Benutzt jemand von euch http://users.adelphia.net/~mwilczyn/mpeg2repair/ ?
ZitatAlles anzeigen
MPEG2Repair:
<!--[if !supportLineBreakNewLine]-->
<!--[endif]--><o:p></o:p>
Windows application for testing HDTV transport streams to make sure they are Mpeg2 compliant. Summary of features:-Error Detection:
Find file errors resulting from signal drop-outs, faulty tapes, encoding errors, etc. Detection code checks transport layer for continuity errors and faulty headers. Code also checks the MPEG2 PES layer for parsing errors (corrupted macroblocks, slices, headers, etc.). All errors are logged with time stamps and file positions so you can easily locate them inside your original recording. Very useful for verifying files prior to permanent archiving.
-Error Repair:
Automatically repair minor Mpeg2 transport and PES errors which may cause problems for certain decoders. Tool will remove erroneous data from the file by either cutting it out or replacing it with valid bits. The goal of repair is to create a fully Mpeg2 compliant file that will not crash, hang, or stall decoders which were not designed to deal with errors. Repair is currently not intended to improve the visual appearance of errors but simply to remove them. <o:p></o:p>
-Improve Decoder Compatibility:Automatically fix other issues that may affect decoder compatibility. These include partial GOP's, missing headers, incorrect continuity, etc. This feature is especially useful for those of you with old recordings from the 169time system. They should now play smoothly on other decoders besides the JVC 30K deck.
<o:p>
</o:p>
<o:p></o:p>
<o:p>Kannte das Tool noch nicht und habe es auf einem Stream mit Erfolg angewendet, würde gerne wissen ob jemand anderes das Tool schonmal benutzt hat und wie seine Erfahrungen damit sind.</o:p>
<o:p></o:p>
<o:p>Cu Selur
</o:p>
