DVD ReBuilder - aktuelle Version
  • DVD-RB v093a Beta Freeware
  • RC1 Pro
    CHANGES MADE TO PRO VERSION ONLY
    - Added a new v1.00 graphical interface that is based
    upon a prototype developed by Teck. Now by using
    selection tabs the majority of functions can all be
    handled from within the main dialog! My thanks to
    Teck for a great idea. I've also included a Rockas
    theme design (based upon Teck's) as the default. For
    folks who like the traditional interface -- you have
    something new too! Rockas has updated the
    Professional Edition with a new "Rockas Original"
    skin design. Skins are still fully functional.
    - Added full support for reencoding and reauthoring of
    ILVU sequences. Now very large ILVU sections will
    no longer put severe limits on bitrates. Lots of new
    code was implemented here -- I ask that all of the
    DVD-RB beta testers please exercise it thoroughly
    and report back on DOOM9. Note: If you run into
    problems or would like to disable this code for any
    reason and force use of the previous "ILVU-intact"
    method -- add the hidden command "ILVU_Encode=0" in
    the [Options] section of the REBUILDER.INI file.
    - Implemented a new key mechanism. It works much like
    the old one -- in that you have to simply copy the
    file into the DVD-RB directory. But you must also
    know your registered e-mail address and use it to
    activate the key (from within DVD-RB). Also, it is
    always named "REBUILDER.RBK" -- the last naming
    structure caused lots of headaches for those having
    a ".AU" in their e-mail name. It also threw errors
    when double clicked because it wasn't a registry
    key as many assumed.
    - Added ISO failsafe code so that padding is inserted
    at any time it may be possible for an IFO and BUP to
    overlap in the same ECC. This dramatically decreases
    the possibility of a scratch ever damaging both an
    IFO and it's corresponding backup (BUP) file (which
    can render a disc unplayable). Note that this action
    is only taken when DVD-RB has been instructed to
    create an ISO image. Also note IFOEDIT will
    incorrectly see the changes to the IFO for padding as
    offset errors. Do NOT perform an IFOEDIT "Get VTS
    Sectors" against a VIDEO_TS folder that has been built
    for ISO unless you are planning to use some other
    burning package to create the disc -- as IFOEDIT will
    incorrectly change the values back to the non-failsafe
    state.
    - Added procedures that automatically determine the
    volume label and ISO filename when selecting an
    input source. Uses actual device detected Volume
    ID or directory name depending upon the input source
    and path format. Default value is "DVD-VIDEO"
    - Added quotes around volume label for ISO creation.
    Previously any spaces in the volume name could
    cause ISO burn to get confused.
    - Fixed an error in which an iDCT method loaded from
    a project could cause two options to be checked.
    - Updated the QLB Matrix to match DragonGodz latest
    changes. in order to update it, you can just
    delete the file "QuEnc Lower Bitrate (QLB).mtx"
    from the MATRIX directory under the DVD-RB
    installation path. DVD-RB will see it is missing
    and update it when next started.
    - Modified the parameters for HC to match the newer
    versions -- there is now only three quality
    profiles (FAST, NORMAL, BEST).
    - Fixed an error in which the segment viewer/editor
    would allow you to make changes even though the
    source information had changed since PREPARE.
    - Changed the viewer/editor so is shows VOBID/CELLID
    and length (in hh:mm:ss:ff) in time rather than
    segment number and frame count. I think this may
    be more useful information to most people.
    - Added two more options to the FILE menu. You can
    now select to create an ISO, or create and write
    (to disc) an ISO for the current project.
    - Fixed an error that could cause undersizing in
    movie-only encodes due to miscalculating the size
    of the original stream (especially true in ILVU
    sources).
    CHANGES MADE TO PRO AND FREEWARE VERSIONS
    - Fixed an error that could cause an "Runtime Error
    9" upon program start or when loading a Project
    file when the source path is no longer present.
    - Added code to disable path buttons when running
    any of the tree phases. Previously changing any
    of the Source, Working, or Output paths (either
    purposefully or accidentally) during execution
    could cause various errors (including Runtime 54).
    - Adjusted the average bitrate for encodes to
    ensure it the minimum and average bitrates were
    never the same.
    - Added a confirmation note when audio or subpicture
    defaults are saved from the SETUP screen. Also
    removed the old screen flags that were incompatible
    with skins.
    - Fixed an error in which ReJig could receive values
    greater than 100% for its reduction level.
    - Fixed an error that could result in "Runtime Error
    52" on certain sources when using either ReJig or
    "No Compression" settings.
    - Fixed an error in which exiting via the Windows "X"
    while rebuilding is in occuring could have anomalous
    results -- including program lockout.
    I hope you enjoy this new version of DVD-RB.
    jdobbs
  • 1.0 RC2
    - Corrected algorithm for seamless branching analysis
    and detection. RC1 made some incorrect assumptions
    that could result in bad interleaving. This could
    also have resulted in several other possible errors
    based upon the structure of the source. This might
    also be a cause of "Runtime Error 63".
    - Fixed an error that was causing a "Runtime Error 9"
    when selecting/deselecting an audio or subpicture
    stream when no VTS was highlighted.
    - Fixed "Runtime Error 6" that could happen when while
    interleaving ILVU objects.
    - Fixed an error in which the PREPARE phase could get
    stuck awaiting a keystroke at the message "Blanking
    all EXTRA Segments" when "Movies and Menus Only" or
    "Movies and Slideshow Extras" are chosen.
    - In response to the "man, that sure is ugly" comments
    about the bluish backgrounds used in controls in the
    tab areas I have changed them in the Teck Skin and
    also added a variable to the Skin definitions called
    "v1TextBackground" that can change it. I'd like it
    to be clear that Teck was not responsible for that
    color choice.
    - Enabled the "Remove Dir Comments" function in the
    Setup screen and made it functional. Also added it
    to the Teck skin's setup. I kinda' forgot about
    this on the first RC...
    - Fixed error in which display of selected subtitle
    and audio streams display was not correctly updated
    when changing selected Skin.
    - Added set parameters that ensure ILVU compliance as
    appropriate when using the HC encoder. This only
    affects ILVU segments.
    appropriate when using the QuEnc encoder. This only
    jdobbs
  • v1.00RC3 der Pro ist raus. :)
    Cu Rippraff
    Blumige Grüße, Rippraff
  • Und weiter geht's, die Final rückt immer näher (siehe dazu auch hier), jetzt ist v1.00RC4 raus! :)
    Cu Rippraff
  • Jetzt wird die Nummerierung spaßig: v1.00RC4.1 ist raus. ;)
    - Corrected an off-by-one sector error in the VTS_C_ADT table of an IFO that contains ILVU sections. This issue was the cause of reported problems importing DVD-RB into DVD Shrink after rebuild. It also caused DVDReMake to sometimes require "recovering sectors".
    - Fixed an error in the routine for updating the VTS_TMAPTI table in IFOs containing ILVU sections. In previous versions some seamless branching titles could have had erroneous entries created.
    - Fixed "Runtime Error 63" that can be caused by large ILVU (greater than 1GB) segments.
    - Added progress bar updates during "Interleaving Video Object" activity.
    Cu Rippraff
  • v1.00 RC5
    - Modified the "Layer Break" recognition code to make it
    more aggressively find and remove layer-break related
    pauses.
    - Added option to change Variable Bitrate Bias for HC
    Encoder. The default value is 20. This setting can
    help keep dark images and fade-ins from pixelating.
    This HC encoder just keeps getting better, hat's off
    (again) to Hank315.
    - Corrected an error that could result in the "File...
    shows completed, but no .M2V file exists" on some ILVU
    segments during ENCODE phase. A special thanks to
    SDragoon for helping to nail this down.
    - Fixed "Runtime Error 52" that could occur on some ILVU
    segments during PREPARE. Related problem to the "no
    MPV file" problem mentioned above. Many thanks to
    soupdragon and RaistlinMajere for the excellent beta
    testing and support.
    - Added "memory" to the Source Directory browse button
    so it will start at the last directory used.
    - As suggested by MarkRB -- added "Full Backup" as a
    choice under the mode menu to make it a little clearer
    how to get back out of one ofthe movie-only modes.
    Also changed the functioning of "Steal Space from
    Extras" in the same way.
    - Fixed an error in which exceptionally large ILVU
    sequences could cause a "Runtime Error 6" during the
    REBUILD phase. This may also have been a source of
    other odd behaviour with large sequences. Thanks to
    ookzDVD for identifying and helping resolve this issue.
    - Fixed an error that could cause OPV prediction to fail
    when encoding in ILVU sections. Please note, however,
    that while DVD-RB may work in OPV with ILVU sections,
    it is NOT recommended that ILVU discs be done in OPV.
    Thanks to Acerjen for pointing this out.
    jdobbs
  • Version 1.00 RC5.1
    - Fixed a glitch in which attempting to overwrite the
    "DVDFILES\VIDEO_TS" could result in being asked the
    same "Overwrite?" prompt twice.
    - Fixed "Runtime Error 63" that could happen on certain
    ILVU sections under specific circumstances.
    - Fixed "Runtime Error 5" when deleting Batch items
    when using one of the non-version-one skins.
    - Fixed "Runtime Error 52" that could happen at the end
    of the PREPARE phase on ILVU titles that end on with
    ILVU section.
  • Inzwischen gibt es auch eine neue Free-Version v0.94 (beta)
    Zitat von jdobbs
    Das ganze gibt's hier.
    Cu Rippraff
  • v1.00 RC6
    - Corrected an error in which resetting "Steal Space
    from Extras" back to 0% was not taking effect until
    the next load of DVD-RB.
    - Fixed a bug in which a "Error 0006 -- DVD-RB has
    found framecount..." error could occur on very small
    segments during REBUILD when selecting the "Movie
    and Menus Only" mode.
    - Added an adjustment to maximum bitrate for MPEG audio
    streams that are included for processing.
    - Corrected an error in which QuEnc versions may not be
    identified correctly (shows as UNKNOWN).
    - Modified the caption in the "Mode" Menu "Steal Space"
    option. It now tells you the reduction percentage
    that is selected.
    - Changed the code when opening .RBK files. You will
    now be prompted as to whether you want to install it
    as the default key. If you answer "Yes" -- DVD-RB
    will automatically copy and register it. DVD-RB must
    be installed first, of course.
    - Fixed an error that could, on very rare occasions,
    negatively affect the calculated SCR value.
    - Tweaked SCR calculation to correct itself for certain
    odd circumstances that could occur in the input stream.
    Fixes "stutter" that occurs as a result.
    - Fixed an error in which ISO label and file names were
    not being properly set when loading from a project
    file.
    - Added code to recognize and attempt to correct system
    clock reference (SCR) irregularities in the audio of
    the source disc.
    - Modified the OPV encoding prediction algorithm so that
    it will take fewer passes on each VTS.
    - The default Q sample percentage for OPV has been
    changed to 2%. Also made the OPV Q selection more
    conservative as it was oversizing too frequently.
    jdobbs
  • Neue Freeversion 0.95 ist raus.
    Gibt's hier und wie immer auch hier.
    Cu Rippraff
  • Auch mal was Neues: jdobbs gibt das Changelog von Pro Edition Version 1.00 (FINAL) raus, bevor diese erschienen ist. :D
    Morgen (7.10.) soll's soweit sein.
    Der Grund ist einfach, soll die letzte Möglichkeit sein, die Zauderer zum Spenden zu überreden. Mehr dazu hier.
    Cu Rippraff
  • Zitat von jdobbs
    To all,
    Please -- I posted the release notice yesterday for v1.00 Final and in the post I wroteI posted early purposely to ensure no one would get angry that they weren't warned when the minimum donation requirement goes up.
    Please, no more PMs or e-mails.... it hasn't been released yet.
    I'm working on a couple of small changes that I think are important to complete before it is released. Hopefully I'll get it done by late tonight (EDT) so I can get it out today....
    wurde auf morgen verschoben :D
    Zitat von jdobbs
    I've changed it to the 8th... getting it finished and mailed today isn't realistic.
    MfG Laserman!
  • Den Hauptgrund hättest Du ja auch posten können... ;D
    Zitat von jdobbs
    I thought I had plenty of time... and then earlier today a windstorm came up and a significant portion of the tree in my front yard ended up on my porch. I've spent most of the day with a chainsaw trying to clear a path to my front door.
    Needless to say, I'm not in a very good mood right now. [Blockierte Grafik: http://forum.doom9.org/images/smilies/angry.gif]
    :ani_lol: <= obwohl's schon fast etwas gehässig ist, ich fand's trotzdem lustitsch. :)
    Cu Rippraff
  • Auch nicht schlecht, niemand hat die Final 1.00 erhalten, dafür wird momentan Pro Edition Version 1.01 (Final) verschickt. ;D
    Version 1.01
    - Found and corrected an inconsistency related to the SML_AGLI table that could affect various chapter and searching functions on ILVU sections.
    Hatte der abgebrochene Bradford Birnbaum doch sein Gutes... ;)
    Cu Rippraff
  • 1.02
    CHANGES MADE TO THIS PRO VERSION
    - Added a new feature under the OPTIONS menu. Now you can select "Audio Track Remapping" and DVD-RB will make changes necessary so that defaults for audio streams can be changed. This is especially useful when DTS is the default and has been removed, or for those who would like the default startup track to be some language other than the original.
    - Added "Dynamic Peak Analysis" which determines peak bitrates from the original stream and uses the info to set segment maximum bitrates. This should improve quality by more accurately distributing available bandwidth. It should also eliminate some possible sources for playback stutter.
    - Fixed a bug in which attempting to apply filters against a source that would already fit on a DVD-5 could halt the batch job waiting for a user prompt.
    - Modified the "Shutdown at One-Click Completion" option under the MODE menu. Now it is "Shutdown at end of REBUILD". This was done in order to allow usage with the "2-click" method introduced in the previous release.
    - Added ProCoder under the OPTIONS menu and added the ability to set the quality level.
    - Fixed "Error 35601, Element Not Found" error that could occur on oddly formatted sources.
    - Changed the Installed default operational mode to "One Click." Earlier versions defaulted to "Three Click" mode.
    - Corrected setting in which GOP size of 12 was being forced too liberally when using HC encoder.
    - Per request, added a new INI parameter that enables the insertion of text in blanked segments. For example, by adding "BlankText=This Video has been Blanked" to the the "[Options]" are of REBUILDER.INI will insert that text on blanked screens. The text has a limit of 40 characters. By default no text is inserted.
    - Added bitrate sanity checks for circumstances in which the calculated bitrate might be greater than the original. This can sometimes happen in Movie-Only modes. An analysis of reports of stutter occurring on certain players has determined it is linked to the reintegration of the original audio stream with higher-that-original bitrates. It is possible to override this check (but it is NOT RECOMMENDED) by adding the hidden flag "OVERRIDE_BITRATE_CHECK=1" to the "[Options]" area of REBUILDER.INI.
  • Neue Free 0.96 ist raus.
    Gibts hier und mittlerweile auch hier.
    Cu Rippraff
