DVD ReBuilder Version 0.57
  • Version 0.57
    ILVU processing has been delayed at least one more version. Below is a summary of the changes/updates associated with this version:
    - Updated code for compatibility with QuEnc 0.52 and above. The KVCD commandline logic has been replaced by the QuEnc Lower Bitrate (QLB) Matrix option. Older versions of QuEnc will no longer be supported and will get an error if use is attempted. QuEnc 0.52+ is free and is easily found on the net.
    - Corrected an error in which the progressive flag was not being set correctly during rebuild when "Deinterlace with Decomb" is selected. Also please note that if the input stream is already identified as progressive, the deinterlacing filter will not be added to the associated .AVS file.
    - Modified SCR algorithm to more accurately reproduce the SCR/PTS structure of the original disc.
    - Made a timing correction that may affect possible audio dropouts. It also may reduce (but not eliminate) the liklihood of encountering an error #0003 or #0004 on preprocessed (3rd party edited) streams.
    - Fixed an error in which the "Disable Interlaced" was correctly reencoding the as progressive -- but was incorrectly reinserting the original flags on rebuild.
    - Add a "Status Logging On" switch to the file menu. When checked, anything that is output to the status box is also echoed to the log file. The file, called "rebuilder.log" is created in the directory specified in "Working Path" -- it no path is specified it is created in the root of the C:\ directory. The file location is changed whenever a new working path is specified (for example when running a batch job). This should be helpful in debugging problems that might cause DVD-RB to exit abruptly.
    download : DVD-RB 0.57
