DVD ReBuilder - aktuelle Version
  • Rockas hat einen Matrixeditor (v0.1.4) für den Rebuilder (nur für die Pro-Version) rausgebracht. Ich häng ihn mal an.
    Er wird im Rebuilder-Verzeichnis im Unterordner "MatrixEditor" angelegt und ist mehr oder weniger selbsterklärend.
    Man kann damit die üblichen Verdächtigen auswählen, bearbeiten oder auch eine eigene erstellen.
    Englische Diskussion hier.
    Cu Rippraff
  • Version 0.80 Pro
    - Added code to do a check for existing .M2V file after a
    segment encode is completed, and to reencode the segment
    if it does not (up to 3 tries). There have been reports
    of missing .M2V files causing errors during rebuild.
    Most often this is caused by an errant keystroke stopping
    the encode accidentally -- but it appears that sometimes
    an encoder can abnormally exit leaving DVD-RB without an
    M2V to process. This code should reduce that likelihood.
    - Fixed an error in QuEnc encodes in which the maximum
    bitrate was always set to 9000Kbs. While this would most
    often have little impact there could be instances in
    which this could raise the total bitrate to a level that
    is greater than the DVD specification.
    - Corrected an error where under rare circumstances the
    calculated average and maximum bitrates could be set to
    the same value. This can cause some encoders to fail or
    freeze.
    - Added a "-maxbitrate" parameter to the QuEnc command line
    for segments less than 60 frames in order to ensure HC
    can work in the freeware version. These had been done at
    CBR due to problems seen in both QuEnc and CCE with very
    small segments -- it is needed because HC does VBR
    encoding only.
    - Made changes to the segment encoding code to better assure
    all segments are encoded properly.
    - Added an output line that displays how long the entire job
    has taken in "One-Click" mode.
    FEATURES ADDED TO PRO VERSION ONLY
    - Updated the HC interface so it now works with the newer HC
    Batch encoder. Please note that support for the previous
    HC encoder IS NO LONGER SUPPORTED. This freeware encoder
    is coming along nicely. While not the fastest encoder
    available -- the quality is outstanding. Please note:
    The HC encoder's .EXE file must be loaded in the same
    directory as DVD Rebuilder and the name must start with
    "HCBATCH" (e.g. "HCBATCH_012.EXE").
    - Fixed an error in which the checkmarks weren't being set or
    reset properly in the DC Precision and GOP Selection menus.
    - Fixed an error in HC encodes in which the maximum
    - Added the "*WAIT 0" command to HC encoder settings. This
    will reduce overall DVD encode time on future HC versions.
  • 0.81 PRO raus :
    Changes in this version:
    CHANGES MADE TO PRO AND FREEWARE VERSIONS
    - Fixed the "Runtime Error 52" that occured with the
    working path is invalid. A proper error message now
    appears and gracefully exits the PREPARE.
    - Changed the displayed text of the error message in an
    UpdateIFO routine so it spells out any missing cells
    that it has found during REBUILD. Formerly known as
    the notorious "Contact developer" message.
    - Added the "adjust_q_matrix=0" parameter to ECL files to
    prevent CCE from using adaptive quantizer matrices as
    there could be incompatibilities on some DVD players.
    - Corrected an error in which an exceptionally large
    segment (e.g. Cape Fear bonus disc) could cause DVD-RB
    to not integrate file into the output, causing an
    extreme undersize in the VIDEO_TS folder.
    - Added code that will automatically update your Skins if
    they are out of date. This is needed to ensure layout
    changes or possible new fields are also updated.
    - Changed the button for starting batch encodes from "Ok"
    to "Start" -- the OK button was confusing...
    - Modified the CCE Advanced settings dialog so the number
    of passes can't be changed when CCE Basic is selected,
    (CCE Basic does no more than 2 passes). This seems to
    have caused confusion for some who weren't aware of CCE
    Basic's two pass limit.
    - Removed "Dynamically Assign Cell Bitrates" as a menu
    option. Cell bitrates are always dynamically assigned
    now. Not doing so detracts from output quality.
    - Changed the actions taken for segments of less than 60
    frames. Instead of setting to CBR, VBR is used but with
    a minimum bitrate. This more accurately correct the
    reason for adding this fix originally.
    - Changed INF file slightly. Added two new values to each
    segment section.
    - ADDED A MAJOR "Pro" FEATURE. A Segment Viewer/Editor
    option has been added to the "Options" menu. This editor
    (following the PREPARE phase) allows you to view each of
    the detected segments to see what it contains, you can
    then selectively blank out the video, or replace it with
    a SLIDESHOW. Saved space is reallocated to the DVD's
    main feature. Look for more options being added to the
    editor in future versions.
    - Added a "Movie and Menu Only" option to the "Mode" menu
    this will automatically detect extras following PREPARE
    and blank them out -- leaving the movie and menus fully
    functional.
    - Added a "Movie, Menu, and Slideshow Extras" optin to the
    "Mode" menu. This option will automatically detect extra
    segments and replace them with a SLIDESHOW.
    - Added the ability to set the HC encoder path in the
    SETUP screen. This was requested by a couple of folks
    who wanted to put it somewhere other than in the DVD-RB
    dirctory.
    - Updated STILLFRAME code so frames are no longer reencoded
    but instead are kept intact and are reintegrated into the
    output stream.
    - Removed the path settings for DECOMB.DLL from the SETUP
    screen. The filter is (or at least should be) rarely
    used and I wanted to clean that up before going to
    version 1.00. You can still set the path by editing or
    adding a "DECOMB=" line in the [PATHS] section of the
    REBUILDER.INI file.
  • 0.82 PRO
    - Fixed a "Runtime Error 75" error that can occur when
    files in the working directory cannot be cleared.
    - Corrected settings that may not be set properly
    during a project load (e.g. during batch encoding)
    - Fixed a memory leak that became especially noticable
    in OPV analysis using v0.81. The symptom of this
    problem would be an increase in DVD-RB's memory usage
    over time as jobs are run, and eventually cause memory
    swapping and slowdown after a few jobs in batch mode.
    Note: The leak was not persistent -- meaning it was
    corrected each time DVD-RB would exit and restart.
    - Added code to removed sequence end codes that are
    added as a default on some encoders. The end code
    at the end of a segment can cause problems on some
    players.
    - Fixed an error in which the decoder and HC paths were
    not properly aligned in the "Windows Standard" and
    the "Simple Blue" SETUP screens.
    - Implemented code to keep legacy Skins compatible.
    - Corrected an error in which audio streams recovered
    when blanking segments were not being accounted for.
    This could cause slight undersizing and would not give
    the recovered space to the feature.
    - Fixed an error in which loading a project file was not
    correctly setting either of the "Movie Only" menu only
    options checkboxes (including batch mode). Note that
    the movie would encode properly, it just displays the
    check mark incorrectly.
  • PRO 0.83 ::
    - Fixed an error in which some of the options that are
    not available in "No Compresssion" or "ReJig" modes
    were not properly enabling/deenabling as modes were
    selected.
    - Correct a problem in which VTSs that were 100% ILVU
    content were not included in the output directory.
    - Revamped the processes associated with removal of
    subpictures. In previous versions it was sometimes
    possible for subs to be kept that weren't selected
    and (rarely) for the wrong subs to be removed when
    running in three-click mode.
    - Changed the default minimum bitrate (MIN_BITRATE) to
    500Kbs. It was previously set to 100. This should
    negate the possibility of getting CCE "MPVA VBF ovg
    frame #" errors and DVD-RB's resulting "ERROR:
    Encoder failed to create .M2V. Aborted."
    CHANGES MADE TO PRO VERSION ONLY
    - Added a new "hidden" setting in the [Options] are of
    REBUILDER.INI for enabling CCE's adaptive quantizer
    matrices feature: "CCEAQM=1" -- if you decide to use
    this feature, be very careful. The reason it is
    "hidden" is because, according to the CCE notes, it
    might be incompatible with some DVD players.
    - Corrected an error in which the value "qmat_idx=0"
    could be incorrectly inserted in an ECL file. The
    result could be the use of the standard matrix as
    opposed to the custom one you've chosen.
    - Fixed an error in the segment editor in which the
    amount of savings was incorrectly calculated when
    selecting "SLIDESHOW" settings. The result caused
    the "Recovered Space" to not return to zero as you
    switch between that and "No Action" mode. Final
    calculations were accurate, however.
  • 0.84 pro ist erschienen:
    - IMPORTANT FIX. Implemented new procedures to
    prevent unreported overflow errors that are
    occurring in CCE version 2.70 (both SP and Basic)
    from causing undersized builds (with frames
    missing). Tweaked several parameters that make
    the overflow less likely to happen, and also
    implemented a segment frame count verification in
    the REBUILD phase to flag it should it somehow
    again happen.
    - Added code that does a checksum verification of the
    source directory which is now used in the ENCODE
    and REBUILD phases. There have been several
    reported errors that were caused by attempting to
    encode or rebuild against a different source than
    was mounted at the time of PREPARE.
    - Made several changes related to how DVD-RB handles
    sources that have a width of 704 pixels. While
    these are very uncommon, they are within the DVD
    standard. There should be no more problems with
    reencoding these sources.
    - Changed the mechanism for setting maximum bitrate
    for VBR encodes. The previous method was overly
    aggressive and could cause rates that are too low
    that might force buffer overflows in CCE.
    - Added an additional selection to the "Steal space
    from Extras" menu. You can now decide to steal only
    10% in addition to 25%, 33%, and 50%. This is for
    folks who what to help the main movie, but keep the
    extras reasonably clear as well.
    - Added display of the percent completed value (for
    encoding and rebuilding) when DVD-RB is minimized.
  • 0.84.1
    (v0.84.1) CHANGES MADE TO PRO AND YET TO BE RELEASED FREEWARE
    - Corrected an error in which some under certain
    circumstances some small VOB files may not be
    copied to the output directory and as a result
    might not make it ot the final output.
  • 0.85 Pro
    - Added new support for OPV in the latest version
    of the HC encoder (HCBatch v013 or above).
    Hank315 has modified HC to give greater CQ value
    granularity improving prediction for the One
    Pass Variable Bitrate (OPV) encoding capability
    of HC. Now DVD-RB can use the same prediction
    algorithms developed for CCE OPV prediction to
    get high quality results in a single pass.
    - Reformatted the segment listbox in the segment
    viewer/editor in order to make it more readable.
    - Added version checking/reporting for HC encoder.
    - There is now an INI value under [Options] that
    allows a target output setting that is specific
    to HC. You can set HCTargetSectors= in the same
    way as you would CCETargetSectors. When nothing
    is set, it defaults to the "TargetSectors" value.
  • Das hast Du vergessen ;D :
    - Fixed "Runtime Error 9" error when attempting to
    run in one-click mode with an invalid directory.
    - Added code to reduce the likelihood of false
    positive detection and abort in the "missing
    frames" check routine of the rebuild.
    - Located and corrected a source of Runtime Error
    '9' during rebuild that would have happened on
    exceptionally long source M2V GOPs.
    - Added code to reset the vbr maximum bitrate to
    the maximum DVD compliant rate if creation of a
    a .M2V file is not successful after 2 attempts.
    - Tweaked the OPV prediction algorithm to try and
    reduce the number of passes required to hit the
    target value.
    - Added code to properly identify and output an
    error message when the encoder path is invalid,
    this corrects the non-descript "Error 53".
  • Version 0.86
    Below is a summary of the changes/updates associated with this version (Pro release, Freeware expected for release in mid May, 2005):
    - By popular demand I have added a new Movie-Only mode. By removing all extraneous material this mode guarantees the highest possible quality reproduction of the DVD's main film.
    - Modified the HC One Pass VBR prediction and parameter passing to take advantage of the new version (HCBatch, v014 or above). Hank315 has modified the new version to limit maximum bitrate. This makes it possible to use HC OPV and remain within DVD bitrate limitations. Outstanding work by Hank315. This encoder is giving CCE a run for its money.
    - For experts: I've added a flag under "Resize to Half-D1" that allows for adjustment in the method of resizing. While my testing shows most sources use a "generic PAR" and will be resized directly -- there are ITU PAR sources that need to have the left/right overscan areas stripped before resizing to Half-D1. The "Adjust for ITU Aspect Ratio" flag does that. Please note that the difference is very slight and in most cases would not be noticable. An ITU PAR incorrectly size would only show a 2% horizontal aspect distortion.
    - Added a fix that significantly increased the point at which the "Buffer Overflow 0003" or the "Buffer Overflow 0004" is reached. While this error is normally a result of a corrupted source, I have found at least one example in which the buffer overflowed on a legitimate source. This will correct that.
    - Again changed the method of encoding for very small segments. Some reports of CCE CRC errors make it necessary to create a "workaround". Now all segments of less than 60 frames are encoded using one pass VBR in CCE SP versions. Single frames encoded with CCE Basic are done in CBR. The Pro version still retains STILLS intact.
    - Changed the setting for ProCoder output so the .ECL file (using ECLPro) has "seq_endcode=1" for all encodes. Since DVD-RB now removes endcodes automatically this save time by not requiring ProCoder to do so. Thanks to Robot1.
    - Modified the way DVD-RB calls web pages so it uses the default browser (it was making a call to "Explorer" before -- which always called Internet Explorer. Thanks again to Robot1.
    - Added a "Contents" option to the Help Menu. This will open the default file DVD-RBHELP.CHM in the DVD-RB home direcotry if it exists.
