Zeul hat
Scenaid prebeta 1.5 B1 und Beta 1.5 B2 für testers/donators released.
1.5 B1
Fixes/Changes:
Many fixes to the BoV routines - too many to list however it's safe to say the BoV will work 100000x better now (thank you zeul for your knowledge and pointing these out)
CLI changes / fixes to resolve scanning issues
Still / Slide show assets now properly detected / scripted (no change yet for slideshow presentations but encoded stills will be scripted correctly now)
Minor tweaks to the subtitle routines
Minor Script changes
Empty CCEData.txt files no longer cause the system to blow up (however obviously the scenaid-ccedata.txt file can't be created)
Additions:
Preview window for the selected AVI
Bitrate Calculations (Currently the bitrate calcs are VISUAL ONLY - they will not be written to any file, no changes to the selected/unselected assets will be reflected in the script, however it lets you see what the bitrate might be if you remove audio X or clip Y - these changes can be made manually and a rescan done if you wish to apply them)
1.5 B2
Fixes:
bug in the ifo parser causing application to error out if all 32 subtitle streams are in use
bug in the batchcce routine causing application to error out on creating new ccedata.txt file
Changes:
Assets that are less then the minimum allowed frames (12 for NTSC, 10 for PAL) but not Encoded stills (1frame) are now dummied instead of used - these assets were causing scenarist to error out w/ .4sec duration errors on the tracks - I plan on enhancing this routine farther to extract 1 frame from these assets and create them as a slide show (not limited to .4sec) instead
