neue ScenAid Version released
  • D3s7 hat ScenAid 1.6 released
    Changelog:
    Fixes:
    * Correction to the palette creation code (fixes the incorrect palette issue in dummy assets)
    * Correction to the VTS Menu scanner - was erroring out if no menu existed in the ifo
    * Correction to BoV routines, fixed a few commands in the main routine
    * Correction to the no-cce file detection routine - app was erroring out occasionally when hitting a no-cce file
    Additions:
    * Added ability to create new D2V and AVS files with the DGIndex application suite (not included - manually install into the scenaid install directory)
    * Added ability to script Pre/Post/Cell commands (option is NOT saved currently) - very useful if your removing angles or the like and are having problems w/ ifoupdate/batchifoupdate - instead just copy in the menu files using PGCEdit
    * Added ability to dummy audio in a vobid demux (Use ONLY if you know for sure the audio can be dummied, no checking is done
    * Additional logging/checking done on irregular assets (in the case of ARCOS or th elike) - these seem to be still causing problems
    Changes:
    * Changed the way the BMP creation occurs int he script, should speed up script generation
    * Changed the detection of which encoder will be used and adjusts scripts accordingly
    * Change to the ccedata file creation - no cce assets are no longer written to the files
    * Changed interface to prevent avs playback before AVS is actually loaded
    IMPORTANT NOTE: Scenaid files are now in a subfolder under you demux directory named Scenaid
  • Zitat von Darklistener
    Das feut mich, hatte ich in letzter Zeit öfters mal. :)
    Das hört sich doch richtig gut an... :)
  • D3s7 hat ScenAid 1.7 released
    ScenAid hat jetzt einen VIP bereich wie Numenu4u
    Changelog:
    Fix:
    Error 13 in GenerateTrack
    Fix causing redundant names in the Scenarist Script
    Fix causing Error 6 in ProcessAssets
    Error 5 in BuildChapterLayout corrected
    Additons:
    VIP Mode (A donation of $15.00 or more will get you added to the VIP list - or if you feel you in the past have added to the development of Scenaid, feel free to email me and if I agree you will be added)
    Muxman Script generation (VIP) - full support for muxman 15 or later
    Muxman SUP support (VIP) - creation of .SUP files from the original subtitles allowing for exact reproduction of subtitles
    Muxman Automation (VIP) - full automation now functions in Muxman mode including IFOUpdate routines (BatchIfoUpdate is no longer required) and Sector check
    Changes:
    Ability to force dummy of audio in a vip demux has been improved
    Audio dummy checks have been improved which should avoid issues with odd named files/directories
    IFO Parsing routine updated to allow for scripting of pre/post commands even in dummy PGC's (no PG's)
    IFO Parsing routine updated to allow for poorly authored IFO's with improper information in the tables
    More changes to come
  • D3s7 hat ScenAid 1.7.0.1 released
    Changelog:
    exe only) has been posted the website which resolves the following:
    * Updated framecounter.exe to allow for more accurate counting of no-cce files
    * Correction in the Scenarist .SCP for pre/post/cell naming
    * Removal of support for BatchEncodeM2V (per request from the author - please use latest BatchCCEWS alpha/beta instead)
    * Correction in the Scenaid-ccedata.txt file to accuratly reflect angle assets to BatchCCEWS
    Die Version sollte noch nicht genutzt werden da es noch einen kritischen Fehlergibt und der erst gefixed werden muss. Das Problem is erkannt und der hotfix am testen.
  • Update:
    ScenAid 1.7.0.6
    This includes a fix for subtitles under scenarist
    In einem Land wo die geistige Sonne so tief steht, werfen auch Zwerge lange schatten. :hm:
    Der Mensch hat die Atombombe erfunden. Keine Maus der Welt käme auf die Idee, eine Mausefalle zu konstruieren. Werner Mitsch
    FC-Erzgebirge Aue :cheers:
    Sommerpause(?)
  • ScenAid 1.7.0.7 Update
    .7 is now available for download.
    This finally corrects the subtitles issues with Scenarist (missing
    subtitles) and a couple minor script updates
    "Ist es schon Zeit, um Thaddäus den Tag zu vermiesen?"
