StaxRip Encoding-Frontend – Neue Versionen
  • 1.3.1.5 beta
  • 1.3.1.6 beta
  • 1.3.1.7_beta
  • 1.3.2.0
    Einmal editiert, zuletzt von Schotenhüter (3. März 2016 um 16:42)
  • 1.3.4.0_stable
  • v1.3.7-stable (2016-06-14)
    New Features
    • added new QSVEncC switches
    • added support to use network drive as temp folder
    • added yadifmod for VapourSynth. Due to popular request I didn't reset the filter profiles, to make the default filter profile for yadifmod available the filter profiles must be manually reset in the filter profile editor.
    • added new command SaveJpgByPath to preview dialog which can be used to customize the menu to save a jpg file to a fixed path without the file browser showing, the path can contain macros.
    • added taskbar progress support
    Fixed Bugs
    • fixed the check for enough free space on the disk of the target file, instead of three times the source file one time is now enough
    • fixed crash StaxRip checking for enough free space in file batch mode and if target directory is network share
    • fixed Umlaute don't work on Windows 7
    • fixed many avs/vs scripts are created when the target file name is changed by typing
    • fixed feature to run jobs in new instance and changed the behaviour of this feature in that when the jobs complete the instance exits without overwriting the settings
    Updated Tools
    • QSVEncC 2.51
    • yadifmod (VapourSynth) r9
    https://github.com/stax76/StaxRip/releases
  • 1.4.0.0
    Einmal editiert, zuletzt von Schotenhüter (27. Juli 2017 um 09:35)
  • 1.5.0.0
  • 1.6.0.0 stable build
  • 1.7.0.0
    https://github.com/stax76/staxrip/releases
  • 2.0.0.0
    • Tweaked the Temp Folder Creator & Path.
    • Removed some old Code, That wasn't doing anything anymore.
    • AVSMeter has Been Updated to 2.8.6.
    • Updated eac3to, fdkaac & qaac.
    • Both FFMPEG and MPV now use custom Builds instead of the normal default build(Which Fully Supports VapourSynth).
    • FFMPEG & Shared dll Files has been Updated to 20181026
    • MPV has been Updated to 20181026
    • Added Limited Support for VS in MPV(Requires VSPipe).
    • nnedi3 for AVS has Been Updated to 0.9.4
    • FFMPEG, x264, x265 & MPV are now compiled Using GCC ToolChain instead of MVS.
    • x264 has Been Updated to 2935
    • x265 has Been Updated to 2.9+2
    • Python Search Path has been Updated to 3.7/3.7.1 & Python 3.6 has been Removed.
    • Also Included Support for Anaconda3.
    • The VapourSynth Script has been slightly altered to work better with Python Search Path.
    • VS has been Updated to R45.
    • MKVToolNix Updated to 28.2.0.7
    • Updated the Update Script to Support additional HTML Protocols, due to the changes on the website.
    • Added hnwvsfunc for VS & mClean to Context Menu.
    • Cleaned up the AVS Filter Names.
    • Added MultiSharpen Function
    • Modified the Profile List for x265, Only Profiles that work with Current Selected Depth with Display.
    • Removed any 8Bit x265 that no Longer used with 2.9(Based on: https://x265.readthedocs.io).
    • Moved Some Extra Functions to the System Process.
    • Custom Directory Output Option has been Added to StaxRip Thumbnail Creator & MTN. It's Default Directory is the last Used Location. If none is known it defaults to C Drive(Fresh Install)
    • Added support for Long Path Aware(Make Sure to Enable it If your OS Supports it)
    • Fixed any Issues for very Short filenames being converted to wrong type.
    • Removed MediaInfo 18.08.1 Due to Bugs it contains and Re-Added MediaInfo 18.05.
    • Added More Support for HDR to Intel Encoder.
    • VS Filters Added: W3FDIF, MiniDeen, IT, TDeintMod, vcfreq, vcmove & TemporalMedian.
    • Updated mvtools-sf to AVX, The latest Builds only use AVX2 which not all CPU's Support.
    • Added Support for RawSourcePlus for Avisynth and RawSource for VapourSynth. Default Pixel_type is set to YUV420P10 (aka P010).
    • Dual Package Setup for x264 have been Removed for Single release x264(8+10Bit). The Depth menu will set the Output Bits, exactly like x265.
    • Following Have Been Added to x264:
      • ColorMatrix: Added chroma-derived-nc, chroma-derived-c, and ICtCp.
      • Added Alternative Transfer
      • vbv-init has been modded to have a locked value and proper float point scaling.
    • FFTW Files will auto copy to System Directory, if your PC is missing these files in the System32 Folder(Fresh Install).
    • MP4Box is back to Static Once again.
    • Included Setup files for Python 3.7.1 & VS R45 to make sure the proper versions are being installed for StaxRip.
  • 2.0.2.0
    fix: downloads were using 7z extension even though it was zip instead of 7z
    update: LSMASHSource avs
    update: mkvtoolnix
    2.0.1.3
    2.0.1.2
    fix for audio streams demuxed as mka
    2.0.1.1
    new: nvencc --vpp-nnedi, --vpp-yadif
    new: few new x265 switches added
    2.0.1.0
    2.0.0.2
    2.0.0.1
    2.0.0.1 Beta
  • 2.0.4.0 Stable
    update: ffms2 2019-08-30 StvG, successfully tested was the load time, memory usage and avs/vs compatibility
    update: L-Smash-Works r935+34 2019-08-29 MeteorRain, successfully tested was the load time, memory usage and avs/vs compatibility
    update: MediaInfo 19.07
    update: ffmpeg 4.2 Wolfberry
    update: nvenc 4.46
    update: qsvenc 3.24
