In der Zwischenzeit gibt es nun auch schon Version 1.1.1.0; warum meldet stax0711 die eigentlich nicht hier zuerst?
http://www.planetdvb.net/staxrip
http://www.planetdvb.net/staxrip/download
http://www.planetdvb.net/staxrip/changelog
ZitatAlles anzeigen1.1.1.0 (2008-07-10)
Added support for custom source PAR
Many fixes and Improvements regarding various source formats
Many minor fixes and improvements
x264 updated to 900
DGAVCDec updated to 1.0.0a26 (info)
Some new MKV features added (info)
Tooltip added to tray icon showing console output (info)
Preparers can define which formats to be used and which not
Various aspect ratio fixes and improvements
VirtualDub updated to 1.8.1 (info)
Pass through encoder improved to handle not only previously encoded project but also source files
Since the pass through encoder was improved StaxRip can now be used to (batch) remux source files.
MediaInfo updated to version 0.7.7.2, it fixes reading aspect ratio from anamorphic avi source files
Some fixes and improvements picking up audio files
Added MP4 demuxing, improved MKV demuxing
Added support for more then one IDX (vobsub) file (info)
Added support to reorder IDX (vobsub) subtitles (info)
Various setup fixes and improvements (info, info, info)
Many useful directories added to the main menu
A couple of improved tooltips (info)
Fixed two bugs with adding jobs from a second StaxRip instance (info, info)
New command to play a sound file (info)1.1.0.1 (2008-05-27)
Fixed bug changes to the audio command line don't get saved1.1.0.0 (2008-05-27)
x264 updated to 859
DGMPEGDEC updated to version 1.5.0
The filter list control can be double-clicked in the empty area below the filters to add new filters
Added support for creating jobs with a second StaxRip instance
Fixed audio settings dialog command line preview not reflecting all changed parameters
Added command to set the maximum value of the target image resize slider
Menu item added in preview to set the end credits
Fixed various aspect ratio related bugs occuring with HD sources
Added support for image subtitles for MP4
Fixed shutdown being broke by XP SP3
Fixed broken Quick Search dialog which didn't set the selected path
mkvtoolnix updated to version 2.2.0
Downloading a external application will now delete the install files of the previous version
Fixed bug StaxRip asking for ProjectX and Java even when ProjectX is disabled
x264 profiles updated
Controls for various x264 switches added
Import of x264 profiles added
Yadif AviSynth filter added
Fixed bug in calculations occuring when crop values are set but the filter is disabled or missing
The aspect ratio display in the main dialog displays now the PAR
Support for using AviSynth scripts as source file
Distribution is now only three files (StaxRip.exe, Stax.dll, ReadFirst!.txt), 7-Zip archive is only 310 KB!
The .NET library to unpack zip files was replaced with 7-Zip to unpack external application
The Issue modul got dumped because of several issues, a forum is used instead for support now
The documents directory was removed, all docs are now online or created dynamically
Online links in the help browser are now opened with the default browser
Feature to add and remove file associations (main menu under 'Tools')
Couple of cosmetic changes in the main dialog
ProjectX updated to 0.90.2
Vorbis updated to TuVb5.5
Added possibility to copy seperators in the menu editor
DivX settings of old DivX versions will be reused with new DivX versions.
Various new macros and commands added
Split of output file added for XviD/DivX AVI output
MKV preparer added demuxing all streams using mkvextract
DGAVCIndex preparer added
The muxing profiles were replaced with a universal muxing profile that auto detects the stream type
New option which output mod to force, this was hardcoded to 16 previously
The range of the resize slider is adjusted automatically according the source image size
Improved assistant tips
TomsMoComp motion compensating deinterlace filter added
Improved Vista UAC handling
The mode in the dialog to open source files was changed to use large command buttons instead of a small list box
The profile 'Misc/No Encoding' was replaced with 'x264 pass through and 'AVI pass through'
New option to use NicAudio as alternative cutting method for mp2 and ac3
The x264 fixed size and constant quality profiles are now based on the HQ-Slow profile
MP4Box was downgraded since the used versions had some issues
Fixed assistant complaining the image size isn't mod 16 even when it is
The crop and preview dialog have improved startup dimensions for HD sources
With auto resize disabled StaxRip will now auto adjust the height according to the aspect ratio
New option to limit the aspect ratio to a defined value to auto crop the width instead
Fixed a bug with three pass encoding
Fixed crash caused by applications like TrueCrypt creating virtual hard drives
The preview can now show the display aspect ratio for anamorphic sources
The preview has now a menu to toggle between aspect ratios for anamorphic sources
The video and the window position of the crop and in the preview dialog is now remembered
The page in the x264 dialog is remembered
The external preview menu in the preview use now KMPlayer or MPC passing the current video position
Added setting to use double-click instead of single-click for the tray icon, the default remains single-click
When the process window is hidden in the tray, all applications will now be started hidden
Added button to the processing dialog showing a menu to disable jobs
The MKV and MP4 container settings have a option to add additional command line switches
The x264 dialog has a feature to manage custom switches more convenient
Automatic VobSub is now always performed if the option is enabled
Changing encoding settings from quality mode to multi pass and back updates the menu now
Changing the encoder will keep the muxer if compatible
Improved verifications to prevent users from problems
Improved diagnostics to help users better with errors
Most command line applications are executed hidden showing the output on the log dialog1.0.0.3 (2008-03-05)
Updated x264 profiles and encoder version
Automatic aspect ratio signaling added for DivX, that mean it's supported for all codecs
now
DivX is the only application I don't host myself. StaxRip links to the download
provided at divx.com. The reason is it's 15 MB big. Unfortunately there are
silent updates very often. While silent updates usually work with StaxRip, the
version detection complains. I've added a special handling for DivX now to
handle this issue. StaxRip don't require the exact but a minimum version now for
DivX
Automatic subtitle demuxing using VSRip added
The profiles dialog has a button now to clone profiles
Muxing audio profiles are now editable from the audio profiles dialog in order to edit the stream type
MPA and MP2 were added to be valid stream types for the MP4Box muxer
Warning added to be shown when trying to open files containing character in the filename the command line parser of DGIndex can't cope with
The em.bed.ded folder browser used to select directories to batch process shows now volume names and hides hidden folders
The delay macro was only available in the scope of the audio settings, there are
now three global macros delay, delay1 and delay2. The help of the audio settings
dialog explains now the different scope
%bitrate% macro added to be used in the audio settings dialog
The filters dialog, script editor in the filters dialog and the audio settings
dialog remember their size
The filter editor in the main dialog shows a script editor on double-click
instead of enable/disable the filter. The filter dialog shows the script editor
with a left-click while pressing Ctrl
Improved support running StaxRip with limited user privilegs which is the normal
case under Vista
