StaxRip Encoding-Frontend – Neue Versionen
  • In der Zwischenzeit gibt es nun auch schon Version 1.1.1.0; warum meldet stax0711 die eigentlich nicht hier zuerst? ;)
    http://www.planetdvb.net/staxrip
    http://www.planetdvb.net/staxrip/download
    http://www.planetdvb.net/staxrip/changelog
  • 1.1.2.0 beta (October 26, 2009)
    * Fixed x264 command line generation for --nr and --rc-lookahead switches
    * Updated x264 to rev 1310 and added new options for --b-pyramid
    * Improved default handling for various source formats
    Download
  • 1.1.2.1 beta (November 21, 2009)
    Download
  • 1.1.2.2 beta (December 03, 2009)
    Download
  • 1.1.2.3 beta (December 05, 2009)
    * Added option to the profiles dialog to batch move profiles out of and into sub menus
    * Added new AviSynth plugins and filter profiles
    * Added new handling to deal with settings stored with old versions
    * Added better help integration
    * Replaced AviSynth plugin auto loading with manual loading
    * Fixed crashes reported by various users
  • 1.1.3
    Download
  • 1.1.5.2 beta
    Download
  • Ahh, welch Erleichterung, vieles davon musste ich bisher immer manuell machen.
    Added feature to cut using mkvmerge when just muxing is used and no encoding is performed, can be enabled in the muxer configuration
    Der erste Schritt zu einem Smart-Rending MKV Cutter ;)
  • 1.1.5.3 beta
    • Fixed crash making a comp. check with sources having a high bitrate
    • Fixed crash streams in MKV sources containing titles using Unicode
    • Added setting to encode audio in parallel, disabled by default
    • Added option to change sample rate in audio dialog
    • Updated x264 to r1510, added Superfast preset, added --nal-hrd switch, added Blu-ray device and profile
    • Updated mkvtoolnix to v3.3.0
    • Updated eac3to to v3.18
    • Updated MediaInfo to v0.7.30
    http://sourceforge.net/projects/staxm…eta.7z/download
  • 1.1.6
  • 1.1.6.6 (beta 2010-07-31)
    • Added option to convert Blu-ray subtitles to VobSub subtitles using BDSup2Sub (Options > Subtitles > Convert Sup to Sub)
    • Added support for moving crop values into dgi file for GPU cropping (there is a question after the crop dialog closes)
    • Added NV tools to applications dialog and launch menu
    • Added source filter profiles DGSource 720p and DGSource 1024x576 but without reseting profiles
    • Added option to force ffmpeg as audio encoder, mostly useful to decode
    • Added warning appearing when the input format isn't supported by the audio encoder using the Execute feature in the audio dialog
    • Added possibility to edit the location and version in the Applications dialog, see F1, F11, F12 shortcuts
    • Added preview option in muxing dialog to preview subtitles with a external player including audio
    • Added option to open SUP and VobSub subtitles with BDSup2Sub in the muxing dialog useful to take a look at the subtitle content
    • Added display of file size for each subtitle file in the muxing dialog
    • Fixed bug second audio track not being picked up
    • Fixed bug audio delay not detected demuxing mkv
    • Fixed bug Execute feature in audio dialog not working when no video source is loaded
    • Fixed bug aspect ratio not properly detected for some source formats
    • Updated x264 to r1683
    • Updated mkvtoolnix to version 4.2.0
    • Updated ffmpeg to 2010-07-25
    • Updated MediaInfo to version 0.7.35.0beta
    • Reorganized muxing dialog
    • Changed eac3to to be the default AAC encoder
    • Disabled header compression for mkv muxing
    • Playing the script at Tools > Play file > AviSynth script or in the Preview dialog at Tools > External Preview adds sound to the script using NicAudio if possible and resizes to set the aspect ratio if necessary. It's now also possible to play the script from the filters menu in the main dialog
    https://sourceforge.net/projects/staxm…eta.7z/download
  • 1.1.6.7 beta (2010-08-10)
    • Fixed bug trying to run DGIndexNV even though it's not installed
    • Fixed bug same source file picked up for both audio tracks
    • Fixed bug mkvmerge custom command line parameters with attachments added to MP4Box custom command line parameters
    • Fixed bug subtitle preview in cropping dialog not showing subtitles due to MakeMKV created idx files not being compatible with vsfilter, also inserted subtitle filter after cropping both in the subtitle preview and in the add hardcoded subtitle feature in the main dialog
    • Added WebM video encoder profile with simple GUI, WebM muxer profile and WebM template
    • eac3to demuxer defaults now to mkv output, DGIndexNV, ffms2 and DSS can open it, DGAVCDEC can't
    • Removed asking to demux video from MKV now using defaults, AVC and MPEG-2 is not demuxed since DSS, ffms2 and DGIndexNV can open it
    • In case the first audio decoding method fails a second method is tried
    • Changed shortcut for 'No Crop' in Cropping dialog to N and added new menu item 'Crop Options...' showing the crop options directly from the Cropping dialog
    • In case the audio track language is undetermined StaxRip now first tries to find a track with language of the current locale as track 1 and english as track 2
    • Improved source PAR detection for some formats
  • 1.1.6.8 beta
  • 1.1.6.9 beta (2010-08-31)
    • Improved source aspect ratio and frame rate detection
    • New Getting Started dialog for beginners
    • Various tweaks to improve handling of rare formats
    • Updated DGMPGDec to version 1.5.8
    • Replaced old folder browser with new vista filder browser
    • Fixed bug video delay in MKV not detected
    • Added various eac3to and BeSweet options
    • Updated x264 to r1703
  • 1.1.7.0 beta (2010-09-19)
    • Fixed trying to create forced subtitle files without Java being installed
    • Fixed Java x64 not being detected
    • Fixed StaxRip trying to use a network directory as temp files directory, opening a source from a network directory StaxRip will now ask for a local temp files directory
    • Fixed native crash in the Event Commands editor happening with command having Boolean values
    • Fixed bug failing to mux mono audio streams
    • Updated Nero to version 1.5.4
    • Updated x264 to r1724
    • Changed default audio processing back to BeSweet for input formats supported by BeSweet, apparently it's more reliable then eac3to
    • Changed start credits default to q=30, end credits q=35, reset preview dialog menu to force new defaults
    • Enabled sup to sub conversion by default and silently omit execution in case Java isn't installed
  • 1.1.7.1 beta
    Updated MP4Box to version 0.4.6 that hopefully fixes sync problems
    Updated ffms2 to version 2.15 mt
    Updated x264 to version r1995
    Updated mkvtoolnix to version 4.7.0
    Fixed bug 'DTS Express' format not detected
    Added option to modify existing cut selection, overlapping selections are merged
  • 1.1.7.2 beta
