StaxRip Encoding-Frontend – Neue Versionen
  • 1.3.1.5 beta
  • 1.3.1.6 beta
  • 1.3.1.7_beta
  • 1.3.2.0
  • 1.3.4.0_stable
  • v1.3.7-stable (2016-06-14)
    New Features
    • added new QSVEncC switches
    • added support to use network drive as temp folder
    • added yadifmod for VapourSynth. Due to popular request I didn't reset the filter profiles, to make the default filter profile for yadifmod available the filter profiles must be manually reset in the filter profile editor.
    • added new command SaveJpgByPath to preview dialog which can be used to customize the menu to save a jpg file to a fixed path without the file browser showing, the path can contain macros.
    • added taskbar progress support
    Fixed Bugs
    • fixed the check for enough free space on the disk of the target file, instead of three times the source file one time is now enough
    • fixed crash StaxRip checking for enough free space in file batch mode and if target directory is network share
    • fixed Umlaute don't work on Windows 7
    • fixed many avs/vs scripts are created when the target file name is changed by typing
    • fixed feature to run jobs in new instance and changed the behaviour of this feature in that when the jobs complete the instance exits without overwriting the settings
    Updated Tools
    • QSVEncC 2.51
    • yadifmod (VapourSynth) r9
    https://github.com/stax76/StaxRip/releases
  • 1.4.0.0
  • 1.5.0.0
  • 1.6.0.0 stable build
  • 1.7.0.0
    https://github.com/stax76/staxrip/releases
