ImgBurn - aktuelle Version
  • Hallo zusammen,
    Lightning UK is back! :) :daumen:
    Hat ein neues Programm rausgebracht, ImgBurn, das eine Weiterentwicklung der Brennengine des Decrypters beinhaltet.
    Zitat von Lightning UK
    ImgBurn carries on from where DVD Decrypter left off! (Well, for the burning part anyway!)
    ImgBurn can write most types of CD / DVD images and it supports all the latest writers (including booktype / bitsetting on many of the major ones - i.e. BenQ, LiteOn, NEC, Plextor, Sony). You can even use ImgBurn to erase / format your rewritable media!
    ImgBurn is an enhanced version of the 3.5.4.0 burn engine - and it will continue to get better and better as time goes on.
    Changelog (wahrscheinlich zu 3.5.4.0 nehm ich mal an ;)):
    • Added: Much improved ISO (DVD Video) image double layer burning. The image is now parsed, the IFO file scanned and the 'seamless playback linked in PCI' flag read/updated to find the best place for the layer break.
    • Added: Changing the volume label of an ISO image via the 'Tools' menu will refresh the one displayed on the main screen if it's the same file.
    • Added: 'Device' to the information area in ISO Write mode during burning.
    • Added: Alternative method of 'load/eject' for drives that dont support 'immediate' command execution.
    • Added: 'Display IFO Layer Break Information' to new Context menu to 'Sectors' label.
    • Added: Tooltip to log windows when the line the mouse is hovering over is too long to fit in the window. The tooltip contains the full line!
    • Added: Possible workaround for drives that randomly return 'Unknown' for 'current profile' that then leads to DVD+R/+RW discs not being finalised.
    • Added: Support for *.GCM images.
    • Added: Retries (10) to the 'CreateFile' API call when doing the 'Search for SCSI / ATAPI Devices' thing using SPTI as the I/O Interface.
    • Added: Log entry explaining in plain english that when you get a 'createfile failed!' message in the log, it means the drive WILL NOT be visible in the program.
    • Added: Log entry when FSCTL_LOCK_VOLUME fails with 'Invalid Function' error. Means drivers dont support it, and therefore need updating. I now mention this in the log.
    • Added: The reason behind FSCTL_LOCK_VOLUME failing to the log.
    • Added: Option to not have the program wait for the background process of formatting a DVD+RW.
    • Added: Support for detection of DVD+RW DL media.
    • Added: Sarcastic message when people try to load IFO/BUP/VOB files for burning.
    • Added: CLI switch '/LAYERBREAK' to allow 3rd party apps to pass the layerbreak LBA directly, rather than manipulating the registry.
    • Added/Fixed: UDF File system error detection when file potentially use 32bits to store their size, rather than the 30 they're supposed to use. A dialog box now comes up if this is detected and asks the user which 'size' they'd like to use - the 30 bit version or the 32 bit one.
    • Changed: Layer break info now shown for DVD-R DL media.
    • Changed: Tooltips - so they're displayed for 5 seconds instead of 2.5.
    • Changed: Hitting 'retry' during a write error will no longer perform X number of retries (as specified in the settings). It'll just do the 1 now!
    • Changed: Layout of drive compatibilities page.
    • Changed: (for the moment anyway) Write parameters are now sent again for DVD+R burns. Some older drives had problems when they weren't sent.
    • Changed: No more forcing of dismounts on the volume when the disc is ejected. They cause other problems.
    • Changed/Fixed: Aborting a write operation whilst it's filling the buffer will no longer perform any of the actual writing/finalising etc.
    Mehr dazu hier.
    PgcEdit unterstützt es übrigens auch schon.
    Und an alle die das vielleicht nicht ganz begriffen haben: Das hat NICHTS mit RIPPEN zu tun! ;D
    Cu Rippraff
    Blumige Grüße, Rippraff
  • Schön und gut das Ganze.
    Mir wäre allerdings eine Fortsetzung des "alten Teils" ohne das CSS - Zeug lieber gewesen.
    Das hätte dann ALLERDINGS was mit mit RIPPEN zu tun! :D Noch dazu Legal.
  • Zitat von Rippraff
    Current version: 1.0.0.0
    Also nicht 3.5.4.0...
    bb
  • Zitat von bb
    bb
    wozu denn sonst, wenn es vorher keine Version gab zu der es Änderungen geben könnte ;)
  • Zitat von bb
    Ich dachte es wäre klar, was ich meine: ImgBurn soll doch eine Verbesserung der Brennengine aus dem Decrypter sein, auf letzteren bezieht sich die 3.5.4.0. ;)
    LigH könnte natürlich auch recht haben, allerdings bezweifele ich das, wenn ich mir das zugehörige Forum ansehe oder der Bereich wäre für normale Mitglieder gesperrt. Das Beta-Tester-Team ist dort auch noch keinen Monat zu gange.
    Cu Rippraff
  • Wie auch immer - jedenfalls finde ich es gut, dass Lightning UK weitermacht.
    Übrigens: Kann mir mal jemand erklären, wofür man vierteilige Versionsnummern braucht?
    bb
  • Goodyear2001
    Das wäre wünschenswert gewesen, eine Iso-Erstellung mit einzubauen, ohne das ganze Kopierschutzteufelswerk. Wird aber wohl nicht dazu kommen.
    Aber zur Erstellung kann man natürlich auch PgcEdit oder ImgTool Classic verwenden. Bei letzterem hab ich den Autor schon informiert, ob das Programm nicht in Zukunft ImgBurn unterstützt.
    Cu Rippraff
  • ImgBurn 1.1.0.0 ist raus! :)
    Changelog:
    • Added: 'Verify' mode for both CDs and DVDs.
    • Added: 'Discovery' mode for testing out media to full / custom capacity without the need for an image.
    • Added: Support for queuing up images to burn (with full Drag 'n' Drop support).
    • Added: Support for specifying how many copies of an image to burn (within Queue window).
    • Added: Support for Drag 'n' Drop of multiple images / folders (containing images) to Write mode's 'Source' box.
    • Added: Export of graph data from previous burn.
    • Added: Display of graph data from previous burn - using DVDInfoPro. Now you can see pretty graphs showing you exactly what speed your drive was burning at and when.
    • Added: Overburning support for DVD+R discs in BenQ (and other?) writers.
    • Added: 'Test Mode' for DVD+R/+RW/+R DL media when using a BenQ drive that supports the feature.
    • Added: New device capabilities window to replace old method that just used a MessageBox.
    • Added: Additional methods of finding a nice layer break position on a dvd.
    • Added: Recent Files list to File menu and context menu on the 'Browse' buttons.
    • Added: Enhanced 'File Association' code to overcome certain problems where the associations wouldn't be visible in the explorer context menu.
    • Added: Support within the installation program for disabling DVD Decrypters file associations.
    • Added: Some additional lines in the log when burning double layer discs so the user knows when layer 0 / layer 1 are being written.
    • Added: /CLOSESUCCESS CLI switch. Will only close the program after a successful burn/verify - unlike /CLOSE which closes regardless of what happens!.
    • Added: /WAITFORMEDIA CLI switch so /START /CLOSE doesn't mean the program loads / quits if the drive isn't ready.
    • Added: Media ID is now displayed for DVDRAM media.
    • Added: 'Display IFO Layer Break Information' to Tools -> ISO menu.
    • Added: Device name/string to the info panel when there is no disc in the drive.
    • Added: Support for Ctrl-A in change volume label edit boxes.
    • Added: Support for Ctrl-A in L0 Sectors edit box in the Settings dialog.
    • Added: Additional limiting of L0 Sectors edit box to numbers only.
    • Added: 'All' and 'None' buttons for file association stuff in the settings.
    • Added: ISO9660 field in label change dialog now always uses uppercase.
    • Added: Character counter to the change volume label dialog box.
    • Added: Settings -> Events -> On Startup -> Set Program Mode.
    • Added: Settings -> General -> Warnings -> Images Still Queued (prompts to save queue when you exit the program if there is more than 1 image in it).
    • Added: Ability to save/load queue (new .IBQ file type (stands for: ImgBurn Queue)).
    • Added: Some more code for BD and HD DVD drives - to support write/erase etc. (not tested yet, obviously! - anyone got a spare drive?!).
    • Added: Current / Maximum Format Capacity to the info panel in Write/Discovery modes for rewritable discs.
    • Added: BETA support for Layer Jump Recording (alternative to DAO and Incremental on DVD-R DL media) - Must be enabled via registry key.
    • Added: Double click 'Graph Data File: ' log entry to display that IBG file in DVDInfoPro.
    • Added: 'Layer Jump Recording' capability to the Drive Capabilities page.
    • Added: Warning message when burning DVD-R DL media and Layer Jump Recording is not supported/being used.
    • Added: Support for latest version of bitsetting in LiteOn drives.
    • Changed: 16x16 icon now also has the flame in it.
    • Changed: The old SpeedButtons for a custom built PngSpeedButton - The images look nicer ;-).
    • Changed: Pressing F5 now refreshes the image info, not just device info.
    • Changed: 'Max Speed' is now sampled more frequently to hopefully provide a more accurate value.
    • Changed/Fixed: Patin-Couffin 'Lock Volume - Exclusive Usage' code. New drivers (post version 32) were not made backwards compatible with old IOCTLs.
    • Changed/Fixed: Method of calculating free sectors on media - mainly for DVD+RW and DVDRAM (fix was needed for DVDRAM).
    • Fixed: Could lose the layer break dialog if minimised to system tray when it pops up.
    • Fixed: UDF allowing too many chars in the field without any message to say it will be truncated.
    • Fixed: Unable to delete folder of image you've just 'browsed to' and burnt.
    • Fixed: Devices drop down box now looks disabled when it is disabled.
    • Fixed: Burning to DVDRAM didn't issue any erase/format/overwrite dialog boxes - even when they were needed.
    • Fixed: Double clicking log entries wasn't correctly parsing the strings for 'known' variables.
    Gibt's hier.
    Cu Rippraff
  • ImgBurn 1.2.0.0 ist raus! :)
    Changelog:
    • Added: Queue can now switch drives/write speed on a per image basis.
    • Added: Verify now displays which file the error was in - if/when a miscompare occurs.
    • Added: Filesystem parsing within Image Files has been improved to include the ISO9660 FS too.
    • Added: A check for AnyDVD / DVD43 (displayed as 'Interfering programs') - as they could potentially modify data when it's being verified - resulting in a 'Miscompare' error.
    • Added: 'Sort By Name' to context menu in Queue window.
    • Added: 'Sort By Name (Ignore Path)' to context menu in Queue window.
    • Added: 'Image Files' as an option for IBG default path options within the settings. This means the IBG gets put in the same folder as the source Image file.
    • Added: %V to custom IBG filename options within the settings. %V stands for 'Volume Identifier' A.K.A. Volume Label.
    • Added: 'Compress Spaces' to custom IBG filename options within the settings.
    • Added: Ability to click column header in Queue window and have it 'sort by name'.
    • Added: Ability to tell Write mode to tell Verify mode to not compare against the file - so it behaves more like 1.0.0.0 where it just checked the sectors could be read.
    • Added: Ability to have Verify mode ignore non user data within sectors. i.e. So with Mode1/2352 images, it only compares the real 2048 user data bytes.
    • Added: Support for loading / saving IBG v2.0 files - to take into account the new options for queued items.
    • Added: '/TESTMODE' CLI switch.
    • Added: Settings fixing/deleting within the installation program depending on current action (downgrade / reinstall / upgrade).
    • Added: Ability to synchronise device selection within the various modes.
    • Added: Ability to synchronise options in ISO Write / Discovery modes (i.e. Test Mode, Verify and Write Speed).
    • Added: 'DVDRAM FastWrite' to Write settings. This is pretty much a bodge to disable the 'verify' part that's built into normal DVDRAM burning.
    • Added: 'Burnt Copies' to Queue window.
    • Added: Increased max copies from 20 to 100.
    • Added: Image details are now updated/refreshed when you start to burn. Previously they were just read when the image was loaded / queued up.
    • Added: Graph data for Verify process (after write process) is now added to IBG file.
    • Added: Option to have the 'Reserve Track' command issued when burning DVD+R/+RW format media. Normally it's just issued for DVD-R/-RW media.
    • Added: 'Verify / Delete Image / Close Program / Shutdown Computer' checkboxes to all modes.
    • Added: Advanced Settings dialog for BenQ / Plextor drives to control special features like PowerRec, WOPC, OverSpeed etc.
    • Added: Verify can now be told to ignore an error and go on to verifying the next one.
    • Added: Workaround to make 'Wait for background format' work on Pioneer drives that don't follow the MMC spec. (Even the 110 has this problem!)
    • Added: Media information to log when erasing discs.
    • Added: Ability to enable/disable 'Stay On Top' for Queue window from within the settings.
    • Added: Little 'Refresh' buttons to the Advanced Settings and Booktype windows.
    • Added: Shutdown dialog (with 'Abort' button and a 10 second timeout) for when the program is supposed to shut the pc down.
    • Added: 'Book Type' to verify log.
    • Added: Ability to get IFO layer break position from 2054 bytes per sector (mastering style) DVD images.
    • Added: Improved methods used to find potential layer break position.
    • Added: Information about midpoint of Image file to the Layerbreak window. The nearer to this value the layerbreak position is, the more compatible with players the final disc will be.
    • Added: Support for '.di' (Prassi / TraxData ONES) images.
    • Added: Support for erasing BD-RE media. (well, fixed it really!)
    • Added: 'LightScribe' and 'Labelflash' entries to Device Capabilities window.
    • Added: Verify now counts up all the errors in a given sector and shows that number in the first (and only) miscompare warning.
    • Added: Extra right click 'Apply xxxx setting to selected' options to the Queue window.
    • Added: A 'MB' (megabytes) value to the 'Not enough space on disc' dialog box.
    • Added: Updating the drive / write speed in the main window now also refreshes the Queue window.
    • Added: A delete button to the 'previous image' section of the 'Please insert next disc...' window.
    • Added: Auto retries to the 'cycling tray before verify' bit of code - useful for when the drive sometimes fails to initialise the disc - it'll then auto eject + reinsert it again.
    • Added: 'Share Images Amongst Drives' & 'Share Selected Images Amongst Drives' options to context menu in Queue window.
    • Added: 'Select All' & 'Invert Selection' options to context menu in Queue window.
    • Added: 'Sequential Scan' flag to command used when reading files. This seems to speed things up when reading over a network.
    • Added: Support for multiboot gcm images.
    • Added: Option to make ImgBurn the default application for the files it's associated with in the registry
    • Added: A second icon to the exe that people can use for files associated with the program.
    • Added: Checking for minimum version requirement of DVDInfoPro before attempting to display an IBG file with it.
    • Added/Fixed: Volume Label change code now updates EDC/ECC area of 2336/2352/2448 byte sector images - would have previously failed Verify.
    • Changed: 'HD DVD-RW' to 'HD DVD-RAM' (the new correct name for it).
    • Changed: Slight redesign of the 'Insert next disc...' dialog.
    • Changed: Maximum Speed (calculated over 2.5 seconds) value can now only be 20% bigger than average speed (calculated over 10 seconds), or else it is ignored. Might cut down on spikes caused by drives caching the I\O requests.
    • Changed/Fixed: Added an aligned buffer to one of the DeviceIoControls commands - used to enable/disable media change notification.
    • Changed/Fixed: The 'Supported Write Speeds' now ensures only 1 instance of a certain speed is shown. i.e. no more 'Supported Write Speeds: 2x, 2x, 4x, 4x, 8x, 8x, 16x, 16x'
    • Fixed: Sorting the Queue didn't update the file shown in the main window.
    • Fixed: Enabling 'Delete The Image File When Done' caused problems if 'Copies' (within the queue) was set at more than 1, or if the image was queued again. Queue is now checked to ensure the image isn't going to be used again before it's deleted.
    • Fixed: Redraw (empty box!) problem on device drop down comboboxes.
    • Fixed: Overburning 'Reserve Track' problem on Plextor and other burners.
    • Fixed: 'Reached EOF' error on PDI etc images.
    • Fixed: Incorrect MSF value in some places.
    • Fixed: Bug (access violation) deleting all items from Queue window.
    • Fixed: Bug with discovery mode showing 0 sectors when verifying - and verify not actually doing anything.
    • Fixed: Issues with my custom component - as used in Discovery mode for Sectors / MB stuff. It didn't display the correct number under Window 9x unless the program started in Discovery mode.
    • Fixed: Bug in UDF parsing code. Would only find/search about 39 files (max) when searching files for layerbreak info.
    • Fixed: Potential workaround for 'PlaySound' API hanging.
    • Fixed: Log window not always coming to foreground when app is activated - it appears like it's not visible/enabled.
    • Fixed: Removed dots from auto IBG naming with 'date' parameter.
    • Fixed: Certain actions could lead to cancelling a close/shutdown but the shutdown part still being enabled - hence when program is finally closed, the pc shuts down.
    • Fixed: Problem with updating the IFO's after figuring out a new layer break flag needed to be added.
    Wie immer hier.
    Cu Rippraff
  • Neue Version: ImgBurn 1.3.0.0
    Changelog:
    1.3.0.0 Released: Thursday 13th April 2006
    • Added: New 'Sector Viewer' feature - within the 'Tools -> Drive' menu and the device context menu.
    • Added: Log windows 'Save As' box now defaults to/remembers the last folder you saved to.
    • Added: 'Open File' / 'Save File' / 'Browse for folder' dialog boxes are now centred when displayed.
    • Added: Checking/unchecking the 'Delete Image' checkbox during a burn/verify now also updates the Queue window (if it's open) to reflect those changes.
    • Added: Support for newer LiteOn drives & their new features in the 'Advanced Settings' window.
    • Added: 'UDF Revision' of the Image file to the log and to the tooltip/hint of the volume label text shown in main window.
    • Added: 'Volume Identifier' (aka. volume label) of the Image file to the log when burning / verifying.
    • Added: Device Buffer and CPU % Usage to IBG data file.
    • Added: Ability to remove the warning about overburning for people that use it all the time!
    • Added: Support for setting the action to be performed when the 'shutdown computer' box is ticked. Options are: Log Off, Restart, Turn Off, Stand By, Hibernate.
    • Added: New context menu to 'Shutdown Computer' checkbox (visible when burning / verifying). This provides a shortcut to the 'Shutdown Action' options.
    • Added: 'Layer Jump Recording' has now been fixed (Thanks to a nice man at LiteOn) and is no longer always disabled. Due to the weird way it works, it's actually very pointless and not at all what I originally thought/hoped it was!
    • Added: Ability to disable the 'Shutting down...' window that lets you abort the shutdown.
    • Added: '/IBG ""' CLI parameter. This will make the program export the graph data to that file when it finishes burning/verifying.
    • Added: Setting ImgBurn to be the default program for the selected image file extensions now refreshes the Shell Icon Cache to you can see the changes without a reboot.
    • Added: A few more errors codes to where the automatic tray cycling code comes into play between writing and verifying if there is an error.
    • Added: Errors are now looked at/checked for when using certain lengthy commands - i.e. Sync Cache, Close Track / Session / Disc. This now works for those where the 'IMMED' (immediate) bit is set - i.e. after burning. Previously, errors during these stages would go unnoticed.
    • Changed: Default IBG naming to something more useful.
    • Changed: Tweaked the 'max speed' capturing code a little more to help reduce the chance of 'spike' speeds becoming the max value.
    • Changed: 'Layer Jump Recording' warning message has been replaced by a 'Layer Break on DVD-R DL' warning.
    • Fixed: Stupid problem with the OS caching the image file as it's read into the internal buffer. This often lead to running low on memory and hence use of the hdd swap file - causing major buffer problems for some people.
    • Fixed: /TESTMODE CLI switch bypassed the normal checks for 'Test Mode' not working on certain media - i.e. DVD+ format discs.
    • Fixed: Bug with 'Open/Save File' dialog boxes being open and still being able to close the program from the task bar. This often led to an internal never-ending loop somewhere.
    • Fixed: Compressing the ImgBurn.exe file with UPX caused problems (BSOD's) on Windows 9x so this will not be used again. PECompact will be used instead.
    • Fixed: 'Delete Image when done' being unchecked on queued images as a result of resetting the controls on the screen ready for the next image.
    • Fixed: It wasn't possible to click the 'Write' button if the currently selected drive wasn't in the 'ready' state - even if that drive wasn't used by any images in the queue.
    • Fixed: Problem with using CVS version of NSIS installer on Windows 98. The Welcome / Finish screens were not displayed correctly.
    • Fixed: Problem with updating the IFO files when burning DL images where layer break position needed to be moved.
    • Fixed: The 'Shutting down...' window had problems when triggered by the 'Shutdown computer' option visible when burning.
    • Fixed: CD MDS files weren't being accepted as valid single session / track MDS files - when really they were!
    • Fixed: Discovery mode's Verify was including the 'parse filesystem' code - which of course failed as it's not a real image.
  • 05.08.2006
    ImgBurn v2.0.0.0 Released!
    http://www.imgburn.com/
    alle die Probleme mit ihrem Virenscanner haben bei der Installation der neuen Version, die PEcompact Virusmeldung sit falsch. Sollten sich ImgBurn nochmal direkt von ImgBurn-Board runterladen. (Mirror 6)
    Der Fehler ist dann behoben. Hier der Link zum Thread im ImgBurn Forum.
    MfG
    Morpheus
  • Auch hier gibts Fehlermeldungen.
    zudem noch diese Meldung
    Maximum Format Capacity:
    Sectors: 2'295'104
    Time: 510:03:29 (MM:SS:FF)
    510 Minuten
    Geladen vom Mirror 6......Type of install = full
    Was passt da nicht?
    Die Zeitmeldung bezieht sich auf die Kapazität einer Standard Audio CD
    Auf eine normale Audio CD passen 74 min Musik - umgerechnet auf eine DVD entspricht das 510 min
    Oha....sollte ich eigentlich vom DVD-Audio "Ersteller",Wavelab,wissen.
    Danke.
  • ImgBurn v2.1.0.0 Released!
    Changelog v2.1.0.0
    • Added: Option of using an auto-generated (where possible) volume label if none as been specified in Build mode.
    • Added: Option to auto ignore 'In Use' files during a 'Build'.
    • Added: Directories now have their 'Modified' dates preserved in 'Build' mode.
    • Added: Log entry to show existing emulation type of boot image (plus other info) on a cd/dvd when using the 'Create Boot Image' feature.
    • Added: The 'Sync Cache' command now auto retries when it fails with the error 'Logical unit not ready, Long Write in Progress'.
    • Added: If you load an IBQ (ImgBurn Queue) file and one (or more) of the image files don't exist, you can choose to locate them elsewhere - incase you renamed / moved them.
    • Added: Ability to add ';1' (known as File Version Number) to the files in the Joliet filesystem. This 'should' only be done for ISO9660 filesystem files but some players are buggy.
    • Added: Ability to auto queue images created in Build mode.
    • Added: The 'save on exit' option for the log now has the ability to append to an existing log file. The log is now save by default on new/updated installation and is set to append to a single file.
    • Added: Additional logging for when the 'Create Boot Image' operation fails.
    • Added: Option to apply the 'Delete Image' setting to the other selected images.
    • Added: Buttons to the bottom of the queue window for applying the current settings (i.e. those of the first selected image in the list) to all the other selected images.
    • Added: Option to sort Queued images by their parent folder name (NOT the full path, just the folder name).
    • Added: Info about total number of queued images remaining and total number of copies remaining to the burn queue window.
    • Added: An alternative 'Padded' MD5 calculation for when burning + verifying an image on DVD+R media where the drive automatically pads the image so the last sector is divisible by 16.
    • Added: Right click the 'Browse' button in the destination box (in build mode) and you'll get an option to swap the drive of the current path - it'll also show you all drive names / sizes (same as how [Blockierte Grafik: http://technik.movie2digital.de/alink.gif] DVD Dec used to do it when you right clicked the actual name).
    • Added: 'Stay On Top' to the system menu of the main window. (Left/right click the top left icon in the Windows caption bar).
    • Added: ISO Build mode can now be told where to put the [Blockierte Grafik: http://technik.movie2digital.de/alink.gif] DVD Video type content within an image (start/mixed/end) - really only applies to when you also have normal DVDROM content to add to the image - the default is 'mixed'.
    • Added: Support for listing the Manufacturer ID of BluRay discs.
    • Added: Various options for how often the 'Check for program update' code should run. Choices are: Daily, Weekly, Fortnightly, Monthly.
    • Added: Speeds shown during burn/verify of HD DVD/BD discs should now show the correct relative speeds for that format (rather than being based on 1x [Blockierte Grafik: http://technik.movie2digital.de/alink.gif] DVD speed).
    • Added: Support for/detection of new types of media (HD DVD-R DL and BD-R DL)
    • Added: Buttons to copy volume labels to the other file systems - i.e. from ISO9660 to Joliet and UDF.
    • Added: Info about current status of 'IFO/BUP 32K Padding' option to the image details message box that pops up just before the build starts.
    • Added: BD-RE has been added to the existing 'DVD-RAM FastWrite' option. This prevents the drive from performing its own internal write + verification, leaving verification down to the software.
    • Added: '/CLOSEINFO' CLI command to allow closing of the application once it has written the info file (based on '/INFO' CLI command).
    • Added: '/ROOTFOLDER' CLI command to allow bypassing of the prompt about a single folder representing the root folder.
    • Added: '/NOSAVESETTINGS' CLI command to prevent the program from saving the settings when it's closed.
    • Added: '/VOLUMELABEL_ISO9660', '/VOLUMELABEL_JOLIET' and '/VOLUMELABEL_UDF' CLI commands for people that like to have different volume labels for each file system in 'Build' mode.
    • Added: '/PRESERVEFULLPATHNAMES', '/RECURSESUBDIRECTORIES', '/INCLUDEHIDDENFILES', '/INCLUDESYSTEMFILES', '/INCLUDEARCHIVEFILESONLY' and '/CLEARARCHIVEATTRIBUTE' CLI commands to allow maniplulation of core 'Build' mode settings.
    • Added: Build mode can now be passed multiple folders/files via CLI using the '/SOURCE' argument and by using pipes ('|') to separate file/folder names within the quotes.
    • Added: '%B' to the default IBG file naming options. This is replaced by the date in YYYY/MM/DD format.
    • Added: Option of automating the answer ('Yes' or 'No') to the 'Root Content' question in Build mode.
    • Added: IBB files now also support the 'Bootable Disc' tab settings in Build mode.
    • Added: Option to have the most recently used tab remembered / restored within Build mode.
    • Added: Correct sorting of files in the AUDIO_TS folder.
    • Added: The uppercase / filtering options for DVD-Video have now been extended to include the AUDIO_TS and JACKET_P folders.
    • Added: Warning message to the 'Ignore' button on the 'Create Layer Break Position' window.
    • Added/Changed: The 'Create MDS File' option in build mode has been expanded to allow 'Auto' / 'Yes' and 'No' modes. 'Auto' means it'll only be created when there is a need for it.
    • Added/Changed: Images built in build mode are now padded so their total size is divisible (exactly) by 16.
    • Added/Fixed: Files with the 'Hidden' attribute set are now marked as 'Hidden' within the image file that Build mode creates.
    • Changed: The 'Change Volume Label' dialog box has been redesigned so it's more like the one that pops up when you build an image without specifying a name.
    • Changed: Some of the pictures on the 'start' buttons have been replaced so they all match. i.e. no more picture of a hdd - it now shows a picture of an image file.
    • Changed: The 'Media' tab in ISO Build mode is now hidden when outputting to a 'Device' rather than an 'Image File'. It does not apply when outputting to a 'Device' because it's all automatic.
    • Changed: 'Create/Select Layer Break Position' dialog boxes are now resizable.
    • Changed: All the 'Media Control Notification' stuff has been rejigged so that windows can detect when the media/media content has been changed if the program isn't doing anything important like burning/erasing etc.
    • Changed: The Queue window is now reopened (if appropriate) after inserting the next disc for a queued burn.
    • Changed/Fixed: When a build is cancelled and an incomplete file is deleted, the empty folders were also deleted without warning. You're now asked if you want to remove empty directories.
    • Fixed: UDF filesystem wasn't using the 'Creation Date' specified in the options for volume dates.
    • Fixed: Statusbar stayed showing '0% - Creating Boot Image...' even when it had finished if the boot file was really small.
    • Fixed: Verify mode wasn't showing the correct 'progress' values (sectors, size, time etc.) for some CD images.
    • Fixed: Layerbreak code in ISO Write mode wasn't correctly being told about fixed layerbreaks - as found on DVD-R DL.
    • Fixed: Jumping focus bug when selecting items in the burn queue that had certain option enabled.
    • Fixed: It was possible to click the big 'Write' / 'Build' / 'Verify' buttons twice and get 2 lots of threads running doing the same thing. The buttons are now disabled the second they're clicked.
    • Fixed: UDF backup anchor could end up in the wrong position due to automatic drive padding on DVD+R when the total image size (in sectors) is not divisible (exactly) by 16.
    • Fixed: When doing queued burns (shared between multiple drives), the taskbar button would flash forever until the program was made the foreground app (by clicking on it). Now it stops it flashing once the 'Auto OK' thing has kicked in and it's no longer waiting for user input.
    • Fixed: Some of the 'open file' dialog boxes could attempt to take on default file names that they shouldn't have been (i.e. ones internal to the program).
    • Fixed: Path names with trailing back slashes weren't accepted/used by build mode when passed using the '/SOURCE' CLI command.
    • Fixed: In Build mode, double layer images requiring a lot of padding (to make it 50/50) and at the same time making use of 32k gaps could end up with layer 1 being larger than layer 0 and layerbreak LBA positions shown in the 'Create layer break position' window would be wrong.
    • Fixed: Incorrect offset in IFO when a gap was added between IFO and BUP (i.e when there's no, or a small, VOB file).
    • Fixed: Some methods of drag + drop weren't working as they should have been.
    • Fixed: PECompact virus warning from some AV software.
    • Fixed: 'End Of File Reached' error message when verifying some really small images.
    • Fixed: 'On Startup' option of setting the 'Build Mode' (i.e. what it outputs to - device/image file) didn't work.
    • Fixed: Incorrect custom file/folder times due to daylight savings being applied once within the image and then again by the operating system as the end user views it.
  • IMGburn V2.2.0.0 ist raus!
    http://www.imgburn.com/index.php?act=changelog
    • Added: 'Read' mode for basic (sector by sector) creation of images direct from a cd/dvd.
    • Added: Unicode support to everywhere that needs it!
    • Added: An 'AUTO' write speed where you can now have custom write speeds for individual media types/dyes on a drive by drive basis. You can also use things like 'CD-R', 'DVD-R', 'DVD+R' etc.
    • Added: Ability to preview Cells in the Build mode's 'Create layer break position' dialog box (or doing it via Tools -> ISO -> Display IFO Layer Break Position). This uses PgcEdit's little PgcEditPreview.exe file.
    • Added: Option of Standard/DOS/ASCII characters set for ISO9660 file systems. (previously only Standard/ASCII was supported)
    • Added: Ability to build ISO9660 file systems where files can have no extension at all (not even a '.' (dot)).
    • Added: Options to disable warnings when checking 'seamless' or 'don't update ifo/bup files' boxes in the layer break dialog windows.
    • Added: Options to automatically check the 'seamless' and 'don't update ifo/bup files' boxes in the layer break dialog windows.
    • Added: Support for reading/parsing UDF v2.50 - as used on HDDVD / Blu-ray discs.
    • Added: Build mode now has the ability to look for and optimise duplicate files so that only 1 copy of that file actually exists in the ISO/on the disc.
    • Added: /EJECT CLI command.
    • Added: 'Auto Change Book Type' option to the settings. This is only used for LG and Samsung drives. When enabled (default), it will make the program send the appropriate command to tell the drive to booktype the disc to DVDROM at the start of every burn - obviously just for Plus format media -i.e. DVD+R, DVD+RW, DVD+R DL.
    • Added: Ability to insert a layer break position in the MDS file made by the 'Create DVD MDS File' tool.
    • Added: Early warning message on DVD Video builds where the files are probably too big for the destination DVD media.
    • Added: Checks for people loading '*.000' and '*.ISO' files in Write mode when a '*.DVD' one exists.
    • Added: Ability to burn small images JUST to the first layer on DL media (normally you would split the data between layers).
    • Added: Warning message if user specified layer break differs from that in the loaded *.MDS/*.DVD file.
    • Added: Additional check for file splitting suitability when doing a read/build to hdd using the FAT/FAT32 file system.
    • Added: 'Sector Viewer' button to Read/Verify modes in the 'Source' box.
    • Added: 'Cancel' option when loading an IBQ file and none of the images are in the right place!
    • Added: Files created in Read/Build mode are now (optionally - default = on) pre-allocated. This cuts down on fragmentation.
    • Added: Options to set process priority during Read/Write/Verify.
    • Added: Support for reading hdd partitions to an image file suitable for use as the boot image when building a bootable disc/iso.
    • Added: A button on the 'volume label' windows to have it insert the current date/time in YYYYMMDD_HHMM format.
    • Added: Answer 'Yes' / Answer 'No' options to the 'Don't prompt VIDEO_TS content' option.
    • Added: An optional timeout to the auto volume label window (default is ON and 30 seconds).
    • Added: Layer break positions are now displayed in the main GUI if the MDS/DVD file loaded in Write/Verify mode contained one.
    • Added: Options on the 'Create DVD MDS File' window are now remembered between sessions.
    • Added: The option of preserving full pathnames within MDS files created by Read/Build modes.
    • Added: Improved logging options for files that have their names shortened due to file system limitations / restrictions currently in place.
    • Added: Ability to add device id strings that are really OEM LG / Samsung drives - for use by the 'Auto Change Book Type' feature.
    • Added: New 'Filter Driver Load Order' feature so you can see which drivers all your I/O is going through - and spot ones that could be messing things up. (Available on Windows 2000 and newer)
    • Added: When the book type commands fail, the 'reason' (I/O SenseArea interpretation) is now also displayed in the messagebox.
    • Added: Support for Vista's new 'OnDVDArrival' autoplay stuff - so it now says 'Burn an Image' (using ImgBurn) as an option when you insert a blank DVD. (This had already been implemented for OnCDArrival and I had assumed it would apply to both - it didn't!)
    • Added: Support for showing supported write speeds on CD.
    • Added: Support for identifying DVD+RW DL booktype.
    • Added: 'TOC Information' to the Info panels in all modes.
    • Added: Detection/Identification of 'HD DVD-ROM' etc type drives to the log when ImgBurn first starts.
    • Added: Detection of HD DVD-RW read/write capabilities.
    • Added: Context menu with 'Copy' option on it to the 'Label' field in the 'Previous Image' groupbox on the 'Please insert next disc' window.
    • Added: Message in 'Build' mode when user tries to write an ISO image - where they should probably be using 'Write' mode.
    • Added: 'Free Space' to the info page in build mode - used as part of the 'Calculate' function.
    • Added/Changed: 'Preferred Format Capacity' value to info window for rewritable media. This value is now used during full erase rather than the maximum one.
    • Added/Changed: A little workaround for a glitch in Vista with windows using a non resizable frame under the Aero theme. Pixel 0, 0 is not the absolute top left of the window - making the window appear off the screen.
    • Added/Changed: The shutdown options / API's now use the 'FORCE' flag if ImgBurn detects the computer is 'Locked' - this can be disabled in the settings.
    • Changed: Only the first cell in an angle block is now shown as a potential layer break. Other cells in the block take on the same SPLIP flag as the first.
    • Changed: Check for updates defaults to 'Weekly' now. (Beta versions still do it every time it's started)
    • Changed: 'Time' column header in layer break dialog boxes to say 'Start Time'.
    • Changed: Some of the 'Program Update' code to hopefully reduce the chance of getting a cached response when checking for version updates.
    • Changed: When looking for firmware updates, only the model is now passed to the http://www.rpc1.org search engine rather than make + model.
    • Changed: On a fresh install, people with over 1GB RAM get a 40MB buffer, not 20MB.
    • Changed: Process priority for Verify mode now defaults to 'Normal'.
    • Changed: Some of the little hdd/cdrom pictures to their XP equivalents.
    • Changed: New images for the column sort arrows shown in the Queue window (Applies to all OS's prior to XP - XP handles arrows by itself). The previous ones were not very clear.
    • Changed: The icon on the DVDInfoPro buttons so it matches the new one used in the latest version of the program.
    • Changed: Samsung 'change book type' screen always used to say the current setting was DVDROM. This was 'forced' because the drive doesn't appear to report the current value. ImgBurn now tells it like it is.
    • Changed: BD-RE Full Erase code now also writes 0's to all the sectors on the disc. Unlike with DVD+RW erase, the drive doesn't do this automatically.
    • Changed: The exe is now compressed using UPX 2.92 (beta). This new version appears to fix the Windows 98 crashing bug that plagued it previously and UPX doesn't suffer from the XP crashes that PECompact does.
    • Changed: Update to using NSIS 2.23 for the installation program.
    • Changed/Fixed: There wasn't anything 'logged' when a file wasn't readable when building an image in 'Build' mode.
    • Changed/Fixed: Errors caught during the sync cache / disc finalisation stages were not taken into consideration when deciding if the burn succeeded/failed.
    • Changed/Fixed: Loads of stuff for Blu-ray media / burning. (BIG Thanks to SVP for letting me borrow a drive!)
    • Changed/Fixed: Some bits for HD DVD media / burning.
    • Changed/Fixed: Now only single session/track data discs can be processed by Read & Verify modes.
    • Changed/Fixed: Unless the user specifically overwrites an image in read/build mode, the MDS file will not overwrite an existing one with the same name - it'll rename / create a new one in the 'filename(x).ext' format.
    • Fixed: IFO parsing code wasn't processing VMGM / VTSM cell info properly (well, ok, at all!) and so they'd show up as non seamless when they shouldn't have in the layer break selection boxes.
    • Fixed: Build mode's layer break code was a little too good at skipping analysis of files it didn't think would work - as such, some perfectly valid potential layer break positions were missing from the dialog box.
    • Fixed: Bad/failed copies in a multi-copy queued burn were not being taken into account when decided whether or not to delete an image based on the 'Delete the image when done' setting.
    • Fixed: The Patin-Couffin I/O interface caused BSOD's on Windows 9x. This is probably due to changes in the driver as 9x used to use different code to NT. ImgBurn now uses the same code for all OS's. Tested with v36.
    • Fixed: UDF Version was displayed using OS's regional setting for a decimal place rather than being fixed as a '.' (dot).
    • Fixed: Drag + Drop of folders into the write queue could lead to duplicates if a .DVD and .ISO were present in the same folder and had the same name (well, first part anyway!).
    • Fixed: Times were wrong in layer break dialog for PGC's using multiple angles.
    • Fixed: Having 'Auto Calculate' enabled messed up builds initiated via CLI.
    • Fixed: The 'Verify Against Image File' option in the settings (Write tab) had no effect on the 'Build' Mode virtual image and so a verify always compared the burnt disc to the original data.
    • Fixed: Just adding VIDEO_TS type files to the source box in Build mode failed to build a DVD Video disc (after you answered 'yes' to say that's what you wanted to do). The operation was aborted instantly.
    • Fixed: /LOG CLI command didn't work if the program was already auto saving the log somewhere due to normal option in the settings (Events tab).
    • Fixed: Pasting text into ISO9660 volume label boxes allowed for characters that should have been restricted (it bypassed the normal checks).
    • Fixed: 'Weekly' and 'Fortnightly' were round the wrong way in the 'check for program update' option drop down box.
    • Fixed: Couldn't just specify a filename (no path) for the /SETTINGS CLI 'File Name' argument. It would save ok but wouldn't load.
    • Fixed: LBA offset was wrong in one of the UDF descriptors if the file descriptors for a given directory spanned multiple sectors. (Some OS's didn't then show all the files)
    • Fixed: Starting the build/write automatically via CLI could mean the autoinsert thread was run after it should have already been terminated. This could cause errors to pop up as the disc continued to burn (so not really damaging anything).
    • Fixed: Memory leak if you used the 'Create DVD MDS File' tool.
    • Fixed: Incorrect decoding of I/O errors when using the 'Write (12)' command.
    • Fixed: A couple of glitches in the GUI on Vista.
    • Fixed: A problem where the MD5 hash wasn't always calculated/displayed in the log after a burn/verify etc.
    • Fixed: The open file dialog boxes now have the places bar down the left hand side on Windows Me.
    • Fixed: 'Chapter' column in layer break dialog boxes was showing a number with a base of 0, instead of with a base of 1 - i.e. it was 1 too low!
    • Fixed: Layer break positions in the list view were only sorted by LBA and those with the same LBA could appear in the wrong order - LU / PGC / Chapter / Cell wise.
    • Fixed: Tools -> ISO -> 'Display IFO Layer break position' could start with part of an internal (to the program) string in the 'file' box.
    • Fixed: Open/Save File dialog boxes were not resizable.
    • Fixed: The AutoPlay (on insert blank cd/dvd) 'Burn Image / Build + Burn Image' entries were passing the drive letter with the '/SOURCE' CLI parameter rather than the '/DEST' one.
    • Fixed: Some memory leaks when closing the program down on Vista (with UAC enabled) due to it not being able to write certain registry entries.
    • Fixed: Lots of error catching code so Borland's internal exceptions are deleted properly and not 'leaked' when the program closes.
    • Fixed: Some issues to do with the 'DVDRAM / BD-RE FastWrite' option.
    • Fixed: Old CD-R/RW drives that don't report the current media properly would cause ImgBurn to prompt the user to select which type of media they wanted to erase - when CD-RW was the only one it could ever be.
    • Fixed: Discovery mode's 'Sectors' box wouldn't accept a large enough number for use on large discs - i.e. HD DVD, Blu-ray.
