DVD ReBuilder - aktuelle Version
  • Version 0.64
    - Added support for DGDECODE.DLL. This is a newer, more accurate, and faster version of MPEG3DEC3DG.DLL. In order to use it, download DGMPGDec from the Doom9 site (the only required portion of the .ZIP file is DGDECODE.DLL. You must point to the file from DVD-RB's "Setup" dialog. The MPEG2DEC3 path area name has been changed to "DECODER". NOTE: In order to use DGDECODE.DLL you MUST point to it in the DECODER area of the setup dialog and it must not be renamed (from DGDECODE.DLL). DVD-RB will default to MPEG2DEC3DG.DLL. Hats off to Neuron2 (Donald Graft) who is an MPEG Maestro.
    - Removed the "Add to AVS" checkbox from the setup screen. It was a source of confusion and probably should never have been implemented. If you enter a path in the "Path to Decoder" box -- it will be loaded in every AVS file.
    - Created a new option under the "Mode" menu that allows you to use a different "Output" path. When selected, the output of VIDEO_TS and AUDIO_TS folders will be sent to that path rather than the "Working Path." This allows users who are low on drive space and have more than one drive to write to two different areas. It also cleans the output up a little -- reducing confusion as to which directories should be burned. You burn only what is in the output directory. If may also increase the rebuild speed. If the option is deselected, DVD-RB will work as it always has -- writing all output to the "Working Path."
    - Fixed an error in "Batch" mode in which some parameters from the saved .RDB file were being loaded and set incorrectly.
    - Note: It continues to be my intention to provide this package as freeware. But it is my belief that I should somehow reward those to took the time and effort to contribute to this project, either through donation or extraordinary testing support. In the future all new releases will be made to a list of VIPs/donators first. After some period (maybe 30 days) that version will be released in a "public" version. Those who helped through donations and special beta support deserve recognition. This is my way of saying "Thanks." THE FIRST DONATOR RELEASE (IN A COUPLE OF DAYS) WILL SUPPORT MULTIPLE ANGLES AND ILVU (I've completed it and am testing it now).
  • Version 0.66
    Below is a summary of the changes/updates associated with this version (VIP release until 30 Nov):
    - Corrected an error in which ReJig encoding failed during the "PREPARE" stage when working on a disc with ILVU and/or angles.
    - Corrected an error that incorrectly always set the "Aspect_Ratio=" variable in the .D2V file to 16:9. (No impact noted in previous version).
    - Found and fixed an error in which interleaved sources, under certain conditions could redirect the PREPARE and/or ENCODE date an incorrect directory.
    - Fixed an error in which Subtitles having an number higher than 9 would be incorrectly shown out of order in the "Subtitles to Keep" listbox.
    - Added support for "Skins" -- user programmable definition files can be created that load backgrounds, set text, and allow you to customize the way you want DVD-RB to look. NOTE: When DVD-RB is executed it will automatically create a SKINS directory within it's execution path! Several default files will then be created in that directory... these files define the default skins. Two defaults are provide. "Rockas Original" is the interface you've seen, as it was released in version 0.65. Also provide as a default is "Windows Standard" which is very similar to what you would have seen in version 0.64a. You can modify them, customize them, do whatever you want... but remember if you ever run into problems you can always delete the files -- and DVD-RB will recreate them the next time it is executed. You can use the two default skins as a baseline for new ones you create. Simply copy the files, rename, and modify and you can play to your heart's content. The name you use (e.g. "My Skin.txt") when creating a new file, will be added to the "Skins" menu the next time DVD-RB is executed. The SKIN code is new -- so some beta problems and feedback is expected. Enjoy.
  • Version 0.66a
    - Fixed the Rebuilder form's header -- removed "3" from the title
    - Fixed an error in which the Subtitles listbox wasn't visible and could not be accessed.
  • Version 0.67
    - Corrected an error that cause QuEnc to fail due to a "blank" .AVS filename.
    - Tweaked SCR calculations to more closely control STD Buffer size. This may reduce or eliminate reported audio dropouts on some players.
    - Added "Rewrite Defaults" option to the "Skins" menu. This will recreate the two standard interfaces in the Skins directory. The option is meant to provide a way to correct any mistakes created in editing the files. It can also be used to implement changes I may make to the standard interfaces.
    - Fixed an cosmetic error in which some residual color was included in "Folder" buttons.
    - Added control over placement of the AudioList, SubList, DTSCheckbox, and MinCheckBox objects in the SETUP dialog box. These were inadvertently left out of the last version.
    - To enable the last two fixes -- YOU MUST SELECT "Rewrite Defaults" in the "Skins" menu so the lastest definitions are updated.
  • VIP v0.68 ist raus:
  • DVD Rebuilder - New [font=verdana, arial, helvetica]VIP [/font]release (0.69b)
  • Der DVD-ReBuilder 0.71 VIP ist raus.
    MfG
    Morpheus
  • die geschwindigkeit von 2.7x scheint in der tat höher auszufallen als bei den vorgängerversionen
    ich habe grade einen test laufen und muss nachher nochmal mit 2.67 gegentesten, aber auf den ersten blick scheint sich grad in dieser hinsicht etwas getan zu haben
    Das kann ich bestätigen, die Geschwindigkeit ist tatsächlich höher.
    Um wieviel muß ich auch erst ausprobieren, hab zur Zeit 4:3 Material in mache und da das bei mir seltener vor kommt hab ich da aus dem Stand keine Vergleichswerte.
    MfG
    Morpheus
  • nach problemen mit cce 2.50 kommt hier nun version 0.72
  • Wobei das neue "Rockas Original" nicht so der Brüller ist.
    Das Status-Fenster ist jetzt so schmal, dass man den Text nicht mehr ganz lesen kann. :nein:
    Cu Rippraff
    Blumige Grüße, Rippraff
