ImgBurn - aktuelle Version
  • ImgBurn 2.3.0.0 ist raus. :)
    Changelog:
    Zitat von LightningUK!
    • Added: Parsing of the Joliet filesystem (in addition to the existing UDF/ISO9660 parsing) for pin pointing the file where a read error is occuring.
    • Added: Ability to have the program use erase/format commands where DVD-RAM and BD-RE disc then give their full capacity to the user data area and do not keep any 'spare areas' for error recovery. (Potentially useful for PS3)
    • Added: A little 'Erase' button to the main screen for easy access to disc formatting/erasing functions.
    • Added: Support for images with a 2332 byte sector size (Easy CD Creator v5 ?)
    • Added: Support for converting a few additional image formats over to the correct format for burning to DVD (Mode1/2048).
    • Added: Import / Export of 'Automatic Write Speed' configuration.
    • Added/Changed: If Build mode detects the file 'I386\NTLDR', it will automatically enable the ISO9660/Joliet options to allow file names without extensions.
    • Changed: When files/folders are dragged + dropped into the source list in Build mode, they're now added to the MRU list - but only if 8 or less items are added at a time.
    • Changed: When files added to the source list in Build mode via the 'Browse for file' button, they're now added to the MRU list - but only if 8 or less items are added at a time.
    • Fixed: Browsing for (and opening) a file (especially in 'Verify' mode) could fail due to some garbage being appended to the filename.
    • Fixed: A potential error when unlocking a volume from exclusive access when locking it had failed in the first place.
    • Fixed: File/folder names parsed from the ISO9660 file system could have garbage appended to them if there was no trailing null.
    • Fixed: Thread synchronisation issue where MD5 values might then be missing from the Log.
    • Fixed: The first cell in an angle block was being ignored and hence never shown in the 'Create Layer Break Position' window. (The first should have been visible, but not the others)
    • Fixed: The program displayed the incorrect 'previous' cell in layer break preview if the chosen cell followed one or more interleaved cells.
    • Fixed: UDF Filesystem didn't allow for the ';' character in file names.
    • Fixed: The 'Don't Prompt VIDEO_TS Content' option wasn't acutally using the answer specifed in the settings.
    • Fixed: The Filter Driver Load Order page was listing 'Upper Class Filters - [None Found]' for an item that should have said 'Lower Class Filters - [None Found]'.
    • Fixed: The wrong item in the Build mode MRU list could get deleted when the 16 item limit was reached. (Number 8 was deleted rather than number 16)
    Gibt's hier.
    Edit: Da die offizielle Seite seit Wochen immer mal wieder down ist, hier noch ein paar Spiegel die auch auf imgburn.com gelistet sind:
    Mirror1Mirror2Mirror3Mirror4
    Cu Rippraff
    Blumige Grüße, Rippraff
  • ImgBurn v2.3.1.0 Released!
    Changelog:
    Zitat von Lightning UK!
    • Added: 'Reset Settings' feature to the 'Options' tab in 'Build' mode.
    • Added: 'Read' support for discs (DVDRAM etc) formatted with the FAT16/32 file system.
    • Changed: Optimised the file system parsing code.
    • Changed: Set default write buffer size to 40MB for people with 1GB of RAM or more (actually set at 980MB rather than 1GB this time).
    • Changed: Set default path for IBG files to [APPDATA]\ImgBurn\IBG Files.
    • Changed: Set default path for LOG files to [APPDATA]\ImgBurn\Log Files.
    • Changed: The little 'DVDInfoPro' icon to the latest one - as taken from the program's exe.
    • Changed: Upgraded to NSIS v2.25.
    • Changed: Some internal workings of the 'Check For Program Updates' code.
    • Fixed: Access Violation error when doing an 'on the fly' DL burn in Build mode.
    • Fixed: DVDRAM discs formatted with FAT32 were always seen as 'empty' and so no 'overwrite' prompt was displayed if you tried to write to them.
    • Fixed: Old drives that don't report the track mode correctly in the TOC could then read normal Mode1/2048 discs to a Mode1/2352 image.
    • Fixed: Problem using numeric keypad to enter a custom number for 'sectors' in Discovery mode.
    • Fixed: The layer break preview application wasn't working correctly under win 9x (Problems in the CreateProcess/ShellExecute wrappers).
    • Fixed: The stars in the 'Select/Create Layer Break Position' window's list showed some odd graphics corruption under Win9x.
    • Fixed: UDF file system parsing code could get stuck in a loop.
    http://www.imgburn.com/index.php?act=news#news
  • ImgBurn v2.3.2.0 Released!
    This fixes a nasty bug in the previous version which messed up the detection of file formats/sector sizes - potentially leading to useless burns.
    Everyone using 2.3.1.0 should upgrade A.S.A.P. !
    • Added: Support for Lite-On drives to the 'Auto Change Book Type' feature.
    • Added: Loading an IBB via CLI no longer requires a path. It'll use the current working directory if one isn't specified, making it a bit more portable.
    • Added: '/OUTPUT' as an alternative to '/BUILDMODE' for a command line argument.
    • Added/Changed: If Build mode detects the file 'I386\NTLDR', it will automatically enable the ISO9660/disable the Joliet options of adding versions numbers to file names.
    • Changed: None of the build mode 'text' options will be changed if an IBB doesn't actually specify a value for that field.
    • Changed/Fixed: Disabled 'Auto Calculate' whilst adding files / folders to the source list from an IBB file specifed via the CLI.
    • Fixed: Incorrect signature matching (due to new FAT16/FAT32 file system detection code) on some images made them look odd sizes and have weird sector modes/sizes.
    • Fixed: Drag + Drop of a folder containing an .ISO and a .MDS file (of the same name*) should have been filtering out the ISO and just adding the MDS.
    • Fixed: The 'Remove All' button in the 'Write Queue' window wasn't being enabled when it should have been.
  • ImgBurn v2.4.0.0
    Released: 10th February 2008
    http://www.imgburn.com/index.php?act=download
  • ImgBurn 2.4.1.0 ist raus. :)
    Changelog:
    • Added: Support for the TAO write type as a real option rather than just a fallback if SAO fails.
    • Added: Support for burning APE/FLAC/WV files with an em_bedded CUE sheet as if they were normal image files.
    • Added: Accurate audio duration calculation (via a dummy decode pass just before the burn) leading to less gaps/padding and no missing audio data.
    • Added: Support for new booktype related options known as 'Active Setting' on NEC/Optiarc drives (to swap between the 'Permanent' and 'Temporary' setting)
    • Added: The ability to have the open/save dialog boxes always default to the folder specified in the 'File Locations' tab within the Settings window. (otherwise it'll default to the MRU one)
    • Added: 'New Project' option to the File menu in Build mode.
    • Added: When the program is unable to find any cells to use for the LB when buring a DL disc in Build mode, it now tells you extra info about which cell to split and where to do it.
    • Added: Support for reading discs recorded using the TAO write type.
    • Added: Context/popup/right click menu to the 'Add file or folder to source list' button in Build mode (the green +) with the option of 'Clear Source MRU List' on it.
    • Added: Options to enable/disable the success/error sounds after certain program functions.
    • Added: 'Show Non-Present Devices' option to the 'Automatic Write Speed' form when 'View By' is set to 'Device' (It's enabled by default).
    • Added: 'Translated By' field to the 'About' box.
    • Added: The ability to define the start LBA when building an image - useful for custom disc layouts.
    • Added: Variable 'PreGap Snapping' whereby gaps will snap to the nearest second (multiple of 75 frames) if within the specified range. (i.e. 1 second, 72 frames will snap to 2 seconds)
    • Added: If you don't enter a path for the file in Build/Read modes it'll use the 'Image Files' default one configured in the Settings (File Locations tab).
    • Added: You can type a relative path into Build/Read modes destination box and it'll resolve it when you click Write/OK.
    • Added: Saving a project file now writes the previously selected LB info from the 'Create Layer Break' window. This can then be used when loading the IBB via CLI so the user isn't prompted to pick a LB, thus allowing for batch builds.
    • Added: 'Don't Enable Sound' checkbox to the ImgBurnPreview options.
    • Added: A button in the settings to reset the burn statistics.
    • Added: 'Device.CDROM' Shell extension option where you get 'Read using ImgBurn' as an option when you right click on any CD/DVDROM drive. (It's off by default because windows appears to make it the default option - hence double clicking on the drive opens ImgBurn!)
    • Added: Option to turn off the funny quotes on the Ez-Mode Picker screen. (For people without a sense of humour ;) )
    • Added: The ability to sort tracks in the order of the 'Track Number' field in any available file 'Tag' within the 'Create CD CUE File' window.
    • Added: The ability to define a default folder for Project files (*.ibb).
    • Added: The ability to define a default folder for Language files (*.lng).
    • Added: Support for 'WavPack' files (*.wv) in the 'Create CD CUE File' window.
    • Added: A failed read of a sector in read mode now maps that sector to a file name and the result is shown in the log.
    • Added: Support for reading unicode file names in MDS v1.5+ files.
    • Added/Changed: When running in 'Portable' mode, certain paths will be saved relative to the exe's folder if they're at the same level or below it. (i.e. 'D:\ImgBurn\Sounds\Success.wav' becomes '.\Sounds\Success.wav')
    • Added/Changed: When build mode detects you're building DVD Video/HD DVD Video/Blu-ray Video/OS installation discs, it now tells you exactly which settings will be modified in the 'conflicting settings detected' message box.
    • Changed: When saving an project file, the initial file name is now taken from the image file name (but with an 'ibb' extension), falling back to using the volume label, then MRU value and finally just 'My Project.ibb'.
    • Changed: Handling of manually entered file names in build/read mode to parse environment variables.
    • Changed: Updated ImgBurnPreview.exe to the latest code - this one has support for audio.
    • Changed: If the bootable image (in Build mode) isn't a multiple of 512 bytes in size, the user can now choose to proceed anyway.
    • Changed: Tweaked some of the TOC parsing code to work around bugs found in certain drives.
    • Changed: Tweaked the UDF file system parsing code to minimise the amount of random access reads and potentially speed up the process by a substantial amount when lots of files are present.
    • Changed: You can now build 'pure' bootable images/discs without having to add a 'dummy' file to the source box.
    • Changed: The 'Restore Defaults' button in the settings now resizes itself to fit the string.
    • Changed: The 'Languages' list is now sorted alphabetically.
    • Changed: Limited the initial height of the 'Create CD CUE File' window to that of the desktop area (for people using 800x600 and below where it wouldn't quite fit on the screen).
    • Changed: Settings screen is now wider to better accommodate longer translated strings.
    • Changed: The buttons on the 'Filter Drivers' screen now auto-resize themselves to fit the translated string.
    • Changed: The 'Create MDS' windows now uses picture buttons for Add/Remove/Move etc just as the 'Create CUE' window does.
    • Changed: All controls have been changed to the 'TTnt*' unicode style so you can use/view a properly translated GUI on a normal 'English' Windows install.
    • Changed: The folder 'IBB Files' now defaults to using the name 'Project Files'.
    • Changed: The folder 'IBG Files' now defaults to using the name 'Graph Data Files'.
    • Changed: The folder 'IBQ Files' now defaults to using the name 'Queue Files'.
    • Changed: Moved some of the 'select a folder' type options in the settings to a new 'File Locations' tab.
    • Changed: The 'Start' button in Read mode is no longer disabled when CSS/AACS protected media is detected. There's just a warning that it won't work (warning can be disabled in the settings).
    • Changed: Date/Time pickers in Build mode now display the selected date/time according to the 'Short Date' format as found in Regional Settings within Control Panel.
    • Changed: Log entries for 'File System(s)' no longer translate the 'None' word when there's no file system present in the image. (The Log is supposed to be English)
    • Changed: Removed the need for a second basic parsing of the file system on the disc when in Read mode (as the automatic destination file name was generated).
    • Changed: Under Vista/2008, the Volume Label displayed by ImgBurn is taken from the 'File Set Descriptor' (when set) rather than the 'Logical Volume Descriptor' to match the behaviour of Windows.
    • Changed: 'DVD+R Reserve Track' is now enabled by default.
    • Changed: 'Perform OPC Before Write' is now disabled by default - it errored out on too many drives.
    • Changed: Removed the pre-read/verify 'Samsung Set Magic Speed' option. It was often slow to complete and not very well supported by some Samsung drives.
    • Changed: Optimised the code that checks for interfering programs so they're all done at the same time rather than individually.
    • Changed: Updated the code that checks for interfering programs to look for newer versions of DVD43.
    • Changed: Prompt user if auto retries of tray cycling still don't make the drive initialise the disc properly between write and verify.
    • Changed: Handling of the 'Delete the image when done' option when the image is a CUE file. The user can now delete the CUE without deleting the files it calls upon (if more than 1).
    • Changed: The 'Open/Save As' file dialog boxes within the Log window now default to the 'Log Files' file location as specified in the settings.
    • Changed: The 'Open/Save As' file dialog boxes for IBB, IBG, IBQ and LOG files now default to the appropriate folder - as specified in the settings.
    • Changed: Some of the messages that can pop up when performing 'Display IFO Layer Break Information' on a drive so that they're appropriate for a drive rather than an image file.
    • Changed: Updated ImgBurnPreview to v1.1.1.0 - Based on Jeanl's latest code.
    • Changed: The log entry for 'BookType' now displays the permanent setting unless the 'Active Setting' is actually set to 'Temporary', in which case it displays the temporary one!
    • Changed: Modified the names of the 'Browse for...' entries on the 'File' menu to make them less confusing.
    • Changed: 'Read Disc Information' command reverted to asking for 32 bytes of data, not 34. (Some dodgy drivers appear to hang when it's 34)
    • Changed: Updated the installer to NSIS 2.36
    • Changed/Fixed: Removed the double image file initialisation when trying to burn the currently selected file in Write mode when it wasn't actually marked as 'Queued' in the Write queue (i.e. having already burnt it).
    • Changed/Fixed: The 'Automatic Change Book Type' option for NEC drives now sets the 'Active Setting' to 'Temporary' so the correct value is actually used.
    • Changed/Fixed: Tweaked some of the code that deals with expanding relative paths passed via CLI or stored within IBB project files.
    • Changed/Fixed: Most of the forms are now dynamically created at runtime as and when need. This cuts down on the resources used by ImgBurn (especially GDI objects) and speeds up the loading time. (GDI object count is down from ~1100 to ~550)
    • Changed/Fixed: CD-TEXT options/controls in the 'Create CD CUE File' window are now disabled when the selected track isn't an audio track.
    • Changed/Fixed: Silently fail (failure is still logged) when MCN control fails with the 'ERROR_NOT_SUPPORTED' error code.
    • Changed/Fixed: Potential workaround for drives that hang when being queried to see if they support labelflash.
    • Changed/Fixed: Better ACM 'acmStreamConvert' handling so the program knows when all the data has been converted (even when buffered under Linux/Wine).
    • Changed/Fixed: When verifying, if the track on the disc is smaller than the one in the image file the user is asked if they want to continue or not. If they choose to, the disc's track is padded out (zero filled) to the size of the image file's track so that the verification process works properly. (otherwise it would just sit there waiting for more data that was never coming)
    • Changed/Fixed: Don't add the current image file name to Write mode's 'Recent Files' list when a 'Read' operation fails.
    • Changed/Fixed: The 'Delete image' button on the 'Insert next disc' window didn't prompt the user when deleting multiple files (like in a CUE with lots of audio tracks).
    • Fixed: Incorrect handling of 'desktop' at the start of a destination image file path in Build/Read mode if it was followed by another folder name - i.e. 'desktop\new image\image.iso'
    • Fixed: The default paths (i.e. before any settings have been read) were incorrect when loading the program with the '/PORTABLE' CLI switch.
    • Fixed: When writing a multisession disc, the 'Writing Session X of X' and 'Writing Track X of X' log entries weren't always being written if the session/track was small.
    • Fixed: A bug when attempting to send a CUE Sheet to the drive ending in the error 'SendCueSheet Bug! - CueSheetVariant 13' being shown.
    • Fixed: Wrong 'REM LEAD-OUT' entry in *.cue file when created using the 'Create CD CUE File' window.
    • Fixed: Better support for old drives that want weird LeadIn/LeadOut 'DataForm' values (non MMC compliant values) in the 'SEND CUE SHEET' parameter list.
    • Fixed: A bug preventing the 'Logical Volume Identifier' field in the 'File Set Descriptor' from being updated when changing the volume label of an image.
    • Fixed: The Layer Break 'Preview Selected Cell' feature didn't always work when working with Image Files/Drives - the preview window would take ages to appear and the 'ImgBurnPreview.exe' process would need terminating via Task Manager.
    • Fixed: Problem with analysing track pregaps on drives that fell back to using the 'Read Sub-Channel' command when 'Read CD' failed.
    • Fixed: Various problems when using the legendary 'old skool' Plextor SCSI CD-ROM drives.
    • Fixed: When SAO wasn't available and the program fell back to using TAO, multi track images weren't burnt correctly. (They came out as 1 long track because I'd made no effort to make it work properly!)
    • Fixed: The 'Add file or folder to source list' button in Build mode was being enabled after 'Calculate' even when there was no text in the field to it's left.
    • Fixed: Access violation when you're in Build mode with Device output and you press 'Cancel' on any of the prompts that come up before the build actually starts.
    • Fixed: A problem where ImgBurn could get stuck at the start of a read/verify operation.
    • Fixed: When reading a disc using only ISO9660/Joliet file systems (no UDF) from DVD+RW/DVD-RAM/BD-RE the image would be 1 sector too short.
    • Fixed: Divide By Zero bug if you terminate a verify operation whilst it's still analysing the tracks on a CD.
    • Fixed: Memory leak if you cancel the 'Open' file dialog box from within the Log window.
    • Fixed: A problem where a file name such as 'desktop\image' in the Read mode destination box was not being parsed correctly to have 'desktop' replaced AND the '.iso' file extension added.
    • Fixed: The 'ACM' audio decoding fallback method wasn't working - acmStreamConvert failed.
    • Fixed: CD-TEXT info at 'Disc' level wasn't always added to the CUE file made by the 'Create CD CUE File' feature.
    • Fixed: When warned that 'Test Mode' *might* not work with the current media (and the user accepted the warning), it was actually being turned off rather than being left on.
    • Fixed: The 'Changer Control' buttons were sometimes being disabled when they shouldn't have been.
    • Fixed: 'Retrying (x of y)...' was wrong in the log when close track/session/disc failed at the end of the burn. x was always 1 number too big.
    • Fixed: No image being added to the combobox on the medium changer control window when running under Vista.
    • Fixed: The 'Medium Changer Control' feature didn't work properly on Vista/2008.
    • Fixed: Incorrect file name sorting in the ISO9660 file system - files starting with '_' came before the others using 'A-Z'. (This prevented WinXP install discs from working)
    • Fixed: Memory leak when loading a CUE containing multiple index points for the same track.
    • Fixed: Read modes 'Default Destination - MRU' option wasn't working.
    Gibt's hier wie auch die deutsche Sprachdatei.
    Cu Rippraff
  • http://www.imgburn.com/index.php?act=changelog
    2.4.2.0 Released: Tuesday 22nd July 2008
    • Added: The program now identifies that you might be building an OS installation disc before scanning the directory structure in a similar way to that used for DVD Video etc. (i.e. if you add a single folder to the source box it will look for an I386 folder within it).
    • Added: Code to try and detect HD DVD and BD Video files in the 'Source' box within Build mode in the same way the program currently detects DVD Video files.
    • Added: If you hold down 'CTRL' when clicking the 'Image Information' button, the program will do a dummy decode pass on any audio files that make up that image to get an accurate duration rather than using DirectShow's GetDuration() function.
    • Added: Current LBA to the log entry when buffer recovery kicks in.
    • Added: You can now double click the layer break list entries to preview them.
    • Added: Support for 'MPA' as a known file extension for Audio files.
    • Added: Code to detect and warn about audio files that decode to digital silence.
    • Added: 'Show Information' option to make the ImgBurnPreview program show the information window automatically.
    • Added: New 'Drop Zone' for Build and Write modes. You can drag and drop folder/files to the 'stay on top' window without having to bring ImgBurn to the foreground all the time.
    • Added: Support for writing unicode names into MDS files and a new 'Create MDS - Save As Ansi File' option to go with it.
    • Added: New 'Don't Prompt Delete Files' option (with Yes/No answers) to the Write tab in the settings.
    • Added: New 'Show Real Size (1:1)' option for the previewer.
    • Added: New 'Don't Use Immediate I/O' option to the I/O tab in the settings.
    • Added: New 'Prevent Entering StandBy' option. When enabled, ImgBurn will attempt to stop the machine going into standby whilst it's burning.
    • Added: Workaround for Plextor PX-116A3 (FW 1.01) returning a single descriptor in the Formatted TOC.
    • Added: Detection of x64 versions of Vista.
    • Added: Support for patching the '\isolinux\isolinux.bin' file in Build mode with the correct 'boot information table' data.
    • Added: Option to not auto retry when the close track/session/disc commands fail.
    • Added: Additional error messages to the code that deals with loading CUE files.
    • Added: When the close track/session/disc commands fail, you're now given Abort/Retry/Ignore options in the message box rather than just Retry/Cancel.
    • Added: BenQ 'Clean EEPROM (Learnt Media)' option to the Advanced Settings windows.
    • Added: Choice of 'None' for the 'Shutdown Action' option in the settings - for people that click 'Shutdown when done' accidently and don't want it to do anything when they do.
    • Added: Additional logging when erase disc fails on CD-RW/DVD-RW/HD DVD-RW media.
    • Added: Additional error messages and logging to code the deals with analysing audio files.
    • Added: Option to automatically ignore failures when the close track/session/disc commands fail.
    • Added: Improved detection of DVD/HD DVD/BD Video content when detecting conflicting settings in build mode.
    • Added: Automatic creation of the 'CERTIFICATE' folder on Blu-ray Video disc in the same way the program automatically creates the AUDIO_TS folder on DVD Video discs.
    • Added: Support for (a version of) relative paths within MDS files.
    • Added: The 'Create DVD MDS File' feature will now store the relative path (assuming images are in a folder below the MDS) in the MDS rather than just the file name.
    • Added: The disc information text on the right of the main window now contains the 'Physical Format' information for each layer on double layer media.
    • Added: The 'Create DVD MDS File' feature now has the ability to specify the Track Path for a double layer image (PTP or OTP).
    • Added: Regardless of the number of (silent) retries performed when attempting to lock the drive for exclusive access (it normally does 10), if it's been trying for more than 30 seconds the program will error out just as soon as it regains control.
    • Added: Media profiles for DVD-5 and DVD-9 to Build mode (useful for mastering).
    • Added: Detection of BD Video content based on the BDAV folder (rather than just BDMV)
    • Added/Changed: When setting the media type for the directshow conversion, the program now falls back to using WAVE_FORMAT_EXTENSIBLE if WAVE_FORMAT_PCM fails. This means filters that don't support WAVE_FORMAT_PCM should now work.
    • Changed: The 2 leftmost buttons (ignore and preview) on the select/create layer break windows now dynamically resize/reposition themselves base on their caption. (This is better for translated text)
    • Changed: When setting write parameters, the 'Write Type' no longer uses fall backs - this was very messy and caused its own set of problems.
    • Changed: Workaround for when DS filters (or the libs they use) don't like SetPosition(0) when they're already at the start - issuing it can lead to missed audio samples.
    • Changed: The 'Temporary' booktype option no longer falls back to displaying the 'Permanent' setting if it's not supported.
    • Changed: Removed one set of calls to the 'Init DirectShow' function that would happen just before a dummy decode pass was run on the audio files - so it's a bit quicker now.
    • Changed: Updated ImgBurnPreview to v1.1.6.0.
    • Changed: Verify won't go ahead if the drive reports the track contains 0 sectors - otherwise the program would generate dummy data for the entire thing and that's 110% pointless!
    • Changed: Max buffer size is now 512MB.
    • Changed/Fixed: Made tweaks to ACM MP3 file parsing code to make it more reliable when searching for the frame header and to prevent a potential divide by zero error.
    • Changed/Fixed: Image/Media Information window is closed if the program fails to initialise the image.
    • Changed/Fixed: When building an OS installation disc, the DOS character set is now used and not ASCII.
    • Changed/Fixed: Improved support for writing Mode 2 tracks in TAO mode.
    • Changed/Fixed: Attempt to workaround drives reporting first track in a session starting before the actual session.
    • Changed/Fixed: Attempt to workaround decoded files that fall short of their estimated durations and cause any trailing/appended pregaps ('INDEX 0' markers in a CUE file) to mess up the internal image layout - which then leads to an error when sending the cue sheet to the drive at burn time.
    • Changed/Fixed: When Previewing a Cell for the LB, the audio stream is no longer forced to 0x80, the program takes the number from the IFO.
    • Changed/Fixed: The 'Create DVD MDS File' function always made MDS files with the Track Path set to PTP.
    • Fixed: Removed the very well camouflaged button in the booktype window.
    • Fixed: Drive related buttons being enabled when no devices are present if you perform certain operations.
    • Fixed: What I believe to be a bug when trying to determine if a single source folder was anything to do with a BD video disc.
    • Fixed: The total count of file/folder names modified due to current settings wasn't 100% accurate due to the file name comparison not being case sensitive.
    • Fixed: Bug converting sector mode/form/size to an internal data type.
    • Fixed: Some odd issue when decoding certain letters (character codes) within CD-TEXT data on a disc or in a *.cdt file. (It would display a square box for the letter)
    • Fixed: WavPack files were not being decoded during burning, they were being read as if they were PCM/RAW audio files.
    • Fixed: Incorrect 'Last Physical Sector of Data Track' value within MDS files for OTP discs.
    • Fixed: Aborting on an error during the audio file analysis stage didn't actually abort anything and having aborted, the error condition meant that future analysis wasn't carried out.
    • Fixed: Potential problem where ImgBurn might check for updates more often than it should do because the 'last update check' value isn't parsed correctly due to regional settings.
    • Fixed: The 'Write Queue' window wasn't being close when going between 'Write -> Read' or 'Write -> Ez-Mode Picker' modes.
    • Fixed: When converting the volume label from one file system to another (or applying a CLI specified one), the resulting name could turn out to be shorter in length than actually permitted.
    • Fixed: Problem where 'DecodedSize == 0' error could appear when DirectShow decoding failed and ACM worked.
    • Fixed: Building a DVD/HD DVD/Blu-ray Video disc didn't work properly if the files were in the root folder of a drive and the root folder was added to the 'Source' list.
    • Fixed: Odd looking configuration message if a root folder was added to the 'Source' list in Build mode and the folder contained DVD/HD DVD/Blu-ray files.
    • Fixed: WMA Tag parsing wasn't working - messed up text strings due to reading them with the wrong byte order.
    • Fixed: Incorrect values in 2nd layer descriptor within MDS for OTP discs.
    • Fixed: ImgBurn not respecting 'Top' and 'Left' coordinates of the desktop (i.e. the area excluding the taskbar)
    • Fixed: One rogue structure used when parsing the UDF file system was limiting the file size to 32 bits (DWORD), meaning any file over 4GB would have been displayed incorrectly size wise. (Only caused a problem when mapping sectors with errors to file names in Read/Verify mode)
    • Fixed: Memory leak if dummy audio decoding pass fails.
    • Fixed: Adding the content (files/folders) of a normal BDMV folder to the source box in Build mode didn't create the proper BD structure.
  • Doch auch mal wieder 'ne neue Version. Releases am 1. April sind gefährlich... man nimmt sie nicht immer so ernst. :D
  • ImgBurn 2.5.0.0 ist da :)
    http://forum.doom9.org/showpost.php?p=1308864&postcount=1
    Der Changelog sit wie immer riesig:
    • Added: An 'Advanced' input mode to build mode where you have total control over the layout of the disc and can add new folders, change names etc. (i.e. you're no longer limited to burning an existing folder structure on your hard disc as-is)
    • Added: Optional logging when hidden or system files/folders are skipped in Build mode due to the current settings (i.e. when 'Include Hidden Files' or 'Include System Files' are disabled).
    • Added: Yet another attempt at setting the write speed - this one does it 100% by the book. It fills the fields in the performance descriptor sent via 'SET STREAMING' with the values returned in the descriptor after issuing the 'GET PERFORMANCE' command. (The previous best method of setting the speed missed one field out)
    • Added: An option (off by default) to enable the enumeration of medium changer devices (this was previously always enabled) on the I/O tab in the Settings.
    • Added: Support for enumerating medium changer devices via the SPTI 'Device Interface' method too - previously it was always done by 'Device Class'.
    • Added: The graph data preview in the Settings now uses a default value for media/volume id if one isn't available based on the current media/image file.
    • Added: Support for another IOCTL for locking the drive - this one (only) appears to work with the 'Device Interface' enumeration method of the SPTI I/O interface ('lock volume' doesn't).
    • Added: Support for using 'Opti Drive Control' as the IBG viewer when you click the 'Display Graph Data' buttons/menu option.
    • Added: ImgBurn now adds itself to the context menu's 'Open With' submenu for files it's associated with.
    • Added: Debug logging to the function that compares the image file/disc layouts.
    • Added: Option to disable the 'Fix VTS Sectors' function when building a DVD Video disc.
    • Added: The 'Create DVD File' feature can now make DVD files with the MediaType field set to 'CD'.
    • Added: Support for saving plain MODE1/2048 discs as a MODE1/2352 image in Read mode by saving as a BIN/IMG file.
    • Added: Support for converting a MODE2/FORM1 track (on a single session/track disc) into MODE1 when reading a disc so it can be stored in an ISO file.
    • Added: Support for burning CCD files.
    • Added: Support for adding files that exceed the limit imposed by the ISO9660/Joliet file systems. Those file systems will record the file size as 4GB (-1 byte) but all their data will be physically present in the image. The UDF file system will use the correct size.
    • Added: Support for building images using the 'MODE2/FORM1/2352' data type. (previously it only supported 'MODE1/2048')
    • Added: Warning when user attempts to read a 'complex' disc to an ISO file and option to use BIN instead.
    • Added: Support for using 'BurnPlot' as the IBG viewer when you click the 'Display Graph Data' buttons/menu option.
    • Added: Advice in the log window (on how to remove the virus) for when the 'maximum number of secrets exceeded' error in encountered when searching for devices (and 0 drives are found).
    • Added: Mini lookup table for some CD disc ID's to get manufacturer info. This info is now show in the disc information panel (under ATIP Information) and also in the log when you erase a disc or burn one.
    • Added: Option to stop the program from analysing (doing the dummy decode pass on) cd-da ready wav files.
    • Added: Show the booktype in the log when reading a disc in Read mode.
    • Added: A check to ensure all the DVD Video files in a sequence are present. (i.e. it'll prompt if VTS_XX_1.VOB and VTS_XX_3.VOB are present but VTS_XX_2.VOB isn't)
    • Added: It now does a basic parse of any supported 'Special' file system on a disc when in Read mode so it can display a volume label (to match what you'd see when loading an image of said disc into Write mode).
    • Added: 'Write Speed Miscompare!' warning in the log when the drive reports a write speed that doesn't match what the user selected.
    • Added: Error balloon when user tries to enter an unacceptable character in the 'Rename' box when replacing/overwriting files.
    • Added: Error checking (and logging) when searching for folders/files (via 'FindFirstFile'/'FindNextFile') and adding them to the image in Build mode.
    • Added: Detection of attempts to build Vista style OS installation discs (via the 'sources\install.wim' file) and the relevant prompting for conflicting settings, failing to make it bootable etc (same as an 'I386' install disc).
    • Added: 'Explore' and 'Open' options to the 'Source' box's context menu in Build mode.
    • Added: You can now control which 'image layout' files Build mode creates via its own set of options (rather than piggy backing the Read mode ones)
    • Added: Ability to select the media type when creating an MDS file via the 'Create MDS File' feature.
    • Added: Ability to select the font used by the program's GUI.
    • Added: New CLI parameter '/CERTIFICATEFOLDER ' to tell the program if it should attempt to include/create a CERTIFICATE folder when a BDAV/BDMV folder is present.
    • Added: Sanity checking for most of the comboboxes - to catch errors in translations where they don't notice I've added new entries!
    • Added: 'Average Write Speed' to the log when full erasing a BD-RE disc with 'perfer properly formatted discs' enabled - i.e. so it performs the 'Zeroing Sectors' part.
    • Added: Workaround for a bug in Windows 7 (7077 anyway) where the PlaySound API will bring up an 'insert disc' error box if the current working directory is no longer valid (i.e. it was set to an optical drive and the disc has been ejected).
    • Added: Workaround for drives/drivers that randomly report a bogus error ('No Additional Sense Information') during the burn, thus forcing a retry - which fails with the error 'Invalid Address For Write' because those sectors HAVE actually been written ok - according to the track's NWA info anyway.
    • Added: The option to read/write CD-TEXT using the Ansi code page rather than ISO 8859-1.
    • Added/Changed: The log entry/error box that pops up when 'send cue sheet' or 'set write parameters' fail now includes a 'reason' in the form of the decoded sense area message.
    • Added/Changed: The ISO9660 Volume Label will now accept characters based on the current ISO9660 character set selection.
    • Added/Changed: Had a go at making all the Build mode question type messageboxes simpler and translatable.
    • Added/Changed: Tweaked and cleaned up the file search code when loading CUE files. It now supports relative paths.
    • Changed: The installer no longer offers the 'Quick Launch' option when Windows 7 is detected as an OS.
    • Changed: The SPTI device enumeration method now defaults to 'Device Interface' on XP SP2/2003 SP2 + IMAPI v2.0, XP SP3, Vista and newer.
    • Changed: The SPTI device enumeration method 'CdRom Class' is now known as 'Device Class'.
    • Changed: The 'CERTIFICATE' folder is no longer created for Blu-ray Video discs by default. This means the programs creating the file structure have more control over whether one gets added or not.
    • Changed: Tweaked all the code for file associations to make it more compliant with Microsoft's documentation. (The installer cleans up the old ones so make sure you use it!)
    • Changed: Tweaked the code used to determine the drive's current write speed before then displaying the 'Write Speed Miscompare' message (I blame the buggy drive firmware!).
    • Changed: Tweaked the code that positions forms when they open (in the middle of the main form) so they're no longer drawn a few pixels off the screen (assuming the main form is along the edge) when desktop composition is enabled under Vista / 7.
    • Changed: Tweaked the code that positions forms when they open (in the middle of the main form) so they're opened on whichever monitor their 'centre point' is on (or the nearest to it).
    • Changed: Tweaked some of the functions associated with the ISO9660 file system's volume label so they handle characters with extra bits like accents a little better and hopefully reduce the number of '_' characters that end up being used.
    • Changed: Even when set to 'No', the DVD/MDS layout files will still be created (if they're selected in the first place) when multiple output files have been created (i.e. file splitting has been used).
    • Changed: Tweaked the way fields in the Joliet volume descriptor are read to hopefully deal with buggy descriptors (like those written by XP's built in burning software) where the fields don't contain Unicode text.
    • Changed: Updated the Virtual TreeView control to the latest on SVN.
    • Changed: Ignore failure to set the layer break position (when changeable or not) if the desired position is where the drive reports it is already . Previously it only ignored the failure if the position was the same and wasn't changeable.
    • Changed: Tweaked some of the code that sizes and positions controls based on the current translation.
    • Changed: The information window shown when building the image/calculating its size in Build mode can now be translated.
    • Changed: The custom strings inserted into system / application menus can now be translated.
    • Changed: When loading a CUE into the 'Create CUE File' feature, the program will now warn you if track/index info will be lost (i.e. if a file is used for more than 1 track or a track has more than 1 index).
    • Changed: Renamed 'Create CD CUE File' feature (and associated buttons/tooltips etc) to 'Create CUE File' so it matches with 'Create DVD File' & 'Create MDS File'.
    • Changed: Rewrote all the code that deals with when to create/not create CCD/CUE/DVD/MDS files. Each one is handled individually now.
    • Changed: Modified that MDS file slightly when building an image with a BDAV/BDMV folder in it (so it'll play when mounted in DT).
    • Changed: Since adding support for CCD/CUE/DVD, the 'Create MDS File' term/option in the Settings didn't really fit - so it's been renamed to a more generic 'Create Image Layout File'.
    • Changed: The 'Filter Drive Load Order' feature now scans for and lists device class filters found in all the relevant 'CdRom' keys under 'HKLM\SYSTEM\CurrentControlSet\Enum\[IDE|SCSI|USBSTOR|1394]' rather than just the first one it finds with an 'UpperFilters/LowerFilters' entry.
    • Changed: The 'Filter Drive Load Order' feature can now remove 'Upper/Lower Device Class' filters.
    • Changed: When burning a CD, the program will now also issue the 'SET STREAMING' command (where supported and in addition to the existing 'SET CD SPEED' one) to set the write speed.
    • Changed: 'FastWrite' no longer applies to BD-R, the new option 'BD-R Verify Not Required' now takes its place.
    • Changed/Fixed: Tweaked the 'Title Case' function to handle certain strings a bit better.
    • Changed/Fixed: Implemented a workaround for Windows 7 whereby ImgBurn prompts 'Do you really want to cancel?' if it's open when you try to restart/shutdown the computer.
    • Changed/Fixed: The program would only use the layer break position in an IBB if the /CLOSE switch was issued via CLI, /CLOSESUCCESS wouldn't work (and it should have done).
    • Fixed: Clicking 'Cancel' to certain build mode prompts (that correct conflicts/settings) didn't prevent some other prompts from popping up.
    • Fixed: Initial disc space check when doing a 'Read' operation didn't take into account the wave header when outputting an audio cd to a wav file.
    • Fixed: The MD5 was incorrect when reading an audio disc to a *.wav file.
    • Fixed: Incorrect / missing drive letters when using 'Device Interface' SPTI enumeration.
    • Fixed: The 'Device Interface' SPTI drive enumeration method didn't work on Vista (drive letters would have been used as a fallback).
    • Fixed: A little bug (they you'd be very unlikely to run into) in the function that compares the layout of an image file to the layout of a disc in terms of sessions, tracks etc.
    • Fixed: A problem where code (specific to 'Image File' output mode) was being called for something that only applies to Device output mode. This was to do with changing the data type to 'MODE1/2048' if the current disc was DVD/HD DVD/Blu-ray.
    • Fixed: Problem with reporting the correct error code in the booktype setting tool on the 'LiteOn' tab if the drive doesn't support any of the 3 different I/O command versions (it would always just return 'No Additional Sense Information').
    • Fixed: The wrong 'Free Space' was/could be displayed in Build mode (image file output) if the destination was set to 'desktop\[*.*]' and the desktop folder was on a different drive to the 'Image File' one configured in the settings.
    • Fixed: A problem with some code that decides if a CCD file should be created or not.
    • Fixed: A few problems with the creation of CCD files (wrong values in certain fields) - mainly when doing multisession.
    • Fixed: Incorrect start time of Indexes >= 1 in a CUE file when any sort of pre/postgap was also present.
    • Fixed: If the 'unlock volume' (exclusive access) function failed after an erase, the program logged that the erase had failed - when actually it hadn't. Also, if the erase had failed but the unlock succeeded, the program logged that the erase was successful.
    • Fixed: The volume label tooltip on the Read mode progress screen was showing 'Unknown' for fields that it shouldn't have been.
    • Fixed: Problem where the program opens the drive whilst in the middle of a temporary open/close which leads to the drive being left in a 'closed' state ('invalid handle' message in the status bar) and potentially leaves an orphaned drive handle which prevents the program from being able to lock the drive for exclusive usage.
    • Fixed: Labels were not displaying the '&' character properly in the 'Image Information' box.
    • Fixed: List out of bounds error when changing the language.
    • Fixed: Bad text width calculation (due to font changes) when positioning controls.
    • Fixed: Task status wasn't updated from 'Fixing VTS Sectors' to 'Getting Region Information'.
    • Fixed: An issue where some internal stuff got messed up as a result of the program prompting to include ADV_OBJ / CERTIFICATE folders (but only if the user said 'Yes').
    • Fixed: Multi-monitor issue where forms centred over the main one could be displayed slightly off the screen.
    • Fixed: A call to the SystemParametersInfo(SPI_GETNONCLIENTMETRICS) API function was failing on pre-Vista OS's and so the GUI font might have been different to previous versions of the program - shouldn't have been an issue for people using the default OS fonts for everything though.
    • Fixed: Bogus 'Destination' text (parent folder of the *.IBB) when loading a project in Build mode where the Output is set to 'Image File' and the destination field is blank.
    • Fixed: Clicking the 'Close' (X) button in the preparing image / building image tree boxes closed the window but didn't actually stop the program from doing what it was doing.
  • ImgBurn 2.5.1.0 ist da :)
    http://forum.doom9.org/showthread.php?p=1383640#post1383640
    Der Changelog:
    • Added: 'Explorer' style file manager pane to the top of the Disc Layout Editor window (can be disabled via a button on the existing toolbar).
    • Added: New 7.95GB, 23.3GB and 46.6GB file splitting options so the individual image file parts can be archived on DVD+R DL, BD-R or BD-R DL media.
    • Added: An option so the user can control whether or not the program will not halt logging after 'too many' (1000) messages.
    • Added: Option in the settings to automatically make the Disc Layout Editor window 'stay on top' (joins the existing one for the Write Queue window).
    • Added: The user can now decide if 'Reparse Point' (A.K.A 'Junction') files/folders are included when scanning for files/folder to add to the compilation.
    • Added: Option to prevent the program from blocking AutoPlay when it receives the 'QueryCancelAutoPlay' message from the OS (probably only when it's in the foreground).
    • Added: Support for detecting when the user might be attempting to build a DVD Audio disc.
    • Added: Automatic change booktype support for the LiteOn drives using the NEC chipset ('iHASxxx Y' rather than 'iHASxxx A')
    • Added: Added additional bits of information to the disc information panel on the right.
    • Added: Support for a couple of other locations for the isolinux.bin file when trying to determine if it should automatically patch the boot-info-table.
    • Added: When the program fails to create a directory for the destination file in Read/Build modes, it'll now mention the reason rather than just saying it couldn't do it.
    • Added: Debug code for the functions that deal with the Taskbar's progress bar type feature under Windows 7.
    • Added: 'Reset DMA' feature to the 'Tools' menu. It's just an internal version of the 'ResetDMA.vbs' script found on the Internet.
    • Added: 'Reset Change Counter' option to the booktype feature for NEC drives. This resets the 'Changes Available' counter back to 500 and the booktype options to factory defaults.
    • Added: Support for reading MCN and ISRC information via other (and more reliable, especially on LiteON drives - will they ever fix the firmware bug?!) means.
    • Added: Support for reading ISRC information on some older devices that aren't quite as MCC standards compliant as was previously required.
    • Added: Blu-ray disc information to the disc info panel on the right.
    • Added: The 'N/A' text can now be translated.
    • Added: The default 'UNDEFINED' volume label can now be translated.
    • Added: Detection of/warning for HDD images without MBR - these cannot be used when making a bootable disc, the MBR must also be present.
    • Added: New 'errorlevel' return codes for use with CLI. (4 = Build/Read/Write aborted, 5 = Verify aborted)
    • Added: Support for the Acronova 'Nimbie' series of auto loaders.
    • Added: A new log entry to show the effective write speed.
    • Added: A workaround for buggy LG drive firmware (first noticed with my GGW-H20L@FW:YL05 - tried to contact LG twice but they ignored me) when issuing the 'GET PERFORMANCE' command with CD media in the drive.
    • Added: You can now decide between single and multiple extents when allowing files that exceed 4GB in the ISO9660/Joliet file systems. (Single fakes the size to 4GB, Multiple allows for the full size but isn't compatible with all parsers)
    • Added/Changed: Wipe out old 'HKEY_CURRENT_USER' file association stuff if HKEY_LOCAL_MACHINE is writable.
    • Changed: The installer now has a checkbox to reset the settings rather than using a message box.
    • Changed: When adding a >4GB file in Build mode, the program now prevents ignoring the ISO9660 maximum file size if 'single extent' method is selected and the UDF file system isn't being included (i.e. you're left with no way to access the entire file).
    • Changed: No longer using the TOC information for the disc layout when reading DVD/HD DVD/BD disc, the information reported by the 'Read Disc/Track Information' commands is used instead.
    • Changed: Don't prompt for certain DVD Video related stuff if the VIDEO_TS folder is empty. (Gets around the double prompts when doing a homemade HD DVD Video disc with dummy/empty VIDEO_TS folder)
    • Changed: The Device MD5 in Verify mode now includes zeroed data for session gaps (as already used in Read mode - thus hopefully making them report the same MD5 for a disc!).
    • Changed: Tweak within the installer for the 'AllocateCDRoms' registry value on x64 OS's.
    • Changed: The 'Disc ID' button in the AWS window is now disabled when there's no active drive.
    • Changed: Moved the Yes/No/Cancel buttons on the 'Confirm Volume Label' form over to the right (same as the other forms now) which allows more room for the 'Auto Yes in X seconds' text on the left.
    • Changed: Searching for 'Medium Changers' (and also 'Auto Loaders') is now its own function and gets logged independently from the normal SCSI/ATAPI device scan.
    • Changed: Rewrote the code that sets the write speed so it now sets the speed and checks it against the selected speed properly before then trying fallback commands if there's a mismatch.
    • Changed: Tweaked the way the program handles discs where (according to the TOC) track 1 starts in what should be the pregap (i.e. 00:00:00 - 00:01:74 (MM:SS:FF)).
    • Changed: The 'Auto Yes in X seconds' text on the 'Create Volume Label' window is now translatable.
    • Changed: Tweaked the SPTD warning to say 'Duplex Secure's SPTD driver can have a detrimental effect on drive performance.'.
    • Changed/Fixed: The program wouldn't suggest a volume label when using Advanced Build mode unless a folder had been added to the compilation.
    • Changed/Fixed: The 'New Project' option on the 'File' menu didn't clear the Disc Layout Editor window.
    • Changed/Fixed: Tweaked the 'Stay On Top' code a bit so it behaves a little better.
    • Changed/Fixed: Workaround for Windows 7 'Show Desktop' issue where restoring the application via the taskbar button could (randomly) leave the main window minimised and the log window hidden off the screen.
    • Changed/Fixed: The NEC drive section of the booktype feature so you can adjust the temporary settings even when the initial query fails (assuming the v4 command set is supported by the drive).
    • Changed/Fixed: Tweaked the way the initial folder for the open/save boxes is calculated.
    • Changed/Fixed: (AGAIN!) The program would only use the layerbreak position in an IBB if the /CLOSE switch was issued via CLI, /CLOSESUCCESS wouldn't work (and it should have done).
    • Changed/Fixed: The 'Eject' option is now persistent across queued burns.
    • Changed/Fixed: Tweaked the way the program detects if a drive returns TOC info in BCD form or not (mainly an issue with really old/non compliant drives).
    • Fixed: Bringing up the 'Cancel' box (and leaving it there) whilst the program was adding files to the DLE window or preparing the build would mean that the form you tried to cancel would stay on the screen even after the operation had actually completed.
    • Fixed: (Again, I hope!) Not getting the 'TaskbarButtonCreated' message in Windows 7 and therefore not being able to do the fancy taskbar progress bar stuff.
    • Fixed: Main form losing focus when switching to Build mode or between Standard and Advanced Input.
    • Fixed: An issue with finding a layer break position when burning directly to DVD+R DL and the 'Double Layer' profile was set to 'DVD-R DL' on the 'Advanced' -> 'Media' tab (only visible when NOT burning direct to disc).
    • Fixed: An issue with unicode file/folder names being converted for the ISO9660 file system. (The file extension could get messed up)
    • Fxied: An issue when truncating ISO9660 file names (those with no extension anyway) when the option to allow names without extensions is enabled.
    • Fixed: The AutoPlay handler for BD Burning wasn't working correctly.
    • Fixed: You could right click the lower part of the column header of the listview control on the disc editor window and it would bring up a context menu as if you'd clicked the 1st item in the list.
    • Fixed: Issue where cached information was being used for the 'Source' information in Read mode when going from a burnt disc to an empty one.
    • Fixed: Filter driver file information was missing on x64 OS's.
    • Fixed: Couldn't add 4GB+ padding to an image.
    • Fixed: Problem when clearing the drop description in the 'DragLeave' event as part of a drag+drop operation.
    • Fixed: Problem with the listview header within the Write Queue window if the handle ever gets recreated.
    • Fixed: Certain fields that should have been present in the disc information panel on the right were missing for certain (multisession) discs.
    • Fixed: Imagelist issue on the 'Disc Layout Editor' window that could result in a crash when closing the program.
    • Fixed: Tweaked the parsing (and display) of track information for DVDs with open sessions.
    • Fixed: Tweaked the parsing (and display) of the TOC for multisession DVDs.
    • Fixed: UDF parsing code always used the first file set descriptor in the partition when looking for files (so files in a 2nd+ session were not seen).
    • Fixed: The '/DEST' CLI parameter didn't work in Verify mode (used to specify the image file to compare the disc to).
    • Fixed: The taskbar 'window preview' showed the log window under Windows 7 (no idea why, it just did!).
    • Fixed: Shutdown/restart/logoff code running before the forms are destroyed (and the log is saved).
    • Fixed: Random failure to load CCD files.
    • Fixed: A bug (you'd never run into) when the program tries to create a folder where there wouldn't be room for an 8.3 format file name after it whilst still keeping under MAX_PATH in length.
    • Fixed: Verify/Read speed linked to Write speed issue with AD-7240S drive (and possibly others?)
    • Fixed: Bug within the installer for the 'AllocateCDRoms' registry value where the type was set to DWORD rather than a String like it should have been.
    • Fixed: The README.TXT file in the fake ISO9660 FS on bootable UDF only discs was being recorded without an actual name.
    • Fixed: An issue loading CCD/CUE files made by CloneCD where the first index didn't start at 00:00:00.
  • 2.5.2.0
  • 2.5.3.0
  • 2.5.4.0 - Sunday, 12th December 2010
    Changed: Remove some more try/catch statements (mainly to do with buffer recovery stuff) in an attempt to get to the root cause of an EInvalidOp error that I've seen in a few bug reports.
    Changed/Fixed: Attempt to clean up the icons created in the wrong location by a bug in v2.5.2.0. It made them in the current user profile rather than the all users profile and could leave you with duplicate icons after installing v2.5.3.0.
    Fixed: Bug introduced in v2.5.3.0 when selecting multiple files in an 'Open File' dialog box under Vista+ (i.e. those using the new IFileDialog code). The first file was being removed from the list of selected files.
  • 2.5.5.0
  • 2.5.6.0
  • 2.5.7.0
    Download
