DGMPGDec von Donald Graft - aktuelle Version
  • DGMPGDec Version 1.4.4 Beta 3
    Here is version 1.4.4 beta 3. It has these changes:
    * The DGIndex INI file is now always loaded from, and saved to, the same directory that contains DGIndex.exe.
    * The error message for bad D2V opening has been broken into four to make it easier to troubleshoot: D2V file is empty, DGIndex/DGDecode mismatch, cannot open one of the source files listed in the D2V file, and source stream has no sequence header.
  • DGMPGDec Version 1.4.4 Beta 4
  • DGMPGDec Version 1.4.4 RC1
    * "Decode AC3 to WAV" was totally broken for tracks 2-8 (1 was OK). This
    has been repaired.
    * Fix D2V is now run automatically and the D2V file is repaired (instead of saving the correct D2V file in *.d2v.fixed). The bad version is saved in *.d2v.bad. See the reference manual for details.
    * The right arrow key can now be used to single step in play/preview mode if the playback speed is set to Single Step (previously just the right arrow button worked).
  • Version 1.4.4 RC 2
    * A deficiency in the implementation of pulldown in DGDecode was repaired.
    The result is that decoding is now resilient to changes of field order. This
    makes Fix D2V superfluous, so it has been removed.
    * Colorimetry was reported incorrectly for MPEG2 in some cases. This has been fixed.
    Doom9-Thread
  • DGMPGDec 1.4.5 Final
    A major bug in version 1.4.4 was found. Random access with multiple elementary stream files loaded was brain-dead. This is fixed in version 1.4.5. That is the only change.
    http://neuron2.net/dgmpgdec/dgmpgdec.html
  • Zitat von neuon2
    Here is 1.4.6 beta 1.
    1. Fixed a bug in indexing for some field structure streams.
    2. The 'This I picture starts a new GOP' flag in the D2V file was not being
    set correctly. This flag is not used by DGDecode, so the impact was only to
    the diagnostics produced by Parse D2V.
    3. The D2V file format version number was bumped to 12. (This should have
    been done for version 1.4.5; better late than never.)
    Doom9-Thread
  • Zitat von neuron2
    * Fixed a problem in DGDecode that could cause a lockup when navigating
    on the timeline with some unusual field structure streams.
    * Increased the maximum number of input files from 256 to 512.
    * Incorporated fix to DGVfapi (by 'tritical') that prevents a failure when
    a large number of VFAPI-served files are opened at once.
    Doom9-Thread
  • DGMPGDec Version 1.4.6 Beta 3
    Beta 4 fixes a problem in setting of the frame rate in Avisynth by DGDecode (merging error when absorbing tritical's fix).
    Doom9-Thread
    * DGVfapi's handling of audio from avisynth scripts was fixed. It didn't set
    values for dwBlockAlign and dwReadedSampleCount, and it should be
    converting the output to 16-bit integer if it isn't already in that format.
    Changes by 'tritical'.
    * The old "Fix D2V" tool is back in a new guise: the "Correct Field Order"
    option. Refer to the manual for details.
    Quelle: http://forum.doom9.org/showthread.php?p=772269#post772269
  • DGMPGDec 1.4.6 Final
    Fixed a problem that limited the number of files that could be opened at
    once from the File Open Dialog (drag-and-drop to the DGIndex window was
    OK). It should now be possible to open up to 512 files at once via the open
    dialog.
    http://forum.doom9.org/showthread.php?t=101159
  • DGMPGDec 1.4.7 beta 1
    This version allows the user to specify different AVS templates for AVS script generation (or to disable AVS script generation)
    http://forum.doom9.org/showthread.php?t=107731
    * Fixed -AT problem in CLI.
    * Made the transport stream detection more robust against spoofing by video data.
    Doom9-Thread
  • Zitat von neuron2
    DGMPGDec 1.4.7 beta 4:
    * The quants log now includes the frame numbers at which the matrices appear.
    * Fixed garbage in the file list caused when hitting the Up button with an empty list.
    * Fixed bug in AVS template support that caused paths with spaces to fail.
    Doom9-Thread
  • Zitat von neuron2
    DGMPGDec 1.4.7 beta 5
    * Added a new option called Use Full Paths. When enabled, behavior is as it always has been. When disabled, only file names (not full paths) are used as references in the D2V and generated AVS files. This makes it easier to move project files.
    This new option was contributed by Christian Eberl. Thank you, Chris!
    * Changed the exception handling in DGIndex. Previously an exception would abort the entire preview or save project operation. Now only the current picture decoding is aborted.
    Post und download bei Doom9.org
    Cu Rippraff
    Blumige Grüße, Rippraff
