[font=verdana, arial, helvetica]Jetzt ist diese Version auch für alle frei zugänglich ;D
Changes :
- Modified the "working" directory selection algorithm so that when the "output" directory is not enabled it will be automatically updated to match that selected as "working"
- Inserted code making any segment of 60 frames or less that is being encoded using Half-D1 outputs in CBR mode. This should eliminate the annoying "cce_encoding_init() failed" error that sometimes occurs.
- Fixed the alignment error experienced in 0.68 on the setup screen when used with skins.
- Modified the default skin used under "Rockas Original" -- Rockas has updated this skin with a little less brilliant colors and a nice textured finish. You will need to select "Rewrite Defaults" under the "Skins" menu for the new skin to take effect.
- Further tweaked SCR calculations. This fix again adjusts the buffer algorithm further in the "less likely to overflow" direction.
- Added capability so that audio selections are now saved in the rebuilder.ini file in a manner similar to that used in project files. This makes it no longer necessary to reset your audio choices any time you stop and then restart DVD-RB.[/font]
