hier ist es :
XPos=383
YPos=308
UseDVDRip=0
UsevStrip=0
UseInternalRip=1
Save diskspace=0
vStrip Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDvStripvStrip.exe
vStrip Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
DVD2AVI Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDDVD2AVIDVD2AVI.exe
DVD2AVI Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
iDCT=0
DVD2AVI Pause=0
WavConv=5
BitRate=7
tooLame Mode=0
Audio Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
Autodetect Azid Gain=1
SubMux Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDWinSubMuxWinSubMux.exe
MPG2Dec DLL=D:AnwenderDVDxDVD2SVCDDVD2SVCDMPEG2Decmpeg2dec.dll
InverseTelecine DLL=D:AnwenderDVDxDVD2SVCDDVD2SVCDInverseTelecineDonald Graftdecomb.dll
SimpleResize DLL=D:AnwenderDVDxDVD2SVCDDVD2SVCDSimpleResizeSimpleResize.dll
CCE Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
NoOfpasses=4
CCE Image Quality=17
CCE Anti noise value=2
CCE Anti noise=0
CBR=0
One Pass VBR=0
Multi Pass VBR=1
Dont Delete Files=0
Create VAF=1
QFactor=5
Linear quantizer scale=1
Zigzag scanning order=1
Pulldown Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDpulldownpulldown.exe
Pulldown Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
Use2Streams=0
Pri1Audio1=27
Pri1Audio2=-1
Pri2Audio1=-1
Pri2Audio2=-1
Sub1=-1
Sub2=-1
Sub3=-1
Sub4=-1
Sub5=-1
Sub6=-1
Sub7=-1
Sub8=-1
Azid Gain Offset=6
Rip subtitles=0
Subpictures Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMoviesubs
Min. Delay. Between Subtitles=100
SVCD subtitles=1
BeSweet Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDBeSweetBeSweet.exe
Permanent subtitles=0
PAL Y-Pos=-1
NTSC Y-Pos=-1
MinsHigh1=50
MinsHigh2=63
MinsHigh3=102
MinsHigh4=147
MinsHigh5=150
NumCd1=1
NumCd2=1
NumCd3=2
NumCd4=2
NumCd5=3
NumCd6=3
CDSize 1=800
CDSize 2=800
CDSize 3=800
CDSize 4=800
CDSize 5=800
CDSize 6=800
MaxBitrate=2498
MinBitrate=300
MaxAvg=2300
MinAvg=1600
Adjust Audio Bitrate=1
Use Min. Avg.=1
Force Film=0
bbMPEG Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDbMPEGRunbbMPEG.exe
bbMPEG Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
Movie Offset=2
CDOverlap=2
I-Author Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
Data Preparer=dvd2svcd
VCDImager Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDVCDImagerVCDImager.exe
VCDXBuild Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDVCDImagerVCDXBuild.exe
Use I-Author=0
Use VCDImager=0
No images=1
Use VCDXBuild=0
Title Picture=D:AnwenderDVDxDVD2SVCDDVD2SVCDDefaultTitlepicture.bmp
Change CD Picture=D:AnwenderDVDxDVD2SVCDDVD2SVCDDefaultChangeCD.bmp
Length of Chapters=60
Use TitlePicture=0
Use ChangeCD Picture=0
Avisynth Bicubic b Value=0
Avisynth Bicubic c Value=0.75
SmartDeinterlace Mode=2
SmartDeinterlace Treshold=10
SmartDeinterlace Denoise=1
SmartDeinterlace Blend=0
SmartDeinterlace Fast=1
Edit Avisynth Script file=0
UseAVI2SVCD=0
UsePVA2SVCD=0
UseDVD2SVCD=1
PVA Executable=
PVA Folder=D:AnwenderDVDxDVD2SVCDDVD2SVCDMovie
UseCDOverlap=1
Wave Length Adjust Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDWLAWLA.exe
FirstRun=0
MADPlay Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDMADPlaymadplay.exe
Use CDMage=0
CDMage Executable=
RunPerCDImage=0
RunPerCDImage Executable=
RunFinal=0
RunFinal Executable=
RunPerCDImage Params=
RunFinal Params=
bbMPEG videoDelay Adjustment=180
bbMPEG audioDelay Adjustment=180
bbMPEG audio1Delay Adjustment=180
Use MPEGAV=0
FixedChapters=0
DVDChapters=1
ForceIAuthorSupport=1
TMPGEnc Rate Control Mode=2
Subtitle DLL=D:AnwenderDVDxDVD2SVCDDVD2SVCDAvisynth Subtitler.dll
BMP Loader DLL=D:AnwenderDVDxDVD2SVCDDVD2SVCDAvisynth BMP Loader.dll
VFAPI Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDVFAPIReaderVFAPIConv-EN.exe
ResizeMethod=2
UseMPEG1=0
UseMPEG2=1
Convert to Canopus codec=0
Convert to Divx4=0
Use Frameselection=0
New Default Folder=0
DVD2SVCD Level=0
Eject DVD=0
Luminance Gain=0
Luminance Offset=0
Audio1Downsampling=1
Audio2Downsampling=1
Audio1BitRate=7
Audio2BitRate=7
Folder Structure Source=
Folder Structure Video=
Folder Structure Audio=
Folder Structure Muxed=
Folder Structure Subs=Subs
Intra=8,16,19,22,26,27,29,34,16,16,22,24,27,29,34,37,19,22,26,27,29,34,34,38,22,22,26,27,29,34,37,40,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,58,26,27,29,34,38,46,56,69,27,29,35,38,46,56,69,83
NonIntra=16,17,18,19,20,21,22,23,17,18,19,20,21,22,23,24,18,19,20,21,22,23,24,25,19,20,21,22,23,24,26,27,20,21,22,23,25,26,27,28,21,22,23,24,26,27,28,30,22,23,24,26,27,28,30,31,23,24,25,27,28,30,31,33
Matrice Preset=
Use deafult Matrice=1
LFEDownmixLR6Ch=-3
LFEDownmixLFE6Ch=0
CenterDownmix6Ch=0
SurroundDownmix6Ch=0
DynamicCompression6Ch=1
StereoDownmixType6Ch=0
RearChannelFiltering6Ch=0
DialogNorm6Ch=0
LFEDownmixLR2Ch=-3
LFEDownmixLFE2Ch=0
CenterDownmix2Ch=-1
SurroundDownmix2Ch=-1
DynamicCompression2Ch=1
StereoDownmixType2Ch=0
RearChannelFiltering2Ch=0
DialogNorm2Ch=0
No Audio Conversion=0
TemporalSmoother Strength=2
TemporalSmoother Radius=1
Use TemporalSmoother=0
Flip Vertival=0
Add ResampleAudio=1
Resize To=0
Use CCE=1
Use TMPGEnc=0
CCE Safe Mode=0
Progressive=1
Auto Intra DC=0
DVD Compliant=0
Restrict auto I frame insertion=0
Close all GOPs=0
Intra DC=2
M GOP=3
MN GOP=5
SEQ Header=1
Constrained Parameter Set=1
TMPGEnc Motion search precision=4
TMPGEnc Field Order=2
Frames pr spread=50
Spread=40
OffsetFixed CQ Value=80
Use fixed CQ Value=0
DC component precision=2
Output YUV data as Basic YCbCr not CCIR601=0
Use floating point DCT=1
No motion search for still picture part by half pixel=1
Soften block noise=0
Soften Intra=35
Soften NonIntra=35
TMPGEnc GOP I Pictures=1
TMPGEnc GOP P Pictures=4
TMPGEnc GOP B Pictures=3
TMPGEnc SEQ Headers=1
TMPGEnc Max frames in GOP=0
TMPGEnc Close GOPs=0
TMPGEnc Detect Scene Change=1
Enabled Padding=0
SubOutputPalette0=clBlack
SubBlendPalette0=0
SubOutputPalette1=clWhite
SubBlendPalette1=15
SubOutputPalette2=$001E1E1E
SubBlendPalette2=15
SubOutputPalette3=clGray
SubBlendPalette3=15
Resize Subtitles=100
CVD subtitles=0
bbMPEG MPEG1=0
bbMPEG VCD=0
bbMPEG MPEG2=0
bbMPEG SVCD=1
bbMPEG DVD=0
bbMPEG VBR=1
bbMPEG Pad VCD=0
bbMPEG Write PEC=1
bbMPEG Add Scan Offsets=1
bbMPEG Align Sequence Headers=1
bbMPEG Use Private Stream 2=0
bbMPEG Computed Bitrate=1
bbMPEG TimeStamps=0
bbMPEG Pulldown=2
bbMPEG MuxRate=0
bbMPEG Pack Size=2324
bbMPEG Packets Pack=1
bbMPEG Video Buffer=230
bbMPEG Audio 1 Buffer=4
bbMPEG Audio 2 Buffer=4
PBCType=0
Use ChangeCD Picture on All=0
Use EntrySVD=0
Save XML=1
Save Movie Info=1
ProcessPriority=1
Automatic Shutdown=0
Anamorphic Aspect=1
[Executables]
PVA Executable=
MadPlay Executable=D:AnwenderDVDxDVD2SVCDDVD2SVCDMADPlaymadplay.exe
BeSplit Executable=
CCE Executable=D:AnwenderDVDxCCECinema_Craft_Encoder_SP250cctsp.exe
TMPGEnc Executable=
I-Author Executable=
CDMage Executable=
[Folders]
DVD2AVI Folder=D:filmSVCDdatenschrott
vStrip Folder=D:
ipFolder
Audio Folder=D:filmSVCDdatenschrott
CCE Folder=D:filmSVCD
TMPGEnc Folder=
Pulldown Folder=D:filmSVCDdatenschrott
bbMPEG Folder=D:filmSVCDothers
so , ich hoffe da kann man was erkennen.
die frage bleibt.
warum brauch castaway 3 cd's ?
ciao,
elo.
