jetzt gings,im gegensatz zu heut morgen.
DVD ReBuilder - aktuelle Version
dvd rebuilder 0.87 PRO
QuoteCHANGES MADE TO PRO VERSION ONLY
- (v0.87a) Corrected a minor syntax error.
- Fixed an error in Movie-Only mode that caused
a 'Runtime Error 9" on any DVD in which the
main feature is not in VTS_01. Silly mistake.
- Corrected an error in which Movie-Only mode may
create a segment having a frame length of zero
under certain circumstances which could cause
CCE version 2.70 to fail with "No M2V".
- Corrected an error in which the CQ value for HC
was being incorrectly written to the HC INI
file. This could result in erroneous sizing
and prediction loops in countries that use the
comma as a decimal point.
- Added code so the "Contents" help command wll
look in a subfolder "Help" as well as the
DVD-RB executable directory.CHANGES MADE TO PRO AND FREEWARE VERSIONS
- Modified startup routines to prevent multiple
instances of DVD-RB from running concurrently.
This prevents any of a number possible errors
from occurring.
- Corrected an error in which the quality_prec
parameter was being incorrectly converted to
a 0-100 scale. Also improved the accuracy of
the conversion and removed extraneous decimal
values. (Pro v0.86, Freeware v0.84 & up) -
Mittlerweile ist die 0.88 Pro raus. Ich glaub die letzte die ich probiert habe, war die 0.82... :lol:
Quote from jdobbsCHANGES MADE TO PRO VERSION ONLY
- Corrected an error in which a nonexistent
source directory could cause unexpected errors
upon program start.
- Added code so the color lookup table (CLUT) of
the source PGC is collected and stored for use
in Movie-Only output. This should fix the
unreadable green subtitles problem.
- Corrected an error in which movie-only subtitle
tables were being incorrectly updated.
- Fixed an off-by-one error in which the final
segment of a DVD was not being loaded into the
segment viewer/editor.
- Fixed a bug in which "Runtime Error 11" could
occur under certain circumstances when using
"No Compression" and movie-only mode.
- Corrected an error that could cause incorrect
sizing when changing parameters in the editor
or choosing "Movie and Menus Only" or "Movies,
Menus, and Slideshow Extras".CHANGES MADE TO PRO AND FREEWARE VERSIONS
- Modified the "missing frames" message. It now
makes a reference entry in the status window
and continues with the rebuilding process.
(Changed on unreleased freeware versions as
well). I have concerns that RB may be finding
false positives.
- Corrected an error in which MPEG Layer audio
was not being accounted for properly in the
DVD sizing and was not being removed properly
when selected for removal. This was causing
oversizing on homemade discs (commercial discs
generally use AC3 audio).
Cu Rippraff -
Die Freewareversion 0.85 ist raus.
Quote from jdobbsThe changes to this version are listed below:
- Fixed "Runtime Error 9" error when attempting to run in one-click mode with an invalid directory.
- Added code to reduce the likelihood of false positive detection and abort in the "missing frames" check routine of the rebuild.
- Located and corrected a source of Runtime Error '9' during rebuild that would have happened on exceptionally long source M2V GOPs.
- Added code to reset the vbr maximum bitrate to the maximum DVD compliant rate if creation of a a .M2V file is not successful after 2 attempts.
- Tweaked the OPV prediction algorithm to try and reduce the number of passes required to hit the target value.
- Added code to properly identify and output an error message when the encoder path is invalid, this corrects the non-descript "Error 53".
- Corrected an error in which the quality_prec parameter was being incorrectly converted to a 0-100 scale. Also improved the accuracy of the conversion and removed extraneous decimal values.
- Changed "missing frames" check so that it only reports "possible" missing frames, but does not stop the process.
Zu bekommen bei doom9 oder hier. Auch als Installerversion mit den akuellsten Programmen.
Cu Rippraff
Guten Morgen,
Die Pro-Version 0.89 ist raus.QuoteChanges in this version:
- Corrected an error in the way subtitle streams
are identified in movie-only mode.
- Fixed "Runtime Error 6" error that could occur
in the ENCODE phase when attempting to use
SLIDESHOW mode on the last segment of a stream.
- Changed OPV encoding so it doesn't use custom
matrices. Since OPV uses constant quality
(quantizer) encoding, the precalculated bitrate
shouldn't be used as a method of determining
quantizer matrix as it really doesn't apply.
This should make sizing predictions more
accurate.
- Corrected an error in REBUILD that could result
in a "Runtime Error 6, Overflow" when still
rebuilding segments selected as SLIDESHOW.CHANGES MADE TO PRO AND FREEWARE VERSIONS
- Modified code so that proper structure will be
created whether or not DVD Decrypter's "Remove
Structure Protection" is selected. Because
DVD-RB made corrections itself, in previous
versions using a source for which Decrypter
had also removed structure protection would in
effect reverse itself and cause long blanks at
title start.
- Adjusted subpicture stream id collection so it
will work properly with a multiple PGC source.
- Corrected an error in which "Reduce by 50%" was
not being read properly from .RBD files so it
was not being set properly in batch encodes.
(Changed in Pro v0.89 and unreleased Freeware)
- Modified the project save routine so that now
subpicture selections are also saved in the RBD
file.
- Corrected a problem in which attempting to call
an encoder with an incorrect path could cause
"Runtime Error 52" and cause Rebuilder to abort.
- Modified audio and subpicture handling so that
unreferenced streams (streams listed in the IFO
attributes tables that are never used in a PGC)
are labeled as such and defaulted to off.
- Fix a bug in which selecting CCE Mode on the
menu was incorrectly resetting the CCE path to
the one selected for "CCE SP" regardless of the
version truly selected. -
Die Freewareversion 0.86 ist raus.
QuoteThe changes made to this release are outlined below:
- Added a fix that significantly increased the point at which the "Buffer Overflow 0003" or the "Buffer Overflow 0004" is reached. While this error is normally a result of a corrupted source, I have found at least one example in which the buffer overflowed on a legitimate source. This will correct that.
- Again changed the method of encoding for very small segments. Some reports of CCE CRC errors make it necessary to create a "workaround". Now all segments of less than 60 frames are encoded using one pass VBR in CCE SP versions. Single frames encoded with CCE Basic are done in CBR. The Pro version still retains STILLS intact.
- Changed the setting for ProCoder output so the .ECL file (using ECLPro) has "seq_endcode=1" for all encodes. Since DVD-RB now removes endcodes automatically this save time by not requiring ProCoder to do so. Thanks to Robot1.
- Modified the way DVD-RB calls web pages so it uses the default browser (it was making a call to "Explorer" before -- which always called Internet Explorer. Thanks again to Robot1.
- Added a "Contents" option to the Help Menu. This will open the default file DVD-RBHELP.CHM in the DVD-RB home direcotry if it exists.
- Corrected an error in which "Reduce by 50%" was not being read properly from .RBD files so it was not being set properly in batch encodes. (Freeware only)
Die Pro-Version 0.90 ist raus.
- (v0.90a) Fixed a last minute syntax error.
- Fixed an error (introduced in v0.89) in which
Movie-Only mode could fail to execute under
certain circumstances.
- Fixed a source of "Runtime Error 9" during the
encode phase when using OPV.
- Fixed "Runtime Error 5" that could happen upon
startup under certain conditions. -
Die Pro-Version 0.91 ist raus.
- Modified the handling of Movie-Only and it's
relationship to D2V files. Also cleaned up
problems with Movie-Only and certain types of
structure protection.
- Fixed "Runtime Error 340" that could happen
when attempting to automatically change the
Movie-Only option.
- Corrected "Runtime Error 6" during REBUILD on
sources that have very large TMAP tables in
the IFO file.
- Added code to inhibit the "...is already
small enough to fit " warning when using the
"No Compression" mode.
- Made a change to OPV prediction routines that
will significantly improve output sizing on
certain types of movies.
- Removed the restriction that limited output
size to 100% of the original. There are rare
occasions in which additional processing (e.g.
frame resizing/filtering) may need additional
bandwidth that is made available through extra
reduction or movie-only modes. Generally,
though, it is best to use "No Compression" mode
on sources that would hit 100% or greater.
- Added code to include a "(DC)" to the
description of audio and/or subtitle streams if
they are flagged as director's comments. Also
added a "(F)" to subtitles that are forced.
- Corrected an error in which very rarely, under
a specific set of circumstances, a 4:3 source
(that has some portion of its stream flagged as
16:9) could incorrectly change the aspect ratio
to 16:9 in the IFO file.
- Changed the default background color to one
that is more standard. The background color
only applies to skins that have no graphic that
fills the background (like "Windows Standard").
- Corrected an error in which retail versions of
CCE 2.67 before v2.67.0.27 would set the wrong
value for "video_type" in the ECL and perform
OPV rather than multipass encoding. -
:hm: Schlaft der Author auch mal? :hm:
Die Freewareversion 0.89 ist erschienen!
- Modified code so that proper structure will be created whether or not DVD Decrypter's "Remove Structure Protection" is selected. Because DVD-RB made corrections itself, in previous versions using a source for which Decrypter had also removed structure protection would in effect reverse itself and cause long blanks at title start.
- Adjusted subpicture stream id collection so it will work properly with a multiple PGC source.
(Changed in Pro v0.89 and unreleased Freeware) - Modified the project save routine so that now subpicture selections are also saved in the RBD file.
- Corrected a problem in which attempting to call an encoder with an incorrect path could cause "Runtime Error 52" and cause Rebuilder to abort.
- Modified audio and subpicture handling so that unreferenced streams (streams listed in the IFO attributes tables that are never used in a PGC) are labeled as such and defaulted to off.
- Fix a bug in which selecting CCE Mode on the menu was incorrectly resetting the CCE path to the one selected for "CCE SP" regardless of the version truly selected.
- Modified the "missing frames" message. It now makes a reference entry in the status window and continues with the rebuilding process.
(Changed on unreleased freeware versions as well). I have concerns that RB may be finding false positives.
- Corrected an error in which MPEG Layer audio was not being accounted for properly in the DVD sizing and was not being removed properly when selected for removal. This was causing oversizing on homemade discs (commercial discs generally use AC3 audio).
- Modified startup routines to prevent multiple instances of DVD-RB from running concurrently. This prevents any of a number possible errors from occurring.
- Added code so the "Contents" help command wll look in a subfolder "Help" as well as the DVD-RB executable directory.
Databox -
Direkte Downloadlinks sind eigentlich verpönt (und oft gar nicht erlaubt), also besser den hier nehmen.
Cu Rippraff -
wie sieht es denn mit links aus, die direkt auf Seiten führen wo man den http://dvd-rb.dvd2go.org/modules.php?na…op=getit&lid=75DVD Decrypter runterladen kann?
Denn der Link von dir führt direkt dahin.
lanius -
0.92 PRO
- Added support for multiple angles in Movie
Only mode. Previous versions would copy the
multiple angle sections but did not make IFO
changes allowing selection and playback.
- Modified Movie-Only creation so it recreates
the cell structure of the original DVD/PGC.
Previous versions built chapter tables based
upon the cell structure of the primary PGC.
- Found and fixed "Runtime Error 5" that could
occur immediately upon start of PREPARE when
using Movie-Only mode. My thanks to bryanb
and Lark for pointing out and helping with
finding this very elusive problem.
- Added an advanced "Graphic Analysis" display
that will show the structure of a VTS to help
the user understand the original authoring.
The display is accessible by double-clicking
on the VTS you wish to view in the "Video
Title Sets" list box.CHANGES MADE TO PRO AND FREEWARE VERSIONS
- Modified the selection routine for "Source"
so that now if a directory is selected that
contains a "VIDEO_TS" subdirectory, that
directory is automatically tried before
returning a "does not contain" error message.
This seems to have caused some confusion to
some users.I hope you enjoy this new version of DVD-RB.
- Added support for writing ISO images using the
mkisofs utility. In order to make this option
you must have the MKISOFS program file installed
in either the rebuilder directory ora subdirectory
under rebuilder called "APPS". Note taht this
is all done automatically if you use the Rockas
installer. If you are doing a manual install,
the two files needed (mkisofs.exe and cywin1.dll)
are included in the rebuilder zip file. After
the files exist, the next time you run DVD-RB
the "Output to ISO Image File" option in the
"Mode" menu will be enabled. You can also select
a VOLUME NAME and FILE NAME for the ISO image or
choose to automatically delete the files after
writing (to save space). These options are
selected using the "Select ISO Output Options"
selection -- also under the MODE menu.
- Added automatic burning of created ISO images
with DVD Decrypter. If the "Automatically
Burn with DVD Decrypter" option is selected
under the "Select Output Options Dialog" the
ISO created will be automatically written to
disc using DVD Decrypter at the end of the
REBUILD phase. Please note that this option will
be disabled if DVD Decrypter has not been
installed on the host computer. Also note: This
option is ignored when in "Batch" mode for
obvious reasons.
- Added a FILE menu option to burn an ISO image,
this is just for convenience, as the image is
actually burned by DVD Decrypter.
- Changed the "MPEG Standard" matrix so it is
updated to what is generally considered more
"standard" today. In order to update it, you
can just delete the file "MPEG Standard.mtx"
from the MATRIX directory under the DVD-RB
installation path. DVD-RB will see it is
missing and update it when next started.
- Added a menu selection under "OPTIONS/AVS
OPTIONS/ADVANCED (EXPERT) OPTIONS" in which
you can instruct the decoder to use of of a
list of 7 iDCT choices. This replaces the
former single "idct=7" choice.
- Added a new "Key" mechanism so the executable
file "REBUILDER.EXE" can be downloaded from
multiple locations and can be included in the
Rockas Installer package. The executable will
not run unless a "KEY" file exists in the
DVD-RB directory. Similar to the previous
method, when VIPs are notified of new versions
they will receive a link to a personalized key
file. Placing this key file in the DVD-RB
directory will enable the software.CHANGES MADE TO PRO AND FREEWARE VERSIONS
- Found and corrected a long-time vexing error
that could cause "Buffer Overflow...0003" and
"Buffer Overflow...0004". This is very likely
the root of some of the "preprocessing" errors
that have been reported -- and was accentuated
in DVD-RBs "Movie and Menus Only" mode. This
one was truly difficult to pin down. My thanks
to Carpo, t3rror, and Numer0bis for helping to
nail this elusive error.
- Fixed an error in which the TMAP tables were
not being updated correctly for Interleaved
and/or Angled sources. This may have caused
errors in random access into those sections.
- Corrected a source of possible "Runtime Error
9" that could happen when IFO and VOBs aren't
in agreement about ILVU. This conflict may
happen during PREPARE when certain types of
preprocessing have been done).
- Changed output directory format. Now in the
designated output dirctory a subdirectory is
created called "DVDFILES". The AUDIO_TS and
VIDEO_TS folders are created under that name.
This is meant to help avoid confusion and
assist in future enhancements by consolidating
all files that should be written to the DVD
within a single directory.Und so wie es aussieht nähern wir uns mit großen Schritten der Final Version 1.0.
Gibt mitlerweile zumind. für die Pro Version einen Installer und Reg-Key -
Nur zur Info
Die DVD Rebuilder PRO 0.93 beta kann man jetzt auch downloaden, man muß nimmer auf die email von [font=verdana, arial, helvetica]jdobbs warten. Dafür erhält man aber ein key womit man sein RB freischalten muß ;D also es gibt auch weiterhin keine Pro umsonst.
Einmal bekommt man sie als ZIP Version zum DL oder als EXE die dann alles für einen einstellt.
Hab es selbst mal getestet und muß sagen es wird immer besser.
[/font] -
Die RB 0.93 Pro ist fehlerhaft auf manchen Systemen, ich bekam gerade eine Laufzeitfehlermeldung 13. Das ist jdobbs bekannt und er hat das gleich in 0.93.1 gefixt.
Wer also auch diese Fehlermeldung erhält, bitte die 0.93 nochmal runterladen, ist die richtige, auch wenn dort nicht extra 0.93.1 steht. Hab's gerade ausprobiert.
Edit:
Quote from IaniusDie DVD Rebuilder PRO 0.93 beta kann man jetzt auch downloaden, man muß nimmer auf die email von [font=verdana, arial, helvetica]jdobbs warten.[/font]
Das halte ich allerdings für falsch. Du kannst zwar das Programm runterladen, musst aber nach wie vor auf die Email von jdobbs warten, da Du sie ohne Key nicht zum Laufen bekommst.Cu Rippraff
Quote from Rippraff
Edit:
Das wäre arm, wenn es so wäre
einmal den key runterladen solte genügen. Ansonsten würde er nur aus Traffic gewinnen da er dann weniger hatt.
Aber der Ärger das der eine oder andere keine email bekommen hatt, hatt er somit immernoch.
Also ich habe gestern für den Rebuilder gespendet. 30 Sekunden später war das email da, in dem 1) der Downloadelink zum Rebuilder Pro 0.93 angegeben war und 2) der Link zu meinem persönlichen Schlüssel.
Keine Spur von "auf das email warten müssen"
Es geht jetzt sicher nicht darum das man zwischendurch spendet und dann seine Version bekommt.
Sondern wenn eine neue Version erscheint, wollen ja alle zur gleichen Zeit ihre Versionen haben und nicht erst Stunden / Tage später.Aber jetzt wird es langsam OFF Topic ;D daher bin ich mal still ;D
0.93.2
CHANGES MADE TO THE PRO VERSION
- Added a checkmark on the menu for AVS Filter
editing. If checked, it indicates that filters
are present in the editor. Also added a line
to the status/log when starting a job that shows
when filters are in effect.
- Adjusted the ISO Image creation code so it would
be more robust in recognizing error conditions.
- Fixed an error in the ISO Image creation routine
in which ISO output would fail when either of the
output or working directories contained one or
more embedded spaces.
- Changed the registry entry from which the DVD
Decrypter path was collected, the one used may
not have been set on all systems.
- (v0.93.1) Corrected an error that was causing
"Runtime 13" when the "ENCODERS" directory wasn't
created.I hope you enjoy this new version of DVD-RB.
jdobbs
