• 18.0.0 "Apricity"
  • 19.0.0 "Brave Captain"
  • 20.0.0 "I Am The Sun"
    https://www.fosshub.com/MKVToolNix.html
    Einmal editiert, zuletzt von Schotenhüter (25. Februar 2018 um 14:31)
  • 21.0.0 "Tardigrades Will Inherit The Earth"
  • 22.0.0 "At The End Of The World"
  • 23.0.0 "The Bride Said No"
  • 24.0.0 "Beyond The Pale"
  • 31.0.0 "Dolores In A Shoestand"
  • 32.0.0 "Astral Progressions"
  • 33.0.0 "A Little Bit of Madness"
    ## Bug fixes
    * mkvinfo: when using the `--size` option, mkvinfo will now report the correctly if an element has an unknown size. Part of the fix of #2530.
    * MKVToolNix GUI: info tool: clusters with an unknown size will now be read and displayed correctly. Part of the fix of #2530.
    * MKVToolNix GUI: multiplexer: Windows: trying to open Blu-ray index or playlist files failed when the path to the files contained symbolic links (e.g. when mounting a drive in a sub-folder via Windows' disk management utility). Fixes #2522.
    * MKVToolNix GUI: multiplexer: if a destination file names ends with a number in parenthesis (e.g. a year such as "(2017)"), that number will not be stripped anymore during the process of ensuring the destination file name is unique. Only those suffixes added automatically in prior attempts to make the file name unique will be removed. Fixes #2521.
    * MKVToolNix GUI: multiplexer: Windows: the GUI will let the user change the drive letter part of the destination file name freely again and only verify its validity right before starting to mux/adding to the job queue. Before it tried to force that into something valid, often resulting in unintentional paths (such as "C:\users\…\DC\files\…"). Fixes #2527.
