DGMPGDec von Donald Graft - aktuelle Version
  • * Fixed a problem with PSIP PID detection that could cause programs to be missed.
    * Fixed a problem that resulted in an abort of processing with the message box popup "Force film mode not supported with frame repeats".
    * Fixed a problem that caused the file open dialog to fail for some earlier versions of Windows. I didn't include this in the formal change list because it was exposed by a change in beta 2 (increased size of internal buffers!), so it is not present in version 1.4.9.
    http://neuron2.net/dgmpgdec/dgmpgdec150b5.zip
    Doom9
  • * Removed the limitation that the AVS and D2V files must be in the same directory when the Use Full Paths option is disabled. Thanks to Rainy for showing the way.
    * Restored the default setting of the Use Full Paths option to enabled for backward compatibility with third-party applications. If you turn this off, you are expected to know what you are doing. :)
    http://neuron2.net/dgmpgdec/dgmpgdec150b6.zip
    Doom9
    • The infamous GOP warning popup has been consigned to the dustbin of history. The D2V Parse log now shows the open/closed status of the GOPs, so if you need to know if your opening GOP is open, look there.
    • The Info dialog position is no longer pegged to the main DGIndex window. It can be independently positioned and its position is saved and restored via the INI file.
    http://neuron2.net/dgmpgdec/dgmpgdec150b8.zip
  • Version 1.5.0 beta 9
    Zitat von neuron2
    * An option was added to control how HD videos are displayed. You can now shrink by half (the previous behavior) or you can view any quadrant of the video. This allows the interlace structure of HD videos to be inspected.
    * The font size of the Info dialog was reduced so that it all stays visible with the new vertical arrangement.
    http://neuron2.net/dgmpgdec/dgmpgdec150b9.zip
    The INI file was changed again, so open DGIndex and then close it the first time you use it.
    Version 1.5.0 beta 10
    Zitat von neuron2
    sorry about the quick update, but the fix for emulated audio headers was rejecting some valid headers. I'm pretty sure everything is fully correct now.
    http://neuron2.net/dgmpgdec/dgmpgdec150b10.zip
    Doom9
  • * Fixed a problem that caused DGIndex to miss some audio streams. For example, if AC3 substream 0x80 was present, and MPA stream 0xC0 was present, both would be viewed as Track 1, and only the first one encountered would be detected. The concept of track number is removed (as it is a DVD-specific construct), and it is replaced with the concept of audio id. See the users manual for details.
    * For MPEG audio streams, the Info dialog now shows full information: audio id, layer, number of channels, sampling rate, and bitrate. This information is also included in the filename of demuxed MPEG audio sreams.
    http://neuron2.net/dgmpgdec/dgmpgdec150b11.zip
    This was a major redesign of audio processing so please beat up on anything audio related and try to break it.
    To avoid possible hassles, delete your DGIndex.ini file before running this new version.
    Doom9
  • weiter gehts:
    * Whenever the Info dialog is closed, a log file is created that contains the same information. This may be invoked by the CLI to silently query the nature of the input file. Please see the users manual for details.
    * When a stream does not declare the colorimetry, matrix_coefficients=1 is assumed for HD video and matrix_coefficients=5 is assumed for SD video.
    http://neuron2.net/dgmpgdec/dgmpgdec150b12.zip
    I'll wait and see who cries foul about the second bullet item. I'd prefer not to make an option for it.
  • * Fixed problem whereby the automatic PID setting for transport streams used the last audio stream encountered instead of the first.
    * Added an MRU list to the File menu.
    http://neuron2.net/dgmpgdec/dgmpgdec150b13.zip
    This version also contains a new feature. The first person to find it gets a brownie point. Then I will add it to the change list. Just for some fun!
    Doom9
    • Leading B frames for field structure streams were not counted correctly, causing a possibility to display bad starting frames when serving with DGDecode. Fixed.
    • Fixed possible crashes when exiting DGIndex while a play/preview is in progress.
    • DGIndex no longer beeps and brings its window to the foreground when a Save Project operation is complete.
    • Fixed minor bugs in the MRU list handling.
    • The quants displayed by DGDecode's showQ=true did not match the avg/min/max values displayed for info=1 (the showQ display was not re-ordered for display order). Fixed.
    • Only half a screenful of values were shown with showQ=true for field structure streams.
    • The funny transparency for the showQ display was fixed.
    http://neuron2.net/dgmpgdec/dgmpgdec150rc1.zip
    This is a release candidate, so this is the last call for bug reports!
    • Fixed a regression in RC1 for field structured streams that could cause a hang in DGDecode.
    • The Info display now shows the picture coding type (I/P/B).
    • Added an option to enable/disable the automatic log file generation (default is enabled).
    • Added a maximum bitrate field to the Info display.
    http://neuron2.net/dgmpgdec/dgmpgdec150rc2.zip
  • Doom9
    http://neuron2.net/dgmpgdec/dgmpgdec150rc3.zip
  • doom9
    http://neuron2.net/dgmpgdec/dgmpgdec.html
  • Version 1.5.0 RC5
    * The Full Paths option is now honored for CLI invocation.
    * Fixed the audio delay calculation, timestamps dump, and analyze sync tool for streams that do not contain GOP headers.
    * The analyze sync tool now prompts for the audio ID instead of a track number.
    * Fixed incorrect audio demuxing when demuxing audio only.
  • 1.5.8
    DGMPGDec 1.5.8
    Changes from version 1.5.7
    1. Fixed a problem that caused DGIndex to crash with some pathological streams.
    Die Version ist jetzt nicht ganz frisch (März 2010), neu ist allerdings das hier:
    Version 1.5.8 is the latest full released version. Note that binaries are no longer provided due to potential MPEGLA licensing liabilities. You'll have to build it yourself, or find binaries elsewhere.
    akapuma
  • Auf der von neuron2 empfohlenen Downloadseite habe ich etwas neues entdeckt:
    Here's an optimized DGMPGDec version compiled by Groucho2004, modified source code is included
    You need SSE (or higher) to run this version, this means > Intel P3 or > AMD K8
    Die optimierte Version basiert weiterhin auf der 1.5.8.
    akapuma
  • Changelog in der "Version History":
    DGMPGDec 2.0.00
    Changes from version 1.5.8
    1. Rebuilt with Visual Studio 2019.
    2. A 64-bit executable of DGDecode is now included (derived from fork by Asd-g).
    3. DGDecode now works with Avisynth 2.6 and Avisynth+.
    Changelog im Forum:
    DGMPGDec 2.0.0.0 / 23.12.2020:
    * Fixed bug in DGIndex regarding AC3 demuxing that could cause a hang.
    * Added Vapoursynth support for 64-bit DGDecode.
    DGMPGDec 2.0.0.1 / 08.01.2021:
    * Fixed decode crash with 64-bit DLL in Vapoursynth mode when stream has RFF flags. The UV pitch was getting set wrong.
    DGMPGDec 2.0.0.2 / 12.01.2021:
    * Performance improvement for DGIndex.
    DGMPGDec 2.0.0.3 / 19.01.2021:
    * For DGIndex, implement message box timeouts and error return values for CLI.
    * The legacy CLI syntax is removed. Only the Unix-style CLI is now supported.
    DGMPGDec 2.0.0.4 / 12.02.2021
    * Removed defunct link to jackei's web site in DGIndex.
    * Fixed the non-AVS interface for the 32-bit DGDecode. This fixes GordianKnot and other apps that use the non-AVS interface.
    Download
    akapuma
    Licensing (DRM) has been removed from DGDecNV and DGDemuxGUI/DGDemux. They will remain closed source for now. The executables remain copyrighted and may not be redistributed without written permission.
    see: https://forum.doom9.org/showthread.php?t=182778
    NICE! Die tools gibt's bei http://rationalqm.us/mine.html
