In letzter Zeit gab es eine neue Version plus ein paar kleine Bugfixes.
<0.9.1.6n c>
- Fixed - quality characteristic and bias setting written properly for all cce versions.
<0.9.1.6n b>
- Fixed - can handle ccedata.txt files with more than usual amount of chapters. (note that the ecl will contain all the chapters that are in the ccedata.txt but cce will only honor the first 128 or so chapter locations)
<0.9.1.6n>
- Fixed - Auto bias now tied to the dropdown edit for average instead of the average spin control (which was removed in 0916m)
- Added - Tweaks for the gui stuff from 'm'. Option to disable the gradient background. also added more numeric selections for the quality, qfactor, and bias dropdown to cover a greater precision of number options.
