ZitatAlles anzeigen
[font=verdana, arial, helvetica]Hello
An updated build is now available:
Bug fix:
Finally found the error that was causing the zipping utility to fail
Critical update to script creation in scenarist 3.0 (dummy highlights were not being created to act as 'holders' for the real highlights)
Critical update to NTSC sub duration written into the script file for scenarist 2.6/7 (incorrect drop frame was being applied)
It has also become apparant that the menu subpics do not always have the stream ID's 0x20 & 21, the code has been changed to reflect this.
Alteration to the internal routines for recalculating the sst timecodes when minimum duration is specified.
A brand new Automate is now available also, which appears to address many of the problems.
http://www.numenu4u.com/NuMenu4u.zip
http://www.numenu4u.com/Automate.zip
Zeul
PS As with all our apps we recommend not naming folders with spaces in them!! so C:\test 1 should be C:\test_1 NB the underscore
[/font]
