Aktuelles CDex-Release
  • Es sieht so aus, als nähme die Entwicklung von CDex nach langer Zeit wieder Fahrt auf. CDex 1.70beta1 ist draußen.
    Mein Lieblings-CD-Ripper war auch schon etwas in die Jahre gekommen. Ich benutze zwar auch EAC, konnte mich damit aber nie so richtig anfreunden.
    Hier ist das Changelog:
    Changes since CDex 1.51 (release):
    * Fixed Vorbis comment field problem and track number field problem
    * Updated to GNU based winamp plugins
    * Support conversion of WAV files > 2 GB
    * Updated Lame encoder
    * Updated Ogg encoder libraries
    * Add patches CDex 1.60++ (cue sheet generation)
    * Updated several language files
    * UTF-8 support for CDDB
    * Flac Support
  • Nach Jahren....
    1.70 Beta 3
    This version features a new hybrid installation approach. The installer includes the new 1.70 Beta 3 version
    with many updates, but also the old Beta 2 Unicode and Non Unicode releases
    Download
  • 1.70 beta 4 (November 18, 2009)
    This version is a bug fix release to CDex 1.70 Beta 3 and features many internal and encoder updates.
    It is recommended that you update to this version.
  • 1.71
    -Fix for configuration settings
    -Use special Windows folder ApplicationData
    -Encoder updates
    -Updated LAME to version 3.99.5
    -Updated CD-ROM Drive offsets
    -Improvements to CDDB querying
    -Updated translations
    -Added new installer languages
    -Improvements to language files
    -Bug fixes
    Download
    Einmal editiert, zuletzt von Schotenhüter (22. Oktober 2014 um 18:04)
  • 1.72
    -Encoder updates
    -Updated to FLAC 1.30
    -Updated to Ogg 1.3.2
    -Updated to Vorbis 1.3.4
    -Updated to FAAC 1.28 and FAAD 2.7
    -Added missing encoder files
    -Installer fixes
    -Internal improvements
    -Bug fixes
  • 1.73
  • 1.74
  • 1.75
  • 1.76
  • 1.77
    -Updated genre list, containing new ID3 extensions
    -Fixed writing ID3v2.4 tags
    -Fixed writing combined ID3v2.4+ID3v1 tags
    -Fixed setting description for attached cover art
    -Fixed spelling errors in genre list
    -Fixed setting MIME type for ID3v2.3 cover art
    -Fixed setting MIME type for ID3v2.4 cover art
    -Performance improvements
    -Bug fixes
  • 1.78
    -Updated Vorbis encoder, using libvorbis 1.3.5
    -Improved Ogg encoder build, using libogg 1.3.2
    -Updated vc redist package
    -Updated CD-ROM drive offsets
    -Fixed track number error during file generation
    -Compatibility improvements
    -Bug fixes
  • 1.79
    This version is the final release for CDex 1.79 for both Unicode and Multibyte.
    -Fixed encoder bug on Windows 10
    -Improved Windows 10 suppport
    -Encoder settings update
    -Bug fixes
  • 1.80
    -Improved writing meta data to files
    -Updated conversions libraries
    -Fixed Windows 10 installation dependency
    -Added new translations
    -Bug fixes
    Achtung beim installieren wird wieder Gedöns ala Browser Toolbars etc. installiert.Die Version 1.77 ist noch frei davon.
  • 1.81
    -Added Corsican language translation
    -Fixed bug in CDex installer
    -Fixed library linking on Windows 7
    -Updated Visual C++ redistributable
    -Updated internal libraries
    -Improved Windows 10 support
    -Bug fixes
  • 1.82
    This version is the final release for CDex 1.82 for both Unicode and Multibyte.
    Changelog
    -Added Vorbis encoder configuration.
    -Updated library dependencies.
    -Updated installer and language detection.
    -Fixed visual styles bug on Windows XP and Vista.
    -Updated Visual Studio redistributable.
    -Added new language translations.
    -Fixed bug in language selection.
    -Windows 10 64-bit bug fixes.
    http://cdex.mu/download
