• 9.1.0
  • 9.2.0 "Photograph"
  • 9.3.1 "Mask Machine"
  • 9.4.0 "Knurl"
  • 9.4.1 "Black Rain"
  • 9.4.2 "So High"
    * mkvmerge: bug fix: AVC & HEVC readers: release v9.4.1 contains a change to both readers so that they will refuse to handle files where the detected pixel width or height is equal to or less than 0. This check was wrong in certain cases causing mkvmerge to reject a file as an unsupported file type. This has been fixed while keeping the constraints on width & height having to be positive.
  • 9.5.0 "Quiet Fire".
  • 9.6.0 "Slave To Your Mind"
  • 9.7.0 "Numbers".
  • 9.7.1 "Pandemonium".
    * MKVToolNix GUI: multiplex tool bug fix: under certain circumstances the GUI was creating invalid JSON files when starting to multiplex resulting in an error message ("JSON option files must contain a JSON array consisting solely of JSON strings").
  • 9.8.0 "Kuglblids"
  • 9.9.0 "Pick Up"
  • 10.0.0 "To Drown In You"
  • 11.0.0 "Alive"
  • 12.0.0 "Trust / Lust"
  • 13.0.0 "The Juggler"
    https://www.fosshub.com/MKVToolNix.html
  • 14.0.0 "Flow"
  • 15.0.0 "Duel with the Devil"
  • 16.0.0 "Protest"
  • 17.0.0 "Be Ur Friend"
