- Fixed an error that causes CCE SP V2.50 to create an incorrectly
formatted .ECL file and fail in the encoding phase under certain
circumstances.
- The GOP size for NTSC material that is not from a FILM source has
been changed to default to 15 frames (rather than 12). This should
improve quality at a given bitrate on NTSC sources that are
interlaced and should be especially useful on episodic discs of
television shows.
- Made a correction to the quality prec value for CCE v2.70. The
scale has been changed (again) in this CCE version. The scale is
again set to 0-100.
- Updated the SETUP and ABOUT screens with new images provided by
Rockas. Now there is more room available for viewing paths in the
"Rockas Original" SETUP screen. You must select "Rewrite Defaults"
under the SKINS menu for this change to take effect.
