neue ScenAid Version released
  • Zeul hat
    Scenaid prebeta 1.5 B1 und Beta 1.5 B2 für testers/donators released.
    1.5 B1
    Fixes/Changes:
    Many fixes to the BoV routines - too many to list however it's safe to say the BoV will work 100000x better now (thank you zeul for your knowledge and pointing these out)
    CLI changes / fixes to resolve scanning issues
    Still / Slide show assets now properly detected / scripted (no change yet for slideshow presentations but encoded stills will be scripted correctly now)
    Minor tweaks to the subtitle routines
    Minor Script changes
    Empty CCEData.txt files no longer cause the system to blow up (however obviously the scenaid-ccedata.txt file can't be created)
    Additions:
    Preview window for the selected AVI
    Bitrate Calculations (Currently the bitrate calcs are VISUAL ONLY - they will not be written to any file, no changes to the selected/unselected assets will be reflected in the script, however it lets you see what the bitrate might be if you remove audio X or clip Y - these changes can be made manually and a rescan done if you wish to apply them)
    1.5 B2
    Fixes:
    bug in the ifo parser causing application to error out if all 32 subtitle streams are in use
    bug in the batchcce routine causing application to error out on creating new ccedata.txt file
    Changes:
    Assets that are less then the minimum allowed frames (12 for NTSC, 10 for PAL) but not Encoded stills (1frame) are now dummied instead of used - these assets were causing scenarist to error out w/ .4sec duration errors on the tracks - I plan on enhancing this routine farther to extract 1 frame from these assets and create them as a slide show (not limited to .4sec) instead
  • Zitat von Darklistener
    1.5 B1
    Additions:
    Verstehe ich das jetzt richtig, dass man endlich in ScenAid Tonspuren/UTs abwählen kann?
    "Ist es schon Zeit, um Thaddäus den Tag zu vermiesen?"
  • ja wenn diese einer ins englisch übersetzten kann hätt ich da schon paar ideen.
    erklärt sich jemand zu bereit?
    gruss
  • oha. ganz vergessen den thread.
    dann will ich mal meine sceneaid-wünsche kund tun. schon mal "danke" für die übersetzung. :D
    ich denke dabei im allgemeinen an die positive reauthorist funktionalität.
    - dummy funktionalität
    - das selbst wählen der kompressionsrate etc. zu den einzelnen titeln...
    - bessere übersicht und bedienung
    ich denke die oberfläche vom reauthorist war/ist nahezu perfekt. nun, das wars erst mal.
    gruss
  • Tjo da kann leider keiner mehr was für dich tun weil das ganz oben auf der todo list steht sozusagen. Ansätzte in die richtung sind in den betas schon erkennbar aber ich schätz das das spätestens mit der C fassung des programms vorhanden sein wird.
  • Hat Zeul eigentlich einen Fahrplan wann er die Final von der C-Version veröffentlichen will?
  • tach
    nu wenns in arbeit is oder schon geplant zumindest, reicht mir das vollkommen.
    danke und gruss, olli
  • Scenaid Beta 1.5 B10 wurde für testers/donators released.
    New:
    support for Trahalds BatchEncode
    Option for importing/scanning only forced subs (Great for testing BOV)
    Changes:
    Subtitle engine rewritten (yeah again) - this time much much faster then before
    New "Debug" logging option - scans are faster but less is written to logfile - enable this option if having problems (primarily subtitle logging)
    BoV changes - minor
  • Scenaid Beta 1.5 B16 wurde für testers/donators released.
    Inside the Zip you will find:
    ScenAid.exe
    framecounter.exe (new for counting frames in no-cce files - thanks to Trahald for this when I was drawing a TOTAL blank) - extract w/ ScenAid
    vsrip.exe (lastest build - fixed a fairly large issue w/ BoV) - this goes in the doitfast4u directory
  • D3s7 hatn neuen puplic build von Scenaid released
    ScenAid 1.5 (Build 17)
    Some of the many changes/fixes are:
    * subtitle scanner routines have been completely redesigned resulting in much faster scanning of sst files and more accurate subtitle placement
    * An option to enable/disable detailed subtitle logging has been added- (when disabled, sst scanning is even faster)
    * Highlight/BOV engine has been completely redesigned resulting in more accurate BoV
    * Interface layout has been redesigned and now includes an AVS Preview window, AVS File viewer (soon to be editor), Chapter Location viewer
    * The start of Bitrate / Asset select/de-selection - Bitrate is currently ONLY visual but will allow the user to see what eliminating certain assets will do to the bitrate
    * Support for Trahald’s BatchEncodeM2V has been added
    MANY Fixes have been resolved
    * Audio dummy routines have been updated which will prevent the application error stating "Can't find file"
    * Overall application stability has been improved and now has more detailed logging
    * NO-CCE files are now more accurately scanned resulting in less frame change warnings
    * Support for assets labeled *.AVS-NO-CCE (only seen in newer Doitfast4u builds) has been added
    * Assets that are smaller then allowed sized are now logged and auto dummied - limits the need to manually delete/unselect no-cce files
    A more detailed changelog will be posted on the ScenAid website shortly.
    Current Known issues are:
    * At times cells apparently use different subtitle palettes. Currently Scenarist will error on mux if this found
    * The new Sony Arccos protection is causing issues w/ some disks (so far only the Grudge has been an issue) - a little bit of manual work is currently needed for these disks to work properly
    * If Scenarist 3.0 is used with BoV, it's possible to have issues w/ Highlights if the Stops are removed. This will be very shortly resolved
  • ScenAid 1.5 (Build 20)
    Changelist:
    # Fixes bugs in the BoV routines causing the interface to error out when certain conditions where met
    # Fixed a bug in the interface causing the Layout/Asset bar to disappear
    # Change in the way dummied cells are created - now dummied cells are created as slideshows w/ the duration set to the cell length in the .ifo
  • Scenaid Beta 1.5 B36 wurde für testers/donators released.
    Fixes/Changes:
    More BoV Fixes / Changes
    Fix for audio files w/ odd filenames
    Pal Dummy files recreated for proper PAL AR/File size (I hope)
    Dummy creation is now unique to PGC / Cell - should completely get rid of all the issues w/ palette errors
    Fixes to bitrate calc routine not to error if file isn't found
    Improvments to the scene allocation routines which were causing .4sec errors in Scenarist
    Changes / Additions for proper datafile generation for BatchEncoder
    New features:
    Asset removal now works - limited to removal of video and all assets associated with - removed assets will be dummied per scene
    Bitrate generation now works (Episode movies don't work yet) - please compare the bitrate you get from Scenaid to the one produced by Doitfast4u and/or RA - so far they seem fairly accurate
  • Hi ich habs geändert aber D3s7 meinte auch das er die version vielleicht auch bzw. bald public macht. Kann sein das noch was war das er noch ändert, aber es kommt bald wider n public release also keine sorge :)
  • ScenAid 1.5 (Build 45) public
    Fixes/Changes:
    Audio now dummied by delaycut instead of BeSplit
    New features:
    Bitrate generation now works (Multi-Main movies do not curreently work) - please compare the bitrate you get from Scenaid to the one produced by Doitfast4u and/or RA - so far they seem fairly accurate
    Errors requiring user attention are now logged to a seperate logscreen
