Blaue Gesichter!
  • Seeigel du scheinst mir helfen zu können. Kannst du mir vielleicht alles ausführlich darstellen wie ich vorgehen muss. Bitte wäre cool von dir. Ich bin kein Profi wie ihr sondern nur ein Anfänger!
  • Hier die ganze DVD2SVCD.ini
    [Settings]
    XPos=0
    YPos=0
    UseDVDRip=0
    UsevStrip=0
    UseInternalRip=1
    Save diskspace=0
    iDCT=0
    DVD2AVI Pause=0
    WavConv=5
    BitRate=9
    tooLame Mode=0
    Autodetect Azid Gain=1
    NoOfpasses=4
    CCE Image Quality=17
    CCE Anti noise value=2
    CCE Anti noise=0
    CBR=0
    One Pass VBR=0
    Multi Pass VBR=1
    Dont Delete Files=1
    Create VAF=1
    QFactor=5
    Linear quantizer scale=1
    Zigzag scanning order=1
    Use2Streams=0
    Pri1Audio1=28
    Pri1Audio2=-1
    Pri2Audio1=-1
    Pri2Audio2=-1
    Sub1=-1
    Sub2=-1
    Sub3=-1
    Sub4=-1
    Sub5=-1
    Sub6=-1
    Sub7=-1
    Sub8=-1
    Azid Gain Offset=6
    Rip subtitles=0
    Min. Delay. Between Subtitles=100
    SVCD subtitles=1
    Permanent subtitles=0
    PAL Y-Pos=-1
    NTSC Y-Pos=-1
    MinsHigh1=50
    MinsHigh2=76
    MinsHigh3=100
    MinsHigh4=125
    MinsHigh5=163
    NumCd1=1
    NumCd2=1
    NumCd3=2
    NumCd4=2
    NumCd5=3
    NumCd6=3
    CDSize 1=740
    CDSize 2=800
    CDSize 3=740
    CDSize 4=800
    CDSize 5=740
    CDSize 6=800
    MaxBitrate=2530
    MinBitrate=300
    MaxAvg=2230
    MinAvg=1600
    Adjust Audio Bitrate=1
    Use Min. Avg.=0
    Force Film=0
    Movie Offset=2
    CDOverlap=2
    Data Preparer=dvd2svcd
    Use I-Author=0
    Use VCDImager=0
    No images=0
    Use VCDXBuild=1
    Length of Chapters=60
    Use TitlePicture=1
    Use ChangeCD Picture=1
    Avisynth Bicubic b Value=0
    Avisynth Bicubic c Value=0.75
    SmartDeinterlace Mode=2
    SmartDeinterlace Treshold=10
    SmartDeinterlace Denoise=1
    SmartDeinterlace Blend=0
    SmartDeinterlace Fast=1
    Edit Avisynth Script file=0
    UseAVI2SVCD=1
    UsePVA2SVCD=0
    UseDVD2SVCD=0
    UseCDOverlap=1
    FirstRun=0
    Use CDMage=0
    RunPerCDImage=0
    RunFinal=0
    RunPerCDImage Params=
    RunFinal Params=
    bbMPEG videoDelay Adjustment=180
    bbMPEG audioDelay Adjustment=180
    bbMPEG audio1Delay Adjustment=180
    Use MPEGAV=0
    FixedChapters=1
    DVDChapters=0
    ForceIAuthorSupport=1
    TMPGEnc Rate Control Mode=2
    ResizeMethod=2
    Auto Intra DC=1
    DC component precision=0
    Avisynth Setup=BicubicResize
    Frames pr spread=25
    Spread=100
    CCE Timecode=01:00:00:00
    Prediction Size=0.95
    UseMPEG1=0
    UseMPEG2=1
    Convert to Canopus codec=0
    Convert to Divx4=0
    Use Frameselection=0
    New Default Folder=0
    DVD2SVCD Level=0
    Eject DVD=0
    Luminance Gain=0
    Luminance Offset=0
    Audio1Downsampling=1
    Audio2Downsampling=1
    Audio1BitRate=9
    Audio2BitRate=9
    Folder Structure Source=
    Folder Structure Video=
    Folder Structure Audio=
    Folder Structure Muxed=
    Folder Structure Subs=Subs
    Intra=8,16,19,22,26,27,29,34,16,16,22,24,27,29,34,37,19,22,26,27,29,34,34,38,22,22,26,27,29,34,37,40,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,58,26,27,29,34,38,46,56,69,27,29,35,38,46,56,69,83
    NonIntra=16,17,18,19,20,21,22,23,17,18,19,20,21,22,23,24,18,19,20,21,22,23,24,25,19,20,21,22,23,24,26,27,20,21,22,23,25,26,27,28,21,22,23,24,26,27,28,30,22,23,24,26,27,28,30,31,23,24,25,27,28,30,31,33
    Matrice Preset=
    Use deafult Matrice=1
    LFEDownmixLR6Ch=-3
    LFEDownmixLFE6Ch=0
    CenterDownmix6Ch=0
    SurroundDownmix6Ch=0
    DynamicCompression6Ch=1
    StereoDownmixType6Ch=0
    RearChannelFiltering6Ch=0
    DialogNorm6Ch=0
    LFEDownmixLR2Ch=-3
    LFEDownmixLFE2Ch=0
    CenterDownmix2Ch=-1
    SurroundDownmix2Ch=-1
    DynamicCompression2Ch=1
    StereoDownmixType2Ch=0
    RearChannelFiltering2Ch=0
    DialogNorm2Ch=0
    No Audio Conversion=0
    Flip Vertival=0
    Add ResampleAudio=1
    Resize To=0
    Use CCE=0
    Use TMPGEnc=1
    Use ProCoder=0
    ProCoder CBR VBR Type=2
    ProCoder Quality=3
    ProCoder Field Order=2
    Procoder Close GOPs=0
    ProCoder Frames In GOP=15
    ProCoder Distance IP=0
    Procoder Use Sequence Header=1
    ProCoder Picture Structure=1
    Procoder DC Precision=1
    CCE Safe Mode=0
    RoBa Multi Pass=0
    RoBa Visibel=0
    CCE Bias=20
    CCE Field Order=2
    Progressive=1
    DVD Compliant=0
    Restrict auto I frame insertion=0
    Close all GOPs=0
    Intra DC=2
    M GOP=3
    MN GOP=5
    SEQ Header=1
    Constrained Parameter Set=1
    TMPGEnc Motion search precision=4
    TMPGEnc Field Order=2
    TMPGEnc Num of passes=2
    OffsetFixed CQ Value=80
    OffsetFixed CQ_VBR Value=25
    Use fixed CQ Value=0
    Output YUV data as Basic YCbCr not CCIR601=0
    Use floating point DCT=1
    No motion search for still picture part by half pixel=1
    Soften block noise=0
    Soften Intra=35
    Soften NonIntra=35
    TMPGEnc GOP I Pictures=1
    TMPGEnc GOP P Pictures=4
    TMPGEnc GOP B Pictures=3
    TMPGEnc SEQ Headers=1
    TMPGEnc Max frames in GOP=0
    TMPGEnc Close GOPs=0
    TMPGEnc Detect Scene Change=1
    Enabled Padding=0
    TMPGEnc VBVBuffer=0
    Use CCE Template=0
    CCE Template=
    SubOutputPalette0=clBlack
    SubBlendPalette0=0
    SubOutputPalette1=clWhite
    SubBlendPalette1=15
    SubOutputPalette2=$001E1E1E
    SubBlendPalette2=15
    SubOutputPalette3=clGray
    SubBlendPalette3=15
    Resize Subtitles=100
    CVD subtitles=0
    External PAL Y-Pos=480
    External NTSC Y-Pos=400
    SubStreamIDOffset=1
    External Subtitle Font Name=Verdana
    External Subtitle Font Size=18
    External Subtitle Font Style=0
    bbMPEG MPEG1=0
    bbMPEG VCD=0
    bbMPEG MPEG2=0
    bbMPEG SVCD=1
    bbMPEG DVD=0
    bbMPEG VBR=1
    bbMPEG Pad VCD=0
    bbMPEG Write PEC=1
    bbMPEG Add Scan Offsets=1
    bbMPEG Align Sequence Headers=1
    bbMPEG Use Private Stream 2=0
    bbMPEG Computed Bitrate=1
    bbMPEG TimeStamps=0
    bbMPEG Pulldown=2
    bbMPEG MuxRate=0
    bbMPEG Pack Size=2324
    bbMPEG Packets Pack=1
    bbMPEG Video Buffer=230
    bbMPEG Audio 1 Buffer=4
    bbMPEG Audio 2 Buffer=4
    PBCType=0
    Use LastCD Picture=0
    Use EntrySVD=0
    Save XML=1
    Save Movie Info=1
    ProcessPriority=1
    Automatic Shutdown=0
    [Executables]
    vStrip Executable=C:\Programme\DVD2SVCD\vStrip\vStrip.exe
    DVD2AVI Executable=C:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.exe
    SubMux Executable=C:\Programme\DVD2SVCD\WinSubMux\WinSubMux.exe
    Pulldown Executable=C:\Programme\DVD2SVCD\pulldown\pulldown.exe
    BeSweet Executable=C:\Programme\DVD2SVCD\BeSweet\BeSweet.exe
    MPEG51 Executable=C:\Programme\DVD2SVCD\MPEG5.1\pub_enc.exe
    bbMPEG Executable=C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe
    VCDImager Executable=C:\Programme\DVD2SVCD\VCDImager\VCDImager.exe
    VCDXBuild Executable=C:\Programme\DVD2SVCD\VCDImager\VCDXBuild.exe
    Title Picture=C:\Programme\DVD2SVCD\DefaultTitlepicture.bmp
    Change CD Picture=C:\Programme\DVD2SVCD\DefaultChangeCD.bmp
    Last CD Picture=C:\Programme\DVD2SVCD\DefaultLastCD.bmp
    PVA Executable=
    CDMage Executable=
    RunPerCDImage Executable=
    RunFinal Executable=
    VFAPI Executable=C:\Programme\DVD2SVCD\VFAPI\Reader\VFAPIConv-EN.exe
    ProCoder Frameserver Executable=C:\Programme\DVD2SVCD\VFAPI\Reader\VFAPIConv-EN.exe
    MadPlay Executable=C:\Programme\DVD2SVCD\MADPlay\madplay.exe
    AVS2 MPG2Dec DLL=C:\Programme\DVD2SVCD\Avisynth2 Plugins\Mpeg2dec\mpeg2dec.dll
    AVS2 Dividee MPEG2Dec=C:\Programme\DVD2SVCD\Avisynth2 Plugins\Mpeg2dec\mpeg2dec.dll
    AVS2 InverseTelecine DLL=C:\Programme\DVD2SVCD\Avisynth2 Plugins\InverseTelecine\decomb.dll
    AVS2 Subtitle DLL=C:\Programme\DVD2SVCD\Avisynth2 Plugins\Avisynth Subtitler.dll
    AVS2 BMP Loader DLL=C:\Programme\DVD2SVCD\Avisynth2 Plugins\Avisynth BMP Loader.dll
    AVS2 SimpleResize DLL=C:\Programme\DVD2SVCD\Avisynth2 Plugins\SimpleResize\SimpleResize.dll
    AVS2.5 MPG2Dec DLL=C:\Programme\DVD2SVCD\Avisynth2.5 Plugins\Mpeg2dec\mpeg2dec3.dll
    AVS2.5 Dividee MPEG2Dec=C:\Programme\DVD2SVCD\Avisynth2.5 Plugins\Mpeg2dec\mpeg2dec.dll
    AVS2.5 InverseTelecine DLL=C:\Programme\DVD2SVCD\Avisynth2.5 Plugins\InverseTelecine\decomb.dll
    AVS2.5 Subtitle DLL=C:\Programme\DVD2SVCD\Avisynth2.5 Plugins\Avisynth Subtitler.dll
    AVS2.5 BMP Loader DLL=C:\Programme\DVD2SVCD\Avisynth2.5 Plugins\Avisynth BMP Loader.dll
    AVS2.5 SimpleResize DLL=C:\Programme\DVD2SVCD\Avisynth2.5 Plugins\SimpleResize\SimpleResize.dll
    CCE Executable=
    TMPGEnc Executable=C:\Programme\Pegasys Inc\TMPGEnc Plus 2.5\TMPGEnc.exe
    ProCoder Executable=
    I-Author Executable=
    [Folders]
    vStrip Folder=C:\Programme\DVD2SVCD\Movie
    DVD2AVI Folder=C:\Programme\DVD2SVCD\Movie
    Audio Folder=C:\Programme\DVD2SVCD\Movie
    CCE Folder=C:\Programme\DVD2SVCD\Movie
    Pulldown Folder=C:\Programme\DVD2SVCD\Movie
    Subpictures Folder=C:\Programme\DVD2SVCD\Movie\subs
    bbMPEG Folder=C:\Programme\DVD2SVCD\Movie
    I-Author Folder=C:\Programme\DVD2SVCD\Movie
    PVA Folder=C:\Programme\DVD2SVCD\Movie
    TMPGEnc Folder=C:\Programme\DVD2SVCD\Movie
    ProCoder Folder=C:\Programme\DVD2SVCD\Movie
    [AVISYNTH_BilinearResize]
    0=BilinearResize(^TargetWidth,^TargetHeight)
    1=AddBorders(0,^BorderTop,0,^BorderBottom)
    [AVISYNTH_SimpleResize]
    0=SwapUV()
    1=LoadPlugin(!SimpleResize.dll)
    2=ConvertToYUY2().SimpleResize(^TargetWidth,^TargetHeight)
    3=AddBorders(0,^BorderTop,0,^BorderBottom)
    !SimpleResize.dll=C:\Programme\DVD2SVCD\Avisynth2.5 Plugins\SimpleResize\SimpleResize.dll
    [AVISYNTH_BicubicResize]
    0=BicubicResize(^TargetWidth,^TargetHeight,^b_value,^c_value)
    ^b_value=0.0
    ^c_value=0.6
  • [AVISYNTH_BilinearResize]
    0=SwapUV()
    ^b_value=0.0
    ^c_value=0.6
    [AVISYNTH_BicubicResize-SwapUV]
    0=SwapUV()
    1=BicubicResize(^TargetWidth,^TargetHeight,^b_value,^c_value)
    2=AddBorders(0,^BorderTop,0,^BorderBottom)
    ^b_value=0.0
    ^c_value=0.6
    kopiere das ans Ende der DVD2SVCD.INI
    Wichtig: dei einer normalen DVD darf kein SwapUV dabei sein sonst werden hier die Farben vertauscht.
    nochmal:
    Mit welchen Avisynth Setups arbeitest du bei den AVI`s?
  • Also es geht wieder nicht. Kann man eine avi sonst noch umwandeln. Weil mit blauen Gesichtern ist dass auch nicht gerade schön. Vielleicht hat ja irgendwer doch noch eine Lösung für DVD2SVCD
  • [AVISYNTH_BicubicResize_Swap-UV]
    0=ConvertToYV12()
    1=SwapUV()
    2=ConvertBackToYUY2()
    3=BicubicResize(^TargetWidth,^Target...
    4=AddBorders(0,^BorderTop,0,^BorderBottom)
    ^b_value=0.0
    ^c_value=0.6
    ...Height,^b_value,^c_value)
    wieder an den...zusammenfügen
    es sollte wieder so aussehen:
    Ich musste mir erst eine AVI erstellen um es auszuprobieren.
  • Also erst einmal: Bis jetzt läuft es einwandfrei! VIELEN DANK AN ALLE DIE MIR GEHOLFEN HABEN!!!!!!!!!!!!!!!!!!!!!!
    Ich hab es mit der letzten versucht und es ist gegangen!
  • Eine vielleicht elegantere Lösung des Aviproblems (blaue Gesichter) mit Geschwindigkeitsvorteilen
    1.DVD2SVCD.EXE kopieren (Kopie von DVD2SVCD.exe)
    2.Edit.com ins Dvd2Svcd-Verzeichniss kopieren
    3.Mit Edit.Com die "Kopie von DVD2SVCD.exe" BINÄR öffnen
    4.Über Suchfunktion "ConvertToYUY2(" suchen -das 2.mal ist es
    5.Mit Ersetzenfunktion "ConvertToYUY2(" durch
    _______ ___________ "______SwapUV(" Ersetzen -Position der Buchstaben und Leerstellen beachten! (___ = Leerstellen)
    6.Speichen unter (DVD2SVCD-SwapUV.exe) - nur für Avi`s mit blauen Gesichtern verwenden!
    Im Preview Video Fenster und bei AutoFitCD Detect Border sind sie aber noch blau.
  • Also du ersetzt "ConvertToYUY2()" durch "SwapUV()".
    Aber du musst du doch noch in YUY2 konvertieren, das macht DVD2SVCD doch jetzt nicht mehr automatisch, oder ?
    Arlsair
  • Ja ich ersetze YUY durch SwapUV()
    Hier ein Aviscript von orginal DVD2SVCD
    RT 1.62 CCE2.50
    Hier ein Aviscript mit der geänderten DVD2SVCD.EXE
    RT 1.88 CCE2.50
    beide Scripte nicht editiert
    Bei unkomprimierten Avi nur Orginal-Version - Da wird das YUY2 gebraucht wenn Avi im RGB-Format ist.
    Mdecoder.DLL ist Mpegdecoder von Nic mit mpeg2Source Ausgabe
  • Wieso fügt denn DVD2SVCD denn zweimal "ConvertToYUY2()" ein ? Die Resizefilter können doch alle Farbräume verarbeiten.
    P.S.: Wie modifizierst du denn den Mpeg2Decoder. Kannst du das mal zeigen ?
    Arlsair
