ScenAid 0.9.0.26 Released
  • D3s7 hat ScenAid 0.9.0.26 Released
    Build .26 is jetzt zum Downloaden verfügbar.
    Diese Version beinhaltet primäre fixes aber auch ein paar neue features.
    Hoffentlich is das die letzte Version vor 1.0
    Changelog:
    # Addition: Added ability to handle out of order chapters and PG's with no chapter marker
    # Addition: Added ability to use Original Palettes from the ifo instead of just Scenarist Default
    # Addition: Added ability to "Use" original assets... not sure why you'd want this but a few people requested it
    # Addition: Added correction for crossing scene boundry for subs (requires custom vsrip/vsconv)
    # Addition: Added Highlight detection and auto padding for sub streams not demuxed (requires custom vsrip/vsconv)
    # Addition: Added Highlight creation and starts of BoV (requires custom vsrip/vsconv)
    # Addition: Added XP Theme compatibility
    # Fix: Corrected IFO handler bug (should fix error 9)
    # Fix: Corrected bug causing Script generation to error out if BatchCCE isn't installed
    # Fix: Corrected problem with audio routine when parsing filenames with spaces in it - (delaycut didn't like spaces in the name)
    # Change: Modifed ifo handler to correct for poor ifo layouts caused by bad authoring
    # Change: Audio delay routine now purely uses difference in frames from audio -> video and ignores filename
    # Change: Rewrote sub time handlers for better placement for NTSC subs
    # Change: Modified Interface to allow for XP Manifests and better location for info..
    # Change: Modified Automate_Scenarist to allow for better control (should help with lockups)
    # Change: Interface Cleanup / Slight redesign
    Custom versions of VSRIP/VSCONV are also on the website for download... replace the ones that are in the doitfast4u directory BEFORE demuxing your movie
    Link: Scenaid Homepage
  • Hab testweise ne dvd5 demuxed und durchlaufen lassen mit scenarist 3.01 einwandfrei gegangen aber mal abwarten obs irgendwo wider ne vermurckste dvd gibt die nicht will :)
    Kann mir jemand sagen, was damit gemeint ist ? Dieses "Highlight" ist mir nicht ganz klar.
    Arlsair
  • Hi
    auszug aus: Photoshop Menüs
    Das tut hat nicht direkt was damit zu tun aber so einfach und verständlich hat ichs ned hingebracht :)
    Ein DVD Menü besteht im Prinzip aus 3 Ebenen: dem Hintergrund, der sogenannten "Subpicture Overlay" Ebene und einer Highlight Ebene:
    Die Hintergrund-Ebene enthält das komplette Artwork, etwa die grafischen Elemente, die später als "Buttons" dienen sollen. Die "Overlay" Ebene dagegen enthält nur die einfachen Grafiken, die später den Status der Buttons kennzeichnen sollen (ausgewählt, gedrückt, etc.). Die Highlight-Ebene enthält die tatsächlichen "Buttons", also den (unsichtbaren) rechteckigen Bereich, der bei Bedienung mit dem Computer "klickbar" sein wird
