AutoMKV - Alternative für AutoGK
update 0.83
ZitatChangelog
- ADDED: Some check to Test Deint fuction
- ADDED: QMtrim. QMtrim is a vectorial analysis software based on mvanalyze. When enabled AutoMKV will do one more pass to determine the motion vectors of movie. Using this file QMtrim is abled to construct a very complect trim script with multiple denoiser applyed. http://www.digitalexpression.it/foru...?showtopic=416
- ADDED: Filter selected is now used in Preview (Suggestion by Nadine)
- ADDED: Edit LVL button to dinamically edit the QMtrim lvl files
- ADDED: Deinterlacer Settings is now used in Preview. You can see what your deinteralcer will do. Leave AUTO for no deinterlace preview
- ADDED: In Preview panel the possibility to trim. Remember to click "Trim from here" for setting the Trim start. The file will be encoded from start to this frame
- ADDED: In QMtrim options to encode as compression test the full lenght of movie
- ADDED: Chapter Editor. Quite goofy and limited... but fuctional. The text could be also directly added and copy&paste. I suggest to use the DEL and CANC button to delete empty string...
- ADDED: Some sanity check about QMtrim
- FIXED: When working with WMV and FILM type the tdecimate stringe goes after cropping
- FIXED: Some issue on iPod profiles (thanks to migrena)
- FIXED: On selecting Don't care about file size the Width is set to Original and Resizer to NONE
- FIXED: In directShowSource is now specified converfps=true and fps=xxx
- FIXED: In Crop settings "Check Values" and "Preview" are valorized only if input file is present
- FIXED: Some tuning to FFmpeg encoding to X264, changed both preset. Now fast is fast.
- FIXED: If input is d2v or m2v and isn't selected any audio, the default audio track will be NONE (previusly was "All Audio Tracks")
- FIXED: If Compression check is 100, then isn't applyed any SelectRangeEvery
- FIXED: Moved ColorMatrix as last filter. This move will correct issue of wrong color with non MOD16 crop
- FIXED: Some update to log
- UPDATE: FFmpeg.exe to v8797, X264 v654
update 0.84
ZitatADDED: Huffyuv to FFmpeg supported output (audio is stereo 16bit pcm)
ADDED: Mpeg1 to FFmpeg supported output (audio is stereo mp2)
ADDED: MSmpeg4 (the old DivX3) to FFmpeg supported output (audio is stereo mp3)
ADDED: Mjpeg to FFmpeg supported output (audio is stereo mp3)
ADDED: Snow to FFmpeg supported output (extremely alpha , command line like -vcodec snow -vstrict -2 -strict -2 )
ADDED: YUV to FFmpeg supported output (no audio)
ADDED: "AUDIO aac 2ch" to FFmpeg supported output
ADDED: "AUDIO aac 5.1ch" to FFmpeg supported output
ADDED: "AUDIO ac3 2ch" to FFmpeg supported output
ADDED: "AUDIO ac3 5.1ch" to FFmpeg supported output
ADDED: "AUDIO flac 2ch" to FFmpeg supported output
ADDED: "AUDIO flac 5.1ch" to FFmpeg supported output
ADDED: "AUDIO mp2" to FFmpeg supported output
ADDED: "AUDIO mp3" to FFmpeg supported output
ADDED: When encoding with FFmpeg for audio, is used the selected audio track
ADDED: CCT AAC is now able to do multichannel encoding. The audio is preprocessed to wav and then piped by ffmpeg to CCT encoder
ADDED: Reorganized the profiles. Added a check to enable "All Profiles", otherwise only basic profile will be avaiable
ADDED: VRO to supported media (using DgIndex to process)
ADDED: LanczosPlus, use it only for UpScaling http://forum.doom9.org/showthread.php?t=125469 by *.mp4 guy
ADDED: LEM. This filter is an adaptive denoiser that could give very good result. It can dinamycally apply till 2 filters based on luma and motion of frame http://www.digitalexpression.it/forum/index.php?showtopic=739 by superqix
ADDED: PS3 X264 profile (alpha, thanks to esso and foxyshadis)
ADDED: AutoMKV will check if fftw3.dll is present in \system32 folder. If not will ask to copy it
FIXED: In XviD Profiles ClosedGop and ChromaMotion renamed to NoClosedGop and NoChromaMotion, for better logic (suggestion by nullstuff)
FIXED: A lot Better image of Codec Logo and Container Logo
FIXED: Modified the pre-processing of WAV when encoding to WMA (suggestion payne_en_diaz)
FIXED: When checked Cartoon Mode in XviD is used both cartoon mode AND greyscale (thanks to sunflash10)
FIXED: Worked on Anamorphic (but is experimental and not supported by any means)
FIXED: Better (i hope) code to handle audio demux, 24kb less code. Should be less prone to "Audio not found" error
FIXED: Better support to FLV as input (but i suggest to use FFmpeg option to deal with)
FIXED: Ref 0 isn't allowed even in turbo pass. Now is Ref 1 (thanks to foxyshadis)
FIXED: More robust detection of Private Audio Stream
FIXED: Moved ColorMatrix as first filter. This move will correct any other issue pending with colormatrix
UPDATE: DgIndex to 1.4.9 stable, FFmpeg to 8891, ported code to PureBasic 4.02 -
AutoMKV 0.85
ZitatADDED: "AUDIO vorbis" to FFmpeg supported output
ADDED: XviD to FFmpeg supported output
ADDED: Log of WMV
ADDED: VirtualDubMod to muxer Options
ADDED: Splitting support to VirtualDubMod muxer
ADDED: In Log the FFmpeg muxing parameters
ADDED: In Log the Virtualdubmod muxing parameters
ADDED: An option to check integrity of avisynth script. Before starting encoding AutoMKV will check the script for avisynth errors. If errors are found those errors are written in log and user is requested to quit or proceed (if proceed it will trigger FFmpeg.exe)
ADDED: External subtitle (only SRT type) support to DivxMuxer and VirtualdDubMod muxers
ADDED: Preset to Tempo options
ADDED: Deinterlace to FFmpeg encoding. If the auto detection or user set a deinterlace pattern this value is passed to FFmpeg.exe
ADDED: AR Error in Preview panel (beta)
ADDED: HGAVS Optimizer by HellGauss
ADDED: MediaInfo is now used in preview panel for setting the original AR
ADDED: New PS3 profile, with level 41 (PS3_41.xml) (submitted by Jeroen)
ADDED: Again support to 5.1ch for WMV, be sure to read this before http://automkv.wiki-site.com/index.php/Audio_Troubleshooting
ADDED: Message to confirm external subtitle loading (suggestion by esso)
ADDED: Gauss_Based_Resize.lvl (QMtrim profile)
ADDED: In Advanced Profile Editing "Allow x264 Stats". This option is checked by default. When enabled will allow AutoMKV to diplay a graphical windows of X264 encoding status. Will be displayed the current video frame, the size of movie, % of progress, encoding speed, time elapsed and time remaining. Is also possible to abort encoding (killing the x264.exe). This feature uses from 0% to 5% of cpu power (depends of cpu power... of course )
ADDED: "Allow x264 Stats" in Save Settings
FIXED: Reworked avi muxers options
FIXED: Substitued VirtualDub.exe with VirtualDubMod.exe
FIXED: When input is an not mpeg container file (OGM/MKV/AVI/DIVX/MP4...) Copy Original as audio isn't more possible
FIXED: If LanczosPlus is used for downscaling the Spline36Resize is triggered
FIXED: Better code to handle FFmpeg usage (should be a little faster on 2 pass encoding)
FIXED: Some issues in preview panel
FIXED: If input file is an AVI/MKV/OGM the AR is extrated with MediaInfo
FIXED: When quequing IFO jobs AutoMKV will not queue if new movie is shorter (ugly bug present from 0.19, thanks to AMED)
FIXED: First pass of X264 is now quick. (thanks to smekoslav)
UPDATE: aWharpSharp to aWharSharp(Pruned), WMCmd.vbs 21/05/2007, DgIndex 1.4.9 VC6, FFT3DFilter 2.1.1, LanczosmtPlus 28/05/2007 , TITVC 1.02, ffmpeg rev 9133, SoundOut 1.0.1, SeeSaw 0.3e update by Foxyshadis (suggestion by wizboy11), QMtrim 0.5b1
REMOVED: AviMux_GUI -
AutoMKV v0.86d
Zitat* FIXED: EditLVL doesn't fuction on path with space (thanks to nullstuff)
0.86b 28/06/2007
* FIXED: HGASV Level count how many filters is applyed (thanks to nullstuff)
* FIXED: Low window now used a fixed type font (Courier New), much more readable (thanks to nullstuff)
0.86c 29/06/2007
* FIXED: HGAVS wasn't saved on Save Settings (thanks to nullstuff)
* FIXED: AutoDeint was broken because of new graphical interface
0.86d 30/06/2007
* FIXED: Some tuning to colormatrix (thanks to Ermenegildo)
* FIXED: Cropping in Preview Panel was broken (thanks to Ermenegildo) -
Hier der allgemeine Link zu den AutoMKV´s
http://www.64k.it/andres/ -
AutoMKV v0.86e
Zitat* ADDED: FFmpeg command line added to Log
* FIXED: "Don't Care about Size" will change width only if with is "Automatic"
* FIXED: When input is ifo AutoMKV will try to demux audio even if not requested
* FIXED: When changing audio codec the downmixing will not change. It will be set to Stereo for Lame
* FIXED: Deinterlace test results now is always reported
* FIXED: When working with interlaced source, ColorMatrix is used in interlaced mode
* FIXED: Readded Deinterlace Status Analysis Window(beta)
* FIXED: ChapterXtractor should work on long path
* FIXED: FFDshow will remain invoked even if script is closed (2 fixed... more needed)
* FIXED: Computing movie parameters is now hidden
* FIXED: ColorMatrix slowdown, moved as last parameter. This little move will gain up to 15% of speed encoding
* FIXED: Removed -fps from xvid_encraw command line. Even if value passed was correct -
AutoMKV v0.87
* ADDED: Check if avs input file is yv12
* ADDED: aq-strength, aq-sensitivity to X264 profile
* ADDED: Possibility to extract audio (Copy Original) for AVI/MP4/MKV/OGM/MOV.. container. The extraction is done by ffmpeg, or if present in \exe\BeSweet folder mplayer.exe. I cannot guarantee the correct extraction (for example AAC extraction with mplayer is broken...)
* ADDED: QMTrim 0.6b1 support
* ADDED: Warning message when selecting QMTrim or HG AVS (suggestion by survivant)
* ADDED: Aften support
* FIXED: FFDshow will remain invoked even if script is closed (2)
* FIXED: In command line interface the movie name wasn't set (thanks to g_aleph_r)
* FIXED: After several test the thread parameter is now set to "--threads 0 --thread-input"
* FIXED: Some bugs on QMTrim (thanks to survivant)
* FIXED: Update PS3 4.1 profile (thanks to survivant)
* FIXED: Save configuration will now save in automkv folder (suggestion by zacoz)
* FIXED: Is no more possible to apply both MVDegrain AND MVDenoise (suggestion to survivant)
* FIXED: Changed the Status bar... more professional now (1kb less of exe size! )
* FIXED: Some little layout change
* FIXED: Using queue in multiple sessions (beta) (thanks to zacoz)
* FIXED: When Disk Settings is "Don't care about size" and codec XviD the matrix will be set to "Didees SixOfNine-HVS.cqm"
* FIXED: Some Matrix in XviD Profiles
* FIXED: Totally reworked CRF/CQ Profile. Should be more clear and understable. Note that will be used as quantitizer the value in this window NOT in profile
* UPDATE: X264 rev.663, all XviD profiles (compatibility with VirtualDub), all X264 profiles (for aq patch),MediaInfo 0.7.5.0, Aften 0.7 -
AutoMkv v0.90
ZitatADDED: PGCDemux and DvdDecrypter support. Reworked how episodic dvd is engaged.
1) FIRST CASE: WORKING WITH DVD TO RIP
the ripping will be done by dvddecrypter, in case of "difficult" ripping i suggest to use ripit4me or dvdfabdecrypter (after this you can mount the iso to simulate "dvd to rip")
On PGC list select your pgc (episode) and DVDDecrypter will rip only this pgc
2) SECOND CASE: WORKING ON DVD ALREADY RIPPED (laying on hd)
If selected the first pgc, dgindex will start directly, else PGCDemux will "demux" the selected pgc and this will be used for encoding
Don't strip audio from dvd or dgindex will be fouled when demuxing audio tracks!
ADDED: CFilter folder in \exe folder. In this folder put plugin that need LoadCPlugin (like yadif)
ADDED: VirtualDubPlugins in \exe folder. In this folder put VirtualDub plugins that want to load (example DeLogo.vdf). The filter will be loaded as this (for example) LoadVirtualDubPlugin("c:\VirtualDub-1_4_10\plugins\delogo.vdf","delogo"), attention to filter name "delogo". The filter name is based on plugin name!. So if plugin is called "awesome_deinterlacer.vdf" the filter will de called "awesome_deinterlacer". To use DeLogo plugin (and other virtualdub plugins) remember to converto rgb32 before. like this ConvertToRGB32.delogo(1, "500-999", "D:/2.bmp", "D:/2.bmp", "D:/1.bmp", "D:/2.bmp", 34, 56, 0,0).ConvertToyv12(interlaced=true) , apply this string to Last line avs string or base.avs
ADDED: If .chunks is present in original folder, before launching VSrip these file will be deleted (suggestion by vOjToL)
ADDED: In Xvid Status encoding the total time estimated and % of worked frames (suggestion by connex)
ADDED: Even in xvid 2 pass encoding the average bitrate is displayed in window
ADDED: FFmpegSource to queue saving
ADDED: DGDecode_Deblock in Advanced Profile Editing
ADDED: More X264 profiles, made by Kurtnoise13 PD_Apple_iPhone.xml,PD_Apple_TV.xml,PD-ATV.xml,PD-iPhone.xml,PD-Archos605.xml
ADDED: MVDegrain1
ADDED: MP4 as allowed audio input (suggestion by tha_reaper)
ADDED: In X264 encoding window the bitrate (suggestion by bleedingum)
ADDED: In Advanced Audio Options the possibility to encode with SoundOut with OGG/FLAC/WAV Extended/MP2
ADDED: In log the use of Specify Quality and Specify Bitrate
ADDED: Workaround for "Field Order Transition Detected" on Dgindex. The d2v is now checked against TFM and if movie-fixed.d2v is generated, then AutoMKV will use it
ADDED: Check , in Advanced profile editing, for allowing third pass with x264 (suggestion by 3ngel)
ADDED: In Advanced Settings "Hide Subs". This option is to use only for mkv container and will force player to not show subtitle
ADDED: Option to force first pass with the same value as second pass. Check "HQ first pass" in Advanced profile editing (suggestion by 3ngel)
ADDED: XviD_Sap_Scure to use for SAP compatibility when dealing with high compressibility source
FIXED: Using preview with d2v with HD movie (thanks to bisdelf)
FIXED: Spelling (thanks to InorganicMatter)
FIXED: X264 profile and use of deadzone-intra/inter (thanks to peter_h)
FIXED: Using the preview without filter enabled (thanks to edwardt)
FIXED: Missing parsing of Width parameter for x264 profiles
FIXED: No more need to copy ffmpeg libraries, libsndfile-1.dll or fftw3.dll in \windows\system32. Anyway is always preferred to copy these dll.
FIXED: AutoMKV will wrongly apply TFM/TDecimate on avi input. (thanks to AC84)
FIXED: In 2 pass encoding the default subme for first pass is now 2, look here http://forum.doom9.org/showthread.ph...85#post1035385
FIXED: Muxing problem using MP4Box and long path
FIXED: Reporting of wrong size of muxed file when container is MP4 (thanks to delacroixp)
FIXED: Title muxing when using Avi container and VirtualdubMod muxer
FIXED: Preview using ifo as input (thanks to DIEGO7-5)
FIXED: In log the report of a second pass when using Quality Mode (thanks to jellyfish2002)
FIXED: Erroneus splitting in many and more parts (beta fix)
FIXED: By default the encoding status is no more displayed. This will bring more speed to encoding and if wanted in Advanced profile editing is possible to enable it
FIXED: The deinterlacer status is not displayed. This will bring a more faster analysis and a more secure results.
FIXED: Custom BAT for audio encoding. Now is passed the Destination directory as variable. Look at custom_mp2.bat and custom_besweet.bat in \besweet folder
REMOVED: Vstrip, DVDFabDecrypter
UPDATE: MVTools to 1.8.4, mt_masktools to 2.0 alpha 32, update NicAudio (13/08/2007), PS3.xml and X264 profiles like 1_Pass_High Performance.xml, 2_Pass_Balanced.xml,2_Pass_Better_Quality.xml (http://forum.doom9.org/showthread.ph...09#post1035509), XviD profiles,Mktoolnix to 2.1.0, BAutoDeint thanks to Andreas Kuhlen, DGindex 1.5.0b1, xvid_encraw 31/08/2007, MediaInfo 0.7.5.2, ColorMatrix 2.2, FFmpegSource 1.11, dgmpgdec 150b2,x264 r675 -
update v0.90a
ZitatFIXED: Keyboard shortcut form HCEnc/Avs2Avi (previusly could break some games.. like PES6 when played at in windowed mode)
FIXED: Better thread optimizations -
update v0.90d
Zitatnoch kein changelog
:nein:
AutoMKV 0.91[update]
ZitatADDED: Tune CQ button. Is activated only when working with Constant Quality profile
ADDED: 2 pass encoding with Nero AAC Enc. Option avaiable only when using CRB or BR encoding, activable in Advanced Audio Options
ADDED: LAME VBR preset (medium, standard, extreme and insane) (Suggestion by ermenegildo)
ADDED: Again check for ffmpegsource dll in \windows\system32. Too many users complain about not able to open avs script made by automkv in virtualdub.
ADDED: v_adz option for wmv profiles. In Wmv profiles is now set to false
FIXED: Font in log
FIXED: The language list will show only avaiable translation (suggestion by aytin)
FIXED: Autodeint routines are launched in old dos mode
FIXED: When loading a Save Setting with Constant Quality Profile enabled the CQ button will be valid
FIXED: Some log optimizations
FIXED: Reworked all WMV Profile
FIXED: No more need to set 6 ch on Advanced Audio Settings for WMA audio. Selecting ORIGINAL will set 5.1 output. USE ORIGINAL only if your audio source is already 5.1 (suggestion by Bleedingum)
REMOVED: v_percopt from wmv profiles
REGRESSION: MP4Mux 14/09/2007 build, newer build crash on Vista
UPDATE: X264 v680, TIVTC 1.0.3, DGIndex 1.5.0 b10, WMcmd.vbs 11/10/2007 -
update 0.91b
ZitatFIXED: Preview of HD files. Note that crop value are referred to the reduced size (thanks to bisdelf)
CHANGED: PGC ripping is now always active. Whenever you select a pgc this pgc will be extracted. -
update 0.93a
ZitatWHAT'S NEW IN VERSION 0.93a:
* ADDED: support for , , , take as reference the PS3_41_ECS3.xml, pulldown value can be any integer. Set 0 for disabling. (suggestion by survivant001)
* FIXED: Typos (AQ strenght -> AQ strength) (thanks to Encoder888)
* FIXED: Maximum AQ Strength is 2.0 (and so you can put 20 for 2.0)(thanks to Encoder888)
* FIXED: Deinterlacer routine test now is running minimized and at idle priority
* FIXED: Computing movie parameters now run at idle priority
* FIXED: Some tweak to ffmpeg.exe usage
AutoMKV v0.95
ZitatADDED: Movie name is now based on folder name (in case of ifo input) (suggestion by AMED)
ADDED: Possibility to specify only the crop values and not the width and height (suggestion by Honeyko)
ADDED: "Don't Mux But Save Temp Folder" checking this option will force AutoMKV to rename temp folder (based on movie name) and to not mux
ADDED: In case of MP4 container and AC3 Audio now AutoMKV will not quit. It will prompt a message about not able to mux and will move the temp folder
ADDED: Now FFmpeg Encoding take account of Manual Crop&Resize and Manual Crop and Specify Bitrate. In this way AutoMKV can be instructed to do near all FFmpeg Encoding
ADDED: Colored crop value. Green = OK, Red = Wrong
ADDED: Colored Manual Width and Height Value, Green = OK, Blu = not so well , Red = Wrong
ADDED: Option to add "--engage keep_bitstream_ar_info" to muxing command line
ADDED: Tips! If you don't want tips just delete the file tips.txt
ADDED: Support for M2TS container using excellent tsMuxeR. I suggest to use PS3_XboX360 profile (have nal-hrd/aud enabled)
FIXED: When reopening CQ TUNE the previus values where rounded up (thanks to Honeyko)
FIXED: On d2v input, when checking Manual Crop and Resize will show correct value on Width and Height
FIXED: When encoding is running is no more possible to add job in queue
FIXED: Now Value of Crop and Width/height are greyed till user click on "Use Manual Crop/Resize" or "Manual Crop" (suggestion by Honeyko)
FIXED: Now when pressing Start Queue, the button "Start Queue" will be disabled (suggestion by Honeyko)
FIXED: In case of triggered ffmpeg encoding (avi/xvid) now AutoMKV wil correctly mux the final file (thanks to Honeyko)
FIXED: Now AutoMKV wil rename automatically "movie name" contain illegal character like|!<>"?\/.
FIXED: Even on Avi muxing AutoMKV will check for already existing file destination. In this case will create a muxed file starting with numbers_movie name.avi (thanks to Honeyko)
FIXED: On Avi muxing the original audio is no more muxed (thanks to ryc0203)
FIXED: Manual Crop and Resize will disable Width on load settings (thanks to Honeyko)
FIXED: Force Mux Height and Width are remebered on qeque
FIXED: Quality Encoding will now trigger on ffmpeg encoding a quality encoding too
FIXED: Removed some pop up windows
FIXED: Usage of ITU and Anamorphic encoding (a BIG thanks to Valnar AND SeeMoreDigital)
FIXED: Anamorphic on muxing (thanks to Zacoz)
FIXED: Some issues using FFmpegSource
FIXED: Some issues using PreProcess to LossLess
FIXED: Reduced the number of "triggering" list. Now clicking on audio, video profile, container, codec AND not changing the value will not trigger AutoMKV routines
FIXED: DSS x A/V will force AutoMKV to use DirectShowSource for encoding both audio and video
FIXED: DSS x Audio will force AutoMKV to use DirectShowSource for encoding only audio (before will trigger even video)
FIXED: Whenever "Manual Resize / Crop" is checked, AutoMKV will determine if there is already a setting for Resize Filter other than NONE. If it is NONE, then it will be changed to SimpleResize(neutral soft). (suggestion by Honeyko)
FIXED: When checking "Specify Quality" the encoding status window will now display the selected CQ/CRF value (thanks to Honeyko)
FIXED: When checking Manual Crop&Resize the value of width specifyed in profile are ignored
FIXED: Deinterlacer Analysis is now minimized
FIXED: Some Layout in GUI, most cosmetic
FIXED: Some layout on log
UPDATE: FFmpegSource 1.14, ColorMatrix 2.3, TIVTC 1.0.5, FFmpeg r11562,Mp4Box 11/01/2008, X264 rev 736 (AQ 0.48, 2pass vbv, aud/nal-hrd) PS3_41.xml profile renamed to PS3_XBOX360.xml and lowred the qpmin to 5, Xbox.xml profile, oggenc2.84-aoTuVb5-generic.zip
UPDATE: Italian translation
DELETE: Some duplicate x264 profile (heritage of compatibility with Megui)
CHANGED: When selecting "Don't care about size" AutoMKV will not do anything, just on status bar "Don't use Automatic Width. It's a waste of time with Unlimited File Size."
CHANGED: On Zune profile all audio is now WMAPRO.
CHANGED: How AutoMKV will compute Height. Now the calculus are very precise and corrected to AR (i hope...)
CHANGED: AutoMKV can now handle delay audio in several ways. The default is to use DelayAudio in Soundout (as MeGeui) (AutoMKV will silently switch to Fix in Mux if audio is "copy original") (a precius suggestion by valnar). Or can Use DelayCut or can fix the delay in mux (as AutoGK)
CHANGED: In case of broken audio encoding AutoMKV will not try to use SoundOut but will pipe from ffmpeg to audio encoder. Due to inability of many encoders and bugs of FFmpeg.exe, AutoMKV will trigger a directly encoding made by FFmpeg -
Automkv 0.95a
ZitatFIXED: On Muxing the changefps parameter was ignored (thanks to zacoz)
AutoMKV v0.95b
ZitatADDED: Now AutoMKV create a muxing.bat even for M2TS muxing. For hand made facilities (suggestion by survivant001)
ADDED: In case of M2TS muxing AutoMKV will compute an overhead of 6% on bitrate (suggestion by survivant001)
ADDED: M2TS Container Logo (fell free to suggest better logo)
FIXED: "Do HQ First Pass" wasn't applyed when encoding to XivD (thansk to XhmikosR)
FIXED: On log file "Enabled CRF/CQ AutoRes" wasn't displyed on case of "Specify Quality" (thanks to Honeyko)
FIXED: Double use of --sar option. Pay attention to <Sar> value in profiles (thanks to survivant001)
FIXED: Link to new 0.95 thread (thanks to nanorch)
FIXED: Clicking on "Preview" will now force "Use Manual Crop/Resize"
FIXED: Usage of AQ (previusly was always on) (thanks to zacoz)
FIXED: SPA to ESP in language (thanks to zacoz)
FIXED: Use of Constant_Quality with constrained disk settings AND Original width/height (thanks to Don_Genaro) -
AutoMKV 0.95c
ZitatADDED: Better tooltip layout
ADDED: Aspect error in log file
ADDED: Save personalized profile (suggestion by survivant001)
FIXED: 2 pass encoding with Nero AAC Audio and movie longer than 2 hours
FIXED: Reduced log (trimming all load plugin/import section) -
AutoMKV v0.96
DDED: "Suspend" to shutdown mode
ADDED: "PopCornHour" profile (thanks to weaver4)
ADDED: In the target output size added "Same as source"
ADDED: Support for neroAacEnc_SSE2
ADDED: Force compulsory MOD16 AUTOCROP (suggestion by MichaelAnders)
ADDED: M2TS input file. These files will be totally parsed when selected
ADDED: Check for NON AVC files inside M2TS
ADDED: "Safe" deinterlacer. This deinterlacer is the same as AUTO, BUT with a very low threshold for determining interlace pattern (so will be easy to trigger)
ADDED: Support for language tag on m2ts muxing
ADDED: Support for DivX 6.8
ADDED: Support for Specify Bitrate for DivX 6.8
ADDED: Support for Specify Quality for DivX 6.8
ADDED: Support for CQ Tune button for DivX 6.8
ADDED: Support to "Do the Third Pass" to DivX 6.8
ADDED: Support for eac3to (thanks to madshi). NOTE that you must supply correct audio decoder configuration:
AC3, E-AC3 and TrueHD decoding you need:
(1) Nero 7 (Nero 8 won't work!)
(2) Nero HD-DVD / Blu-Ray plugin
DTS decoding you need:
(1) "Sonic Cinemaster Audio Decoder 4.3" DirectShow filter
ADDED: 15000/1000 conversion fps (request by Honeyko)
ADDED: Possibility to specify path to chapters file. You must use chapter editor for create this chapter and save where you want
ADDED: Support for multi audio track in avi/mkv container input file. Yes you can choose the audio track inside a mkv input file
ADDED: Matroska folder to dinamyc path (thanks to jeroenvg)
ADDED: Buffer size to x264 basic profiles
FIXED: On Save Configuration the ini is now added automatically if not set (thanks to Cyrus221/Tirade)
FIXED: Forcing PAR with XviD
FIXED: --engage keep_bitstream_ar_info is now avaiable only for x264 encoding
FIXED: If neroaacenc.exe isn't present the default audio codec is now "Coding Tech. AAC"
FIXED: Some work on Queue
FIXED: In Command Line is now showed even the AQ Strength/AQ Sensitivity
FIXED: Tips! a Invaluable Thanks to Tirade for grammar and spellings
FIXED: Load and Save Conviguration could mismatch codec profile's (thanks to Spreeni)
FIXED: Number of threads is now saved in queue/Save Configuration (thanks to Spreeni)
FIXED: Suspend status (at least on Win XP) (thanks to Spreeni)
FIXED: NONE Resizer AND Automatic Crop combo usage (thanks by MichaelAnders)
FIXED: Hybrid Framerate support on queue
FIXED: Queue usage and AQ Sensitivity/AQ Strength
FIXED: On Save Setting the CQ Tune button wasn't triggered on start
FIXED: Use of "RIP ALL SUBS" when muxing into MP4 container
FIXED: AutoMKV log will better trace x264 log
FIXED: Memory leak on x264 encoding status window
CHANGED: 2_Pass_PS3_XBOX360 profile, now using uhm, and for second pass "me-prepass" (thanks to survivant001)
CHANGED: Reworked how files are checked at start
CHANGED: Readded default AQ. It will be always on as default. Set both values to 0 for disabling it
CHANGED: Totally reworked (AGAIN!!! ) WMV encoding. (note that support is very limited due to restrictive possibility of VC1 Encoder)
UPDATE: DGIndex 1.5.0rc3, MKVToolnix 2.2.0, X264 748, medianfo 0.7.6.0, tsmuxer 1.5.0b, eac3to2.31, ffmpegsource 1.16, bass audio 2.3 -
