
    * Fixed resizer resampling pattern attempted use after deletion.
    * Fixed resizer subpixel shifting functionality being a noop.
    * Fixed Info() auto font selection metric.
    * Fixed Conditional error checking of float RHS.
    * Corrected colours in YUV ColorBars, Now match BT.801-1.
    * TCPDeliver updates: Client: Fixed crash if client gets disconnected.
    * TCPDeliver updates: Server: Remember to disconnect clients when shutdown.
    * Fixed Turn*() YUY2 mod 2 height test.
    * Fixed AVISource() corrupted error messages.
    * Fixed AVISource() direct input drop frame handling.
    Optimizations:
    * None.
    Changes:
    * SetMemoryMax() minimum now 4Mb instead of 16. (Tritical)
    * Remove 50 plugin auto load limit. (Tritical)
    * COM QueryInterface calls now return S_OK instead of NULL.
    * Bracketless call of argless function now get a cache. (Tritical)
    * Over-range numbers now raise a compile time exception.
    * xxxFPS(float) now uses continued fraction to generate a minimal rational pair. (Raymod2)
    * ChangeFPS(linear) now raises a compile time exception if the change ratio is > 10.
    * ConvertFPS() blend mode works for all pixel formats. (Tritical)
    * Info() retrofit of 2.60 updates.
    * TCPDeliver.dll upx'ed.
    * RGB ColorBars +Q and -I bars, Hue is now correct, Luma is NOT zero to achive this.
    * AVISource Audio no longer limited to 2 channels.
    * SaveString memory blocks are now 32 bit aligned.
    * Default planar chroma planes mod 16 aligned. See SetPlanarLegacyAlignment().
    As usual download from Sourceforge.
  • Alle Filter für den 2.5er Zweig laufen auch mit 2.57.
    Bei 2.6 könnte es einige Änderungen geben, die eine Neukompilierung nötig machen, 3 ist ganz anders.
  • Here is release candidate 1 for Avisynth 2.5.7. The intention was for this to be a bug fix release only, but a few minor gems have been slipped in. [Blockierte Grafik: http://forum.doom9.org/images/smilies/smile.gif]
    Notes:- I forgot to turn of the COM environment debugging option when I made this build. The final release version will not have this feature. (It can cause problems with miserable software that employs anti-debugging technology. GRR!)
    2.57 Changes from 2.56
    Additions
    • Installer option for avisynth.lib, avisynth.exp and avisynth.map files.
    • DirectShowSource() now sets _HIRESOUTPUT property of WMAudio Decoder DMO. Allows 24 bit samples and 6 channel decoding.
    • Avisynth COM object now supports IAVIStreaming interface. Many apps blindly expect it and fail to load AVS scripts.
    • Conditional Reader now also accepts T, F, Yes and No for bool data.
    • DirectShowSource() log debug messages to file.
    • DirectShowSource() force set framecount.
    • DirectShowSource() accept audio streams of type WAVE_FORMAT_IEEE_FLOAT.
    • Added KillVideo() verb.
    • TimeStretch now exposes the tuning parameter of the SoundTouch library.
    • Adding global OPT_AllowFloatAudio=True to your script enables WAVE_FORMAT_IEEE_FLOAT audio output.
    • Explicitly request all the channels available in the audio stream [acm AC3]
    • Explicitly try to request float, 32 bit then 24 bit samples from the audio codec.
    • Accept raw audio streams of type WAVE_FORMAT_IEEE_FLOAT.
    • Added installer option to add "Avisynth Script" item to Explorer shell for new .avs file creation.
    • Added avs_delete_script_environment and avs_subframe_planar to avisynth_c interface.
    • Hack to allow Fraunhoffer MP3 codec to work when wBitPerSample==16. (Squid_80)
    • Added portugese translation (by RoLon), and partly french translation (by JasonFly)
    • Subtitle multi line text, set LSP arg and use \n. (foxyshadis, tateu)
    • xxxFPS("preset") string preset FPS values. (Tritical)
    • Better avisynth_c cdecl/stdcall mismatch detection and protection (Tritical).
    Bugfixes
    • Fixed ConvertFPS() blend mode mix_ratio was wrong.
    • Fixed AviSource() handling of dud AVI files that start with drop frames, just return the first key frame.
    • Fixed DirectShowSource() handling of pin renegotiation.
    • Fixed Overlay() "PC_Range" argument handling.
    • Fixed SubTitle() crash when resources exhausted.
    • Fixed Resizers cropping argument validation.
    • Fixed % operator bad argument text message.
    • Fixed stuffing Audio buffer with video graphics on Exception. Now returns E_FAIL. Video stream subsequently will return error text in graphic form.
    • Fixed KillAudio() not resetting nchannels and sample type to 0.
    • Fixed Conditional Reader sscanf buffer overrun.
    • Fixed Version() and VersionString() timestamp discrepancies.
    • Fixed Serious inaccuracies in TimeStretch. It is still not sample exact!
    • Fixed Negative int arg handling for ApplyRange() and Animate().
    • Fixed Installer handling of readonly/inuse target files.
    • Fixed ConvertAudio SSE2 to Float alignment test.
    • Fixed (auto)LoadPlugin altname generation. (Tritical)
    • Fixed SaveString memory block overrun.
    • Fixed $Plugin!Functionname!Param$ bug. (Fizick)
    • Fixed registry handle leak on $PluginDir$ lookup. (Dave Brueck)
    • Fixed memory leaks avisynth_c.
    • Fixed returning locked/protected VBF's to LRU. (Tritical)
    • Fixed runtime mixed SEH/C++ exception handling for XPsp2. (Tritical)
    • Fixed CAVIStreamSynth::Read audio buffer overrun. (Avery Lee)
    • Fixed DLL handle leak in LoadPlugin. (Tritical)
    • Fixed Assert("text") no longer parses % args.
    • Fixed number parser returning inaccurate float conversions.
    • Fixed ConvertFPS() blend mode not processing of chroma planes.
    • Fixed resizer resampling pattern attempted use after deletion.
    • Fixed resizer subpixel shifting functionality being a noop.
    • Fixed Info() auto font selection metric.
    • Fixed Conditional error checking of float RHS.
    • Corrected colours in YUV ColorBars, Now match BT.801-1.
    • TCPDeliver updates: Client: Fixed crash if client gets disconnected.
    • TCPDeliver updates: Server: Remember to disconnect clients when shutdown.
    • Fixed Turn*() YUY2 mod 2 height test.
    • Fixed AVISource() corrupted error messages.
    • Fixed AVISource() direct input drop frame handling.
    Optimizations
    • SubTitle() releases all resources when the last frame of the clip is rendered.
    • SubTitle() releases GDI resources after text map is created.
    • ApplyRange() only builds 2 chains instead of 3.
    Changes
    • Map file is now generated for release builds.
    • ConvertTo*() and GreyScale() now accept "Rec601" as a valid matrix name.
    • DirectShowSource.dll upx'ed.
    • Upgrade internal copy of SoundTouch library to 1.3.1.
    • SoundTouch now available in RelSym build.
    • Animate Integer arg enumeration no longer rounds toward positive infinity. Both positive and negative enumerations are identical. i.e. For Animate(0, 10, "Foo", 0, 0, 10, -10), Foo's arg1 = -arg2 for all frames.
    • Selecting associate open with Notepad with .avs files in the installer now also includes .avsi files.
    • The Installer now pushes a recovery dialog box when unwritable files are encountered during an install. The user may manually correct the problem and retry installing that file.
    • SetMemoryMax() minimum now 4Mb instead of 16. (Tritical)
    • Remove 50 plugin auto prescan load limit. (Tritical)
    • COM QueryInterface calls now return S_OK instead of NULL.
    • Bracketless call of argless function now get a cache. (Tritical)
    • Over-range numbers now raise a compile time exception.
    • xxxFPS(float) now uses continued fraction to generate a minimal rational pair. (Raymod2)
    • ChangeFPS(linear=true) now raises a compile time exception if the speed change ratio is > 10.
    • ConvertFPS() blend mode works for all pixel formats. (Tritical)
    • Info() retrofit of 2.60 updates.
    • TCPDeliver.dll upx'ed.
    • RGB ColorBars +Q and -I bars, Hue is now correct, Luma is NOT zero to achive this.
    • AVISource Audio no longer limited to 2 channels.
    • SaveString memory blocks are now 32 bit aligned.
    • Default planar chroma planes mod 16 aligned. See SetPlanarLegacyAlignment().
    As usual download from sourceforge
  • AviSynth 2.5.8 RC5
    bis zur final dürfte es nicht mehr allzu lange dauern
  • AVS 2.6.0 Alpha 4 [130114]
  • Nur zum Dokumentieren – seit das Wiki von avisynth.org auf avisynth.nl umgezogen ist, hatte sich auch die URL der Plugin-Sammlung von WarpEnterprises leicht verändert:
    http://avisynth.nl/users/warpenterprises/
    Alternativ dazu auch eine Sammlung innerhalb des Wiki:
    http://avisynth.nl/index.php/External_filters
