Hi Leute,
unter der unten genannten Adresse gibt es nützliche AVI Tools.
SSMM 3.0
ZitatThis tool, called Slide Show Movie Maker (SSMM), is a tool for creating AVIs from your pictures very fast. Put your images, for example from your digital camera, in an image list, add some text to every picture (if you want) and start creation. The text can be faded very smoothly into and outo the picture. And many more functions.
Mit Toneinspielung, in Deutsch, Freeware und super Einfach
projectDivX 1.6 Beta1 + VCCI
ZitatThis tool can merge easily DivX (MPEG4-Codec) AVIs encoded with Low-Motion and Fast-Motion. You don´t need anymore tools like MakeFilm or Virtual Dub to merge your AVIs. Use this and merge your AVIs also with sound. High Performance cause of direct stream copy. Can also cut big AVIs into smaller parts. Now with an extended Oracle. Create your DivX AVIs only with some mouse clicks with "Full Automatic Creation". Full resizable GUI.
Now merge as many AVI files you want; Audio and Video Synchronization. Set maximum final AVI file size. Choose Thread Priority.
The Oracle is much better. Full Creation now creates both AVIs (Low and Fast) at one time; safes a lot of time.
Über die Qualität der Progs kann ich nichts sagen, da müsst ihr mal selbst testen.
