05/08/16 bugfix release 0.15J
remove audio duration "frame" granularity - improves LPCM muxes
change DBalloc to pre-clear entries.
Muxman - aktuelle Version
Weitere Diskussionen:
Bugfix release 0.15K
properly parse sst file that is missing the final cr/lf
mpeg encoder now multiple pass to avoid STD buffer overflow/underrun________________________________________________________________
05/09/29 Beta 0.16RC2 released
rework add segment and add scene logic05/09/28 First Beta 0.16RC1 released
05/09/27 PTT/PG/Cell radio buttons.
ability to add/remove PTT's within titles on per cell basis.
ability to add/remove programs within PGC on per cell basis.05/09/26 use Wingdings font, if available, for arrow keys
fixed inability to add PGC to empty title or menu05/09/25 compile 0.16p13 available
05/09/24 improvements to default navigation
fixed crash in compositor delete layer function
added Z-axis control in compositor (move layer up/down)
double clicking video file in listbox opens compositor
right click opens popup menu in compositor05/09/23 added ability to add content to PGCs (whole segments only atm)
columns may now be filtered by PGC, title/LU, or domain05/09/22 finished dialog to create a PGC
05/09/16 added chapter (ptt) number to display
ability to delete scene with no references
ability to rename scene with references updated
added create default navigation, delete all navigation05/09/15 ability to add scene to segment
05/09/14 ensure minimum scene duration in spreadsheet
05/09/13 compile 0.16p12
fixed compositor canvas attributes
fixed subpicture pts problem created by restructure of mux305/09/12 spreadsheet reduced to need only 1152 width with large fonts
added "New Project" to "Files"
spreadsheet added domain and title/LU names above PGCs
spreadsheet PGCs are now listed in proper order (sorted by domain, title/LU)
ensure generated time 0 scene name is unique
do not list scenes from segments without video
disallow setting first scene time (always 00:00:00:00)05/09/09 save project was using wrong value for segment display mode (att vice pref)
05/09/08 compile 0.16p11
compositor now supports multiple images and background color selection
The "spreadsheet" display for viewing/changing scenes and PGCs is not fully
functional, but does allow changing scene start time, and has multiple ways
to view the project.05/08/29 mpeg encoder now multiple pass to avoid STD buffer overflow/underrun
05/08/18 added code to handle 32-bit bmp/dib files.
05/08/15 fixed logic to allow empty subpicture streams
05/08/08 started work on scene editor
05/08/06 experiments with AlphaBlend
05/08/05 compile 0.16p10
added delete segment (in "utilities" to prevent accidents)
manual (gui) and automatic (engine) testing05/08/04 added new segment / segment rename dialog
correct error trap for empty segment05/08/03 improve progress bar, add project import progress bar
05/08/01 compile 0.16pi
changed audio duration calculation (to be retrofitted to 0.15)
fixed assets disappearing in gui after compilation
Muxman Homepage -
Muxman: Public//Free ist immer noch bei v0.14G
Muxman: Advanced ist jetzt v0.16.0
Muxman: Alpha ist jetzt v0.17.1 -
5$ (oder waren es 15$?) für 3 Monate Zugang zum Board bezahlen.
Da kann man dann die Sachen downloaden. -
Die kostenlose Version ist jetzt 0.15
Muxman new version 0.15N
ZitatMuxman release notes
06/02/25 bugfix version 0.15N released
fixes problem with GOP < 2015 bytes
http://www.mpucoder.com/Muxman/versions.html
Sawadee Khrap -
Muxman 0.15P
Bugfix ReleaseChangelog(17.03.2006):
- corrected log message "use of extension stream in DVD not implemented." length
- added code to remove extra bytes following sequence_end
- fixed problem with GOP < 2015 bytes
- fixed reference frame pointers for bottom field first field encoded video
- highlight errors were not halting multiplex -
Neue free version Muxman 0.15Q ist raus!
Changelog
Zitat von mpucoder07/02/11 bugfix version 0.15Q released
fixes:- sst parser not closing files, causing too many open files problem
- conversion rule relational operators
- buffer overflow problem in mpeg encoder
- Time map discontinuity flag now set properly.
- time map for titles < 1 second long not formed properly (time_unit not zero)
- corrected window interaction (from 0.16)
Cu Rippraff
Nurmal so: Muxman release notes for version 0.18.6 released
- Database allocation changed to allow for larger data areas, eliminating the need for
- breaking up large items such as highlight data into several slots and the overhead of
- assembling these items for use in the editor. This will drastically reduce the memory
- requirements and startup time for editing segments with many highlights.
- Fixed: .scp was not using timecode type established in data folder for timecodes in the track folder
- .scp now allows use of semicolon prior to frame number in timecodes
aber wartet noch ein bissl, anscheinend ist PAL ein Stiefkind, da stimmen noch ein paar Sachen nicht. Aber wie gut das MPUCoder mich hat
evt. kommt ja bald auch eine neue Freeware Version raus.
Muxman 0.15R release notes
Zitat07/05/05 bugfix version 0.15R released
Fixed:- .scp PAL Video timing (not retrieving tv standard from data folder)
- .scp PAL SubPicture timing (not processing resolution and drop type statements)
- .scp SubPicture duration was 1 frame too long
- .sst parser not clearing generator (and other) flags on entry.
Endlich funkt auch die Import/Remux von VOBs
Zitat07/07/17 bugfix version 0.17.10 released
- Fixed: internal demux of LPCM error
- could create highlight without subpicture
- multiple VobID, CellID, and name/rename entry text boxes were not acting properly
- unable to demux dts streams
ups wir sind ja "bald" bei MuxMan version 1.0 is coming October 1
Edit: jetzt sind wir schon bei: MuxMan version 1.0 is coming October 8
Bis dahin: 07/07/17 - bugfix version 0.18.10 released
* ist im Ausland noch nicht der 1.10.?
------------------------------------------------------------------10.10.2007: will be delayed again
18.10.2007: is coming October 18 < Heute?
07/09/30 bugfix version 0.18.11 suspended due to pending 1.0.0 release
Fixed: saving project would create improper menu navigation if none existedMuxman (Kaufversion) 07/10/22 Version 1.0.0 released
- Adds: Visual editor for setting subpicture conversion rules, color palettes, cropping, and positioning.
- Image files may now be imported via GUI (requires setting conversion rules with above editor).
- Karaoke AC3 files now recognized.
- Karaoke titles can be created, includes Karaoke multi-channel extension mapping.
- Settings tab allows setting:
- Project name
- Provider ID
- Region mask
- Volume
- Number of sides
- Side number
- Drag and drop files onto file manager listboxes
- Visual editing of palettes in RGB or YUV colorspace
- NTSC safe color display shows you what needs to be changed.
- Subpicture effects (fade, cut, and wipe)
07/10/29 bugfix version 1.0.1 released
Adds:- delete subpicture effect
- delete subpicture highlight
- highlight and import adjust color buttons now have upper right corner at 100% opaque, same as effects
Fixed:- subs imported from segment tab or multifile manager not inheriting tv system from video
- area too small for longest button command in button/highlight edit
- do not ask "save highlights" if no changes to highlights
- "select" and "action" buttons not correct color if color other than RGB colorspace
- only one button command saved on exit from highlight editor
- deleting button not always deleting correct PGC menu command
Und neues von MPUCoder:
[*]Version 1.0.2 due to be released Friday, contains updates needed for examples in the User Guide
Habe selber schon Untertitel Animationen erstellt, und finde des echt cool. Besonders bei SlideShows oder bei MusikVideo inc Info Texten.
[*]Work on version 2 has begun. It will not replace version 1, but be a more advanced product with angles and stories.
Na mal sehen, wie oft er das diesmal verschiebt... ;DCu Rippraff
07/12/03 version 1.0.2 released
code cleanup (remove DBlist and DBallocs)
Adds:- delete palette (delete and rename disabled for "DefaultPalette" or any in-use palette)
- context menu for highlight only (no button) in highlight editor plus:
* ability to delete FA and FS
* ability to set the number of numerically selectable buttons
* ability to set forced display in subpicture import adjust
* ability to replace a subpicture with a new image but retain all other values. - SubPicture Fade effect from Scenarist script
- Main window can now be maximized/resized and 2 tabs (spreadsheet and palettes) will resize
Improved:- SubPicture multi-file manager now shows where a subpicture will be in the timeline after making a change to the display time with a colored line. Green indicates no problem with the time, yellow indicates overlap with an existing subpicture, and red indicates the move cannot be made due to highlight information needing to be swapped.
- note: the multi-file manager cannot swap highlights, that is a very complicated change to the data requiring seeking out all commands (menu items) of both highlights from all PGCs.
Fixed:- unable to edit subpictures or highlights with a composite or simple image for video.
- selecting a button cleared auto-action flag for button
- unable to select button unless highlight layer displayed
- moved controls in import adjust panel due to large fonts
- clicking on a button with no move was setting highlight as modified
- button icon and compass not showing links on unmodified highlight
- VM command editor was losing handle to link controls in type 3 editing
- emulation not working correctly for subs other than full size
- disallow immediate compare for JumpTT and JumpVts_TT in VM command editor
- conversion from contrast percentage to contrast number needed rounding up
