D3s7 hat ScenAid RC3 .25 released
D3s7 Homepage: http://www.sceneaid.com
Direktdownload: http://www.sceneaid.com/download.php?file=7
changelog:
# Fix: Corrected bug in GetRawAV causing type mismatch[/*]
# Fix: Corrected bug in GetSceneFrames causing type mismatch/Type incompatible[/*]
# Fix: Fixed "Batch" launching of Scenarist so that is the only needed option to be checked[/*]
# Fix: Fixed bug with dummy .sst files erroring out the app[/*]
# Change: Modified AudioFix routine to work without delay factor in filename[/*]
# Change: Modified Script routine to use Max/Min/Avg settings from the ccedata file[/*]
# Change: Rewrote CCE routine so Scenaid goes idle while encoding[/*]
# Change: Rewrote VOB/CELL detection routine to correct for broke IFO's[/*]
# Change: Modified CCE file creation routine to more accurately find match[/*]
