This version adds the PCR (for transport streams) and SCR (for program streams) to the 'Log Timestamps' dump. The PID detection/setting dialogs now allow for the specification of the PCR PID for transport streams.
DGMPGDec von Donald Graft - aktuelle Version
* DGIndex can now automatically set the PIDs on file open for streams that lack PAT/PMT tables. If the PAT/PMT tables are absent, DGIndex falls back to using raw PID detection and sets the first audio and video PIDs seen in the stream.
update auf beta 7
Doom9 -
* The __aud__ variable in the AVS template now uses the first audio track found instead of the last.* 204-byte transport packets are now supported.
* The info dialog now includes a stream type field.
* An error popup now appears if frame repeats are encountered (only field repeats are currently supported).
* If an exception occurs during processing, a message box pops up and allows the user to choose to continue or to abort.
* The D2V file version is bumped to 15.
* The AVS template path now defaults to a file called "template.avs" in the same directory as DGIndex.exe.
* Fixed a bug in INI file loading that caused some parameters to be read incorrectly.
* An error popup now appears if the user attempts to execute "Demux Audio Only" when the audio method is set to "Decode AC3 Track to WAV".
* Fixed a bug in relative path handling that crashed DGIndex when "Load Project" was performed.
* Revised the track selection interface to be more user friendly.
* Added preliminary support for frame repeats. These are increasingly being found in 720P streams. Now you can process these videos through DGDecode/Avisynth with proper audio/video sync.
Zitat von neuron2
This version now correctly renders the video within DGIndex for streams with frame repeats. Also, Field Operation=Raw is now supported for such streams.
Edit:
ZitatBeta 11 is withdrawn. Standby for the fixed version.
Beta 11 ist verbuggt, erstmal auf fix warten, oder Beta 10 benutzen... -
* This version now correctly renders the video within DGIndex for streams with frame repeats. Also, Field Operation=Raw is now supported for such streams.
* Added two new fields to the info dialog: number of frame repeats, and number of field repeats.
http://forum.doom9.org/showthread.php?p=939789#post939789
Gruß,
7ven -
There's a problem with beta 12 and frame repeats. It's erroneously kicking in the field order correction. I included a check for that but it isn't working right. So turn off the Correct Field Order option when your stream has frame repeats. I'll fix that tonight.
Problem mit frame repeats --> auf Bugfixrelease warten
* The Correct Field Order option is removed and the field order correction function is now available through the Tools menu: Fix D2V. I did this because this correction should not be applied to streams with frame repeats, and trying to prevent it via a code check runs into technical complications.
* A first attempt has been made to add a progress percentage field to the DGIndex window title bar.
* When in CLI mode, DGIndex no longer grabs the foreground focus and beeps at the end of a Save Project operation.
* Fixed a bug in the LumaYV12() filter (part of DGDecode) that could cause a crash in some circumstances.
Zitat von neuron2
* Adding checking for audio file names to not be already open in another application before trying to demux to them.
* Added a new tool in the Tools menu: Analyze Sync.
* Revised the indexing code to support the case where an indexed unit (especially packs) might contain more than one I frame. Previously random navigation in DGDecode failed for this rare scenario.
* D2V file format is bumped to 16.
http://neuron2.net/dgmpgdec/dgmpgdec149b14.zip
* Fixed a bug that caused DGIndex to sometimes use 601 colorimetry in the preview window and when doing Save BMP when 709 should have been used. The Info Dialog was correct, however.
* Added support for M2TS (Blueray Disk) files.
* Fixed incorrect audio demuxing for M2TS files. At this time AC3 is known to be good. All other formats are untested but may work.
Changelog DGMPGDec 1.4.9 RC1
- The reporting of matrix coefficients was off by one GOP so if they changed, one GOP would be reported wrongly. Fixed.
- Multiple __vid__ and __aud__ per line are now supported.
- Audio-only demuxing of LPCM audio was fixed.
- Making a range that cuts from the start failed for some program streams. Fixed.
Changelog DGMPGDec 1.4.9 RC2
ZitatOK, guys, this is feature cutoff for 1.4.9. Bug fixes only until final release, please.
- Added support for demuxing LPCM from M2TS ([Blockierte Grafik: http://technik.movie2digital.de/alink.gif] Blu-ray) files. Note that the raw PCM is demuxed (same as xport.exe). You must use an audio processor, such as sox.exe, to repackage it as you want it (typically as a WAV file). Refer to the DGIndex Users Manual for instructions in that regard (Audio/Output Method section). PID detection and the Info dialog are supported for this new audio type. Thanks to drmpeg for showing the way with xport.exe.
- Added a warning pop-up to notify the user that a field order transition was detected.
DGMPGDec 1.4.9 Final
Here is DGMPGDec 1.5.0 beta 1:
* Pop-up warning message boxes are now suppressed for CLI operation.
* PSIP PID detection has been added.
* PIDs are now displayed in decimal as well as hexadecimal.
* A new option, Looped Playback, was added. When the end of the timeline is reached during a Play or Preview operation, playback is automatically restarted at the beginning of the timeline.
* A bug was fixed in the transport packet length detection code. This caused some M2TS streams to be parsed incorrectly.
* The file type .m2t was added to the open dialog.
* Some array sizes were increased to prevent crashes in the debugger.
* The next_start_code() function was enhanced to add error resiliency for abnormal slice terminations.
* Because the code never writes to the DirectDraw surface anymore (removed long ago!), the DirectDraw Overlay option was removed. DGIndex now never seizes the overlay.
* When the Use Full Paths option is turned off, relative paths are used. This allows for the source files to be in a different directory than the D2V file. If they are in the same directory, the behavior is the same as before.
* In CLI mode, if a field order transition is detected, it is silently corrected.
* Fixed two problems with .m2ts files: 1) audio on PRIVATE_STREAM_1 was not processed correctly, and 2) video demuxing was broken.
