Hi
Hab die erste Dvd mit Hc016 encodet könnte mir jemand über das beigefügte Logfile Auskunft geben ob alles ok ist oder ob ich was falsch gemacht habe
| HCbatch - MPEG2 encoder - rel. 0.16A beta |
input: e:\rebuilder\vts_01_1.d2v.avs
output: e:\rebuilder\fertig.m2v
| encoder settings |
profile: NORMAL
frames: 1 191751
framerate: 25.00
aspect ratio: 16:9
bitrate Kb/s: 4500
max. bitrate Kb/s: 6750
closed gops: no
VBV check: yes
scene change det.: yes
interlaced: no
goplen,B-pic: AUTO
dc_precision: 9
scan method: ZIGZAG
bias: 30
chapter frames: 0
time code: 0 0 0 0
CPU: SSE2
matrix: MPEG
| source stats |
nr. of frames in source: 191751
width*height: 720*576
fps: 25.00
nr. of frames to encode: 191751
frames to encode: 1 - 191751
| encoding - pass 1 |
pass 1 encoding time: 1:42:59 (6179 s)
average fps: 31.0
| encoding - intermediate pass |
bitrate set to: 4500000 b/s
est. outfile length: 4213279 kB
intermediate encoding time: 2.1 s
| encoding - pass 2 |
pass 2 encoding time: 1:18:33 (4713 s)
average fps: 40.7
| encoding stats |
total encoding time: 3:01:35 (10895 s)
intra matrix used
8 16 19 22 26 27 29 34
16 16 22 24 27 29 34 37
19 22 26 27 29 34 34 38
22 22 26 27 29 34 37 40
22 26 27 29 32 35 40 48
26 27 29 32 35 40 48 58
26 27 29 34 38 46 56 69
27 29 35 38 46 56 69 83
non-intra matrix used
16 17 18 19 20 21 22 23
17 18 19 20 21 22 23 24
18 19 20 21 22 23 24 25
19 20 21 22 23 24 26 27
20 21 22 23 25 26 27 28
21 22 23 24 26 27 28 30
22 23 24 26 27 28 30 31
23 24 25 27 28 30 31 33
nr. of gops: 13821
nr. of frames: 191751
nr. of I-frames: 13821
nr. of P-frames: 54785
nr. of B-frames: 123145
average quant (non linear): 2.670
VBV underflows detected: 0
VBV underflows fixed: 0
minimum bitrate: 181
maximum bitrate: 6749
average bitrate: 4500
Vielen Dank
Icemaan
Ps Ausgangquelle war 16:9 127min Laufzeit
