Zitat von ChangesAlles anzeigenChanges to the freeware version made since the last release (v0.91) are listed below:
- Found and corrected a long-time vexing error that could cause "Buffer Overflow...0003" and "Buffer Overflow...0004". This is very likely the root of some of the "preprocessing" errors that have been reported -- and was accentuated in DVD-RBs "Movie and Menus Only" mode. This one was truly difficult to pin down. My thanks to Carpo, t3rror, and Numer0bis for helping to nail this elusive error.
- Fixed an error in which the TMAP tables were not being updated correctly for Interleaved and/or Angled sources. This may have caused errors in random access into those sections.
- Corrected a source of possible "Runtime Error 9" that could happen when IFO and VOBs aren't in agreement about ILVU. This conflict may happen during PREPARE when certain types of preprocessing have been done).
- Changed output directory format. Now in the designated output directory a subdirectory is created called "DVDFILES". The AUDIO_TS and VIDEO_TS folders are created under that name. This is meant to help avoid confusion and assist in future enhancements by consolidating all files that should be written to the DVD within a single directory.
- Modified the selection routine for "Source" so that now if a directory is selected that contains a "VIDEO_TS" subdirectory, that directory is automatically tried before returning a "does not contain" error message. This seems to have caused some confusion to some users.
DVD ReBuilder - aktuelle Version
RC1 Pro
CHANGES MADE TO PRO VERSION ONLY
- Added a new v1.00 graphical interface that is based
upon a prototype developed by Teck. Now by using
selection tabs the majority of functions can all be
handled from within the main dialog! My thanks to
Teck for a great idea. I've also included a Rockas
theme design (based upon Teck's) as the default. For
folks who like the traditional interface -- you have
something new too! Rockas has updated the
Professional Edition with a new "Rockas Original"
skin design. Skins are still fully functional.
- Added full support for reencoding and reauthoring of
ILVU sequences. Now very large ILVU sections will
no longer put severe limits on bitrates. Lots of new
code was implemented here -- I ask that all of the
DVD-RB beta testers please exercise it thoroughly
and report back on DOOM9. Note: If you run into
problems or would like to disable this code for any
reason and force use of the previous "ILVU-intact"
method -- add the hidden command "ILVU_Encode=0" in
the [Options] section of the REBUILDER.INI file.
- Implemented a new key mechanism. It works much like
the old one -- in that you have to simply copy the
file into the DVD-RB directory. But you must also
know your registered e-mail address and use it to
activate the key (from within DVD-RB). Also, it is
always named "REBUILDER.RBK" -- the last naming
structure caused lots of headaches for those having
a ".AU" in their e-mail name. It also threw errors
when double clicked because it wasn't a registry
key as many assumed.
- Added ISO failsafe code so that padding is inserted
at any time it may be possible for an IFO and BUP to
overlap in the same ECC. This dramatically decreases
the possibility of a scratch ever damaging both an
IFO and it's corresponding backup (BUP) file (which
can render a disc unplayable). Note that this action
is only taken when DVD-RB has been instructed to
create an ISO image. Also note IFOEDIT will
incorrectly see the changes to the IFO for padding as
offset errors. Do NOT perform an IFOEDIT "Get VTS
Sectors" against a VIDEO_TS folder that has been built
for ISO unless you are planning to use some other
burning package to create the disc -- as IFOEDIT will
incorrectly change the values back to the non-failsafe
state.
- Added procedures that automatically determine the
volume label and ISO filename when selecting an
input source. Uses actual device detected Volume
ID or directory name depending upon the input source
and path format. Default value is "DVD-VIDEO"
- Added quotes around volume label for ISO creation.
Previously any spaces in the volume name could
cause ISO burn to get confused.
- Fixed an error in which an iDCT method loaded from
a project could cause two options to be checked.
- Updated the QLB Matrix to match DragonGodz latest
changes. in order to update it, you can just
delete the file "QuEnc Lower Bitrate (QLB).mtx"
from the MATRIX directory under the DVD-RB
installation path. DVD-RB will see it is missing
and update it when next started.
- Modified the parameters for HC to match the newer
versions -- there is now only three quality
profiles (FAST, NORMAL, BEST).
- Fixed an error in which the segment viewer/editor
would allow you to make changes even though the
source information had changed since PREPARE.
- Changed the viewer/editor so is shows VOBID/CELLID
and length (in hh:mm:ss:ff) in time rather than
segment number and frame count. I think this may
be more useful information to most people.
- Added two more options to the FILE menu. You can
now select to create an ISO, or create and write
(to disc) an ISO for the current project.
- Fixed an error that could cause undersizing in
movie-only encodes due to miscalculating the size
of the original stream (especially true in ILVU
sources).CHANGES MADE TO PRO AND FREEWARE VERSIONS
- Fixed an error that could cause an "Runtime Error
9" upon program start or when loading a Project
file when the source path is no longer present.
- Added code to disable path buttons when running
any of the tree phases. Previously changing any
of the Source, Working, or Output paths (either
purposefully or accidentally) during execution
could cause various errors (including Runtime 54).
- Adjusted the average bitrate for encodes to
ensure it the minimum and average bitrates were
never the same.
- Added a confirmation note when audio or subpicture
defaults are saved from the SETUP screen. Also
removed the old screen flags that were incompatible
with skins.
- Fixed an error in which ReJig could receive values
greater than 100% for its reduction level.
- Fixed an error that could result in "Runtime Error
52" on certain sources when using either ReJig or
"No Compression" settings.
- Fixed an error in which exiting via the Windows "X"
while rebuilding is in occuring could have anomalous
results -- including program lockout.I hope you enjoy this new version of DVD-RB.
jdobbs
1.0 RC2
- Corrected algorithm for seamless branching analysis
and detection. RC1 made some incorrect assumptions
that could result in bad interleaving. This could
also have resulted in several other possible errors
based upon the structure of the source. This might
also be a cause of "Runtime Error 63".
- Fixed an error that was causing a "Runtime Error 9"
when selecting/deselecting an audio or subpicture
stream when no VTS was highlighted.
- Fixed "Runtime Error 6" that could happen when while
interleaving ILVU objects.
- Fixed an error in which the PREPARE phase could get
stuck awaiting a keystroke at the message "Blanking
all EXTRA Segments" when "Movies and Menus Only" or
"Movies and Slideshow Extras" are chosen.
- In response to the "man, that sure is ugly" comments
about the bluish backgrounds used in controls in the
tab areas I have changed them in the Teck Skin and
also added a variable to the Skin definitions called
"v1TextBackground" that can change it. I'd like it
to be clear that Teck was not responsible for that
color choice.
- Enabled the "Remove Dir Comments" function in the
Setup screen and made it functional. Also added it
to the Teck skin's setup. I kinda' forgot about
this on the first RC...
- Fixed error in which display of selected subtitle
and audio streams display was not correctly updated
when changing selected Skin.
- Added set parameters that ensure ILVU compliance as
appropriate when using the HC encoder. This only
affects ILVU segments.
appropriate when using the QuEnc encoder. This only
affects ILVU segments.I hope you enjoy this new version of DVD-RB.
jdobbs
v1.00RC3 der Pro ist raus.
Zitat von jdobbsCHANGES MADE TO PRO VERSION ONLY
- Added "Disable 32K Padding" option to the ISO Output Options dialog box. AnyDVD seems to have a problem mounting discs that have been created using the padding even though it is completely compliant.
- Changed the font color on the ISO Output Options dialog when using the "Teck Original" skin. The previous color was not easily readable.
- Found and fixed the source of "Runtime Error 63" (Illegal Record Number) that could sometimes happen during REBUILD of an ILVU section.
- Fixed a problem in which films that are encoded as 4:3 (within the stream) -- but are displayed as 16:9 (as directed by the IFO) were being set to 4:3 when created in "Movie-Only" mode. Now the setting in the original IFO is retained as the new Movie-Only IFO is created. Strange but true, someone out there is actually authoring commercial DVDs that way.
- Fixed an error in which, under certain circumstances ILVU content that has the same VOBID/CELLID as the last VOBID/CELLID of the previous VTS would not be interleaved properly.
- Fixed an error in which maximum bitrates set for CCE when encoding ILVU could be set too high. ILVU puts more restrictions on maximum bitrate than standard single threaded playback. HC and QuEnc should not have experienced this problem.
- Made further changes to the algorithm for seamless branching reproduction. Corrected problems in the way DVD-RB interpreted the interleaving patterns of some of the more complex ILVU source discs.
- Corrected an error in which, during ILVU rebuild, it is possible that erroneous values could be set into the IFO entry sector.
- Changed the "QuEnc Options" menu to clarify the three modes and also prevent choosing both single pass and OPV simultaneously which is a source of confusion.
- Corrected an error in which "Steal Space from Extras" was sometimes not being disabled when loaded during batch processing.
Cu Rippraff -
Und weiter geht's, die Final rückt immer näher (siehe dazu auch hier), jetzt ist v1.00RC4 raus!
- MAJOR FIX. Corrected an error in which the VTS_C_ADT table was not being properly updated for ILVU sequences. This error may have manifested itself in several different ways depending upon the player or playback software -- but probably would be most noticed using navigation controls. This fix should correct several (most?) reported ILVU backup problems.
- Corrected an error in which Button Over Video (BOV) was not working correctly on ILVU segments that had been reencoded.
- Fixed an error that could cause file sizing errors (VOBs too large) under certain circumstances.
- Fixed an error in which, when the last segment of a VTS is ILVU, the special ILVU.D2V file is not properly closed. This could result in a "missing M2V" file and/or a "Unrecognized exception on Line 6" AVISYNTH error when trying to encode.
- Corrected source of "Runtime Error 380", invalid property value. What an odd one. This was happening when the source had hundreds of stills. The Status window's text box cursor postion became too large for the variable! I've now set a limit on how much of the Status box's history remains available without looking in the LOG file.
- Added code to more accurately account for space used for STILL frames. On DVDs with large numbers for STILL frames (picture playback) the bitrate could be miscalculated because STILLs are extracted intact.
- Modified the display of NTSC bitrates so the actual achieved bitrate (29.97fps) and the ECL file bitrate (23.976fps) are shown. In the past the lower (ECL) rate was displayed and prompted questions as to why it was lower than what might be hand-calculated. The ECL rate is used as part of the method to ensure support for hybrid sources and is readjusted as when
necessary during REBUILD.Cu Rippraff
Jetzt wird die Nummerierung spaßig: v1.00RC4.1 ist raus.
- Corrected an off-by-one sector error in the VTS_C_ADT table of an IFO that contains ILVU sections. This issue was the cause of reported problems importing DVD-RB into DVD Shrink after rebuild. It also caused DVDReMake to sometimes require "recovering sectors".
- Fixed an error in the routine for updating the VTS_TMAPTI table in IFOs containing ILVU sections. In previous versions some seamless branching titles could have had erroneous entries created.
- Fixed "Runtime Error 63" that can be caused by large ILVU (greater than 1GB) segments.
- Added progress bar updates during "Interleaving Video Object" activity.
Cu Rippraff
v1.00 RC5
- Modified the "Layer Break" recognition code to make it
more aggressively find and remove layer-break related
pauses.
- Added option to change Variable Bitrate Bias for HC
Encoder. The default value is 20. This setting can
help keep dark images and fade-ins from pixelating.
This HC encoder just keeps getting better, hat's off
(again) to Hank315.
- Corrected an error that could result in the "File...
shows completed, but no .M2V file exists" on some ILVU
segments during ENCODE phase. A special thanks to
SDragoon for helping to nail this down.
- Fixed "Runtime Error 52" that could occur on some ILVU
segments during PREPARE. Related problem to the "no
MPV file" problem mentioned above. Many thanks to
soupdragon and RaistlinMajere for the excellent beta
testing and support.
- Added "memory" to the Source Directory browse button
so it will start at the last directory used.
- As suggested by MarkRB -- added "Full Backup" as a
choice under the mode menu to make it a little clearer
how to get back out of one ofthe movie-only modes.
Also changed the functioning of "Steal Space from
Extras" in the same way.
- Fixed an error in which exceptionally large ILVU
sequences could cause a "Runtime Error 6" during the
REBUILD phase. This may also have been a source of
other odd behaviour with large sequences. Thanks to
ookzDVD for identifying and helping resolve this issue.
- Fixed an error that could cause OPV prediction to fail
when encoding in ILVU sections. Please note, however,
that while DVD-RB may work in OPV with ILVU sections,
it is NOT recommended that ILVU discs be done in OPV.
Thanks to Acerjen for pointing this out.I hope you enjoy this new version of DVD-RB.
jdobbs
Außerdem hat sich jdobbs zum Erscheinen der Final geäußert, Mitte September 05 soll es soweit sein. Näheres dazu hier.
Cu Rippraff
Version 1.00 RC5.1
- Fixed a glitch in which attempting to overwrite the
"DVDFILES\VIDEO_TS" could result in being asked the
same "Overwrite?" prompt twice.
- Fixed "Runtime Error 63" that could happen on certain
ILVU sections under specific circumstances.
- Fixed "Runtime Error 5" when deleting Batch items
when using one of the non-version-one skins.
- Fixed "Runtime Error 52" that could happen at the end
of the PREPARE phase on ILVU titles that end on with
ILVU section. -
Inzwischen gibt es auch eine neue Free-Version v0.94 (beta)
Zitat von jdobbsZitat von jdobbsCHANGES MADE TO FREEWARE VERSION (since v0.93)
- Now released as a fully installable unit utilizing the Installer created by Rockas.
- Fixed an error that could cause an "Runtime Error 9" upon program start or when loading a Project file when the source path is no longer present.
- Added code to disable path buttons when running any of the three phases. Previously changing any of the Source, Working, or Output paths (either purposefully or accidentally) during execution could cause various errors (including Runtime 54).
- Adjusted the average bitrate for encodes to ensure that the minimum and average bitrates were never the same.
- Added a confirmation note when audio or subpicture defaults are saved from the SETUP screen. Also removed the old screen flags that were incompatible with skins.
- Fixed an error in which ReJig could receive values greater than 100% for its reduction level.
- Fixed an error that could result in "Runtime Error 52" on certain sources when using either ReJig or "No Compression" settings.
- Fixed an error in which exiting via the Windows "X" while rebuilding is in occuring could have anomalous results -- including program lockout.
- Added selection on the MODE menu for HC Encoder. It still works as before (using the QuEnc interface) but can now be more easily selected. You no longer need to set a path as it is must be in the directory created by the installer. Also added HC "Options" menu.
- Fixed the "Make a Donation" and "Rebuilder Web Link" menu options so they will work with Windows 2000.
- Reorganized the QuEnc "Options" menu so it it easier to understand.
- Reorganized the "Steal Space from Extras" menu so it is less confusing.
Das ganze gibt's hier.Cu Rippraff
v1.00 RC6
- Corrected an error in which resetting "Steal Space
from Extras" back to 0% was not taking effect until
the next load of DVD-RB.
- Fixed a bug in which a "Error 0006 -- DVD-RB has
found framecount..." error could occur on very small
segments during REBUILD when selecting the "Movie
- Added an adjustment to maximum bitrate for MPEG audio
streams that are included for processing.
- Corrected an error in which QuEnc versions may not be
identified correctly (shows as UNKNOWN).
- Modified the caption in the "Mode" Menu "Steal Space"
option. It now tells you the reduction percentage
that is selected.
- Changed the code when opening .RBK files. You will
now be prompted as to whether you want to install it
as the default key. If you answer "Yes" -- DVD-RB
will automatically copy and register it. DVD-RB must
be installed first, of course.
- Fixed an error that could, on very rare occasions,
negatively affect the calculated SCR value.
- Tweaked SCR calculation to correct itself for certain
odd circumstances that could occur in the input stream.
Fixes "stutter" that occurs as a result.
- Fixed an error in which ISO label and file names were
not being properly set when loading from a project
file.
- Added code to recognize and attempt to correct system
clock reference (SCR) irregularities in the audio of
the source disc.
- Modified the OPV encoding prediction algorithm so that
it will take fewer passes on each VTS.
- The default Q sample percentage for OPV has been
changed to 2%. Also made the OPV Q selection more
conservative as it was oversizing too frequently.I hope you enjoy this new version of DVD-RB.
jdobbs
Neue Freeversion 0.95 ist raus.
Zitat von jdobbsCHANGES MADE TO FREEWARE VERSION (since v0.94)
- Modified some status routines to ensure compatibility of the INI and INF files between Freeware version and the Professional Edition.
- Fixed an error that could cause ""DVD Rebuilder experienced a buffer overflow. Error #0004.." on some sources.
- Corrected "Runtime Error 75" that could happen at start of rebuild.
- Modified the OPV encoding prediction algorithm so that it will take fewer passes on each VTS.
- Fixed an error that could cause SCR value to "drift" higher over time under some unique circumstances and cause timing irregularities and stutter.
Gibt's hier und wie immer auch hier.Cu Rippraff
Auch mal was Neues: jdobbs gibt das Changelog von Pro Edition Version 1.00 (FINAL) raus, bevor diese erschienen ist.
Morgen (7.10.) soll's soweit sein.
Der Grund ist einfach, soll die letzte Möglichkeit sein, die Zauderer zum Spenden zu überreden. Mehr dazu hier.Zitat von jdobbsBelow is a summary of the changes/updates associated with this version (Pro release):
- Updated the method for one pass encoding prediction for HC encoder. The changes in RC6.0 had a negative impact on the prediction for HC and caused it to require more passes rather than fewer.
- Fixed an error that could cause SCR value to drift over time under some unique circumstances and cause timing irregularities with possible stutter.
- Changed the default value for 32k padding to "off". Also removed the setting from the ISO Options form. While the format is compliant with DVD standards, there are too many 3rd party packages that have trouble reading ISO images with padding. I've decided the benefits are outweighed by the disadvantages. For those purists who wish to enable it anyway -- it can be enabled by adding the line "Enable_32K_Padding=1" in the [Options] area of REBUILDER.INI. The older "Disable_32K_Padding" is now ignored and should be removed.
- Modified HC values to preset GOP size to 12 rather than AUTO for sources that will receive pulldown flags. This is necessary to ensure GOP time length parameters stay within DVD specs.
- Corrected an error that could cause a "Runtime Error 9" during rebuild under certain conditions while processing reencoded ILVU sequences.
- Changed the default state for "Status Logging" to ON.
- Implemented checks to ensure the DVD Volume Label is checked and enforced for maximum length (31 chars).
- Added some updates that will make DVD-RB work more reliably with the output of DVDFab Decrypter.
- Added support for burning ISO images with ImgBurn, Lightning UK's latest burner. Use is automatic, DVD Rebuilder will recognize when ImgBurn is installed and it will be used. DVD Decrypter now becomes the secondary choice for burning.
- Fixed an error in which "Create/Write Project ISO Image" was not properly writing the created image to the blank DVD disc.
- Improved error detection in Write-To-Disc function.
- Enabled a type of "2-Click" mode for those using add-ons following PREPARE. Now you can click REBUILD following a PREPARE and it if ENCODE has not already been performed, it will be automatically executed. It can also be used to RESUME jobs that were stopped during ENCODE.Cu Rippraff
Zitat von jdobbs
To all,
Please -- I posted the release notice yesterday for v1.00 Final and in the post I wroteI posted early purposely to ensure no one would get angry that they weren't warned when the minimum donation requirement goes up.
Please, no more PMs or e-mails.... it hasn't been released yet.
I'm working on a couple of small changes that I think are important to complete before it is released. Hopefully I'll get it done by late tonight (EDT) so I can get it out today....
wurde auf morgen verschoben
Zitat von jdobbsI've changed it to the 8th... getting it finished and mailed today isn't realistic.
Den Hauptgrund hättest Du ja auch posten können... ;D
Zitat von jdobbsI thought I had plenty of time... and then earlier today a windstorm came up and a significant portion of the tree in my front yard ended up on my porch. I've spent most of the day with a chainsaw trying to clear a path to my front door.
Needless to say, I'm not in a very good mood right now. [Blockierte Grafik: http://forum.doom9.org/images/smilies/angry.gif]
:ani_lol: <= obwohl's schon fast etwas gehässig ist, ich fand's trotzdem lustitsch.
Cu Rippraff
das hab ich doch glatt überlesen
Auch nicht schlecht, niemand hat die Final 1.00 erhalten, dafür wird momentan Pro Edition Version 1.01 (Final) verschickt. ;D
ZitatVersion 1.01
- Found and corrected an inconsistency related to the SML_AGLI table that could affect various chapter and searching functions on ILVU sections.
Hatte der abgebrochene Bradford Birnbaum doch sein Gutes...Cu Rippraff
1.02
CHANGES MADE TO THIS PRO VERSION
- Added a new feature under the OPTIONS menu. Now you can select "Audio Track Remapping" and DVD-RB will make changes necessary so that defaults for audio streams can be changed. This is especially useful when DTS is the default and has been removed, or for those who would like the default startup track to be some language other than the original.- Added "Dynamic Peak Analysis" which determines peak bitrates from the original stream and uses the info to set segment maximum bitrates. This should improve quality by more accurately distributing available bandwidth. It should also eliminate some possible sources for playback stutter.
- Fixed a bug in which attempting to apply filters against a source that would already fit on a DVD-5 could halt the batch job waiting for a user prompt.
- Modified the "Shutdown at One-Click Completion" option under the MODE menu. Now it is "Shutdown at end of REBUILD". This was done in order to allow usage with the "2-click" method introduced in the previous release.
- Added ProCoder under the OPTIONS menu and added the ability to set the quality level.
- Fixed "Error 35601, Element Not Found" error that could occur on oddly formatted sources.
- Changed the Installed default operational mode to "One Click." Earlier versions defaulted to "Three Click" mode.
- Corrected setting in which GOP size of 12 was being forced too liberally when using HC encoder.
- Per request, added a new INI parameter that enables the insertion of text in blanked segments. For example, by adding "BlankText=This Video has been Blanked" to the the "[Options]" are of REBUILDER.INI will insert that text on blanked screens. The text has a limit of 40 characters. By default no text is inserted.
- Added bitrate sanity checks for circumstances in which the calculated bitrate might be greater than the original. This can sometimes happen in Movie-Only modes. An analysis of reports of stutter occurring on certain players has determined it is linked to the reintegration of the original audio stream with higher-that-original bitrates. It is possible to override this check (but it is NOT RECOMMENDED) by adding the hidden flag "OVERRIDE_BITRATE_CHECK=1" to the "[Options]" area of REBUILDER.INI.
Neue Free 0.96 ist raus.
Zitat von jdobbsCHANGES MADE TO FREEWARE VERSION (since v0.95)
- Modified code to perform more aggressive detection and removal of layer breaks.
- Improved calling procedure so DVD-RB does not use as much CPU time (leaving more for the encoder).
- Corrected maximum bitrate allocation on NTSC interlaced sources in order to assure adherence to specifications.
- Corrected an error in which source filenames that are a mixture of uppercase/lowercase letters might cause "Error 0003, buffer overflow".
- Updated OPV code to more accurately hit the specified target size on NTSC non-telecined sources.
- Added measures to more accurately measure bitrates in the source stream and then distributes it accordingly in the backup.- Changed the default state for "Status Logging" to ON.
Gibts hier und mittlerweile auch hier.
Cu Rippraff
wie isn das, behandelt die aktuelle pro version auch das menu oder muss man auch damit das ganze erst nochmal durch shrink jagen ?
