1.3.1.5 beta
New: Added full first class VapourSynth support including plugins and profile for QTGMC
New: Added possibility to switch dynamically between any source filter back and forth including DGSource and DGSourceIM. Indexing is triggered automatically in case no index file is present
New: Added vinverse plugin to remove residual combing from NTSC
New: Added GUI for demuxing MKV and MP4
New: Added feature to easily enable certain parameters for certain filters in the AviSynth editor. Currently supported are FFVideoSource and DGSource, more parameters and filters might be supported on request. Use it by right-clicking on FFVideoSource or DGSource in the AviSynth editor, the menu shows then NTSC options and hardware cropping and resizing options.
New: Added Play option for MPC playback in the AviSynth editor
New: Added two new options in the dialog to define files for batch processing to add a entire folder and a entire folder including sub-folders
New: Added new subtitle UI based on data view
New: Added option to generate subtitle names based on the subtitle language
New: x265 switch --limit-refs added
Fix: Disabled audio demuxing for MKV and MP4 by DGIndexNV and DGIndexIM because it's already demuxed by MP4Box and mkvextract
Fix: Tools/Directories/Plugins wasn't pointing to the AviSynth+ plugin directory
Fix: Wrong command line generated for --deblock
Update: QSVEncC 2.0 beta 11
Update: x265 1.7+234
Tweak: DTS bitrate is now unrestricted
Tweak: Moved field processing filters to dedicated category like before in StaxRip x86
Tweak: Replaced LinkLabels with Buttons in eac3to dialog
Tweak: The help for all included AviSynth plugins can now be accessed per menu in the AviSynth editor
Tweak: ProjectX is enabled by default in case Java exists, other dsmux will handle MPEG-2 TS
Tweak: In the dialog to define files for batch processing the 'Create Jobs' option was renamed to 'Demux and index before adding jobs', regardless of if this option is enabled jobs are always created
Tweak: Removed x86 and VS C++ 2013 from AviSynth+ installer bringing it from 18 MB down to 4 MB. Very often VS C++ 2013 is already installed and in case it ain't already installed StaxRip will show the Apps dialog which has a download button for VS C++ 2013.
Tweak: replaced avs4x26x with ffmpeg
Alles anzeigen
