SMPlayer - neue Oberfläche für MPlayer
  • update auf 0.2.26
    * New fullscreen mode. The code has been rewritten. Previously I used a different widget (window) for fullscreen. Now I use the main window (hidding all widgets except the video window).
    The most important: now if you move the mouse to the bottom of the screen the control widget will appear (see screenshot). If you move it to the top of the screen the menu bar will appear.
    And now opening another window (open dialog, video equalizer, the preferences dialog...) doesn't need to exit from fullscreen.
    But as I said the code in completely new, so please test it and report bugs.
    * Added an option who people with wide screens can find useful: 16:9 letterbox. If you play for instance a 2.35:1 movie, this option will add black borders to fit 16:9. The interesting thing is that subtitles will appear in the bottom border.
    Quelle
  • smplayer_update_0.3.27
    Changelog
    Version 0.3.21 - 0.3.27
    * A lot of internal changes: now QAction's are used for most of the menus, constants have been changed to enums. Due to the amount of changes it's possible that something could have broken. Please test it, specially audio and subtitle selection, aspect ratio options, and well... everything in the menus...
    * The Gui class has been divided into BaseGui and DefaultGui. The intention of this it to allow to create alternative GUI's easily (when I say GUI in fact I mean the main window). The DefaultGui is less than 300 lines of code.
    * The new GUI has been written from scratch and it has some toolbars. This GUI has been written today in a few hours and it's not finished yet. Unfortunately the "controlwidget over the video" from previous releases has not been implemented yet in this GUI.
    * Updated the Italian, German, Hungarian and Russian translations.
    * Added the Georgian translation.
    Download (Linux / Windows)
    http://smplayer.sourceforge.net/windows/download_en.php
  • 0.4.3
    * Added the Bulgarian translation.
    * Updated the Polish translation.
    * Qt 4: Made the repaint of the mplayer window more or less like Qt 3. At least this seems to fix some small cuts in the audio when resizing. But still the window is getting black after changing the language in preferences. I don't know why.
    Report if you find problems with this (more flickering than before or something).
    * Started to implement the system tray icon. You need Qt 4.2 to see it.
  • smplayer_0.5.0 !
    There aren't many changes since the last announcement here, mostly small fixes. Although now there's an option which could make that srt/sub subtitles could look much better (info here).
    But the most important is that a new full package with installer is available (about 11 MB). It also includes a more recent mplayer build.
    There are also a zip and a 7z packages (in this case without mplayer).
    http://forum.doom9.org/showthread.php?p=1008731#post1008731
  • Full package for SMPlayer 0.5.2 is now available
    Why a new package so soon?
    Because Qt 4.3 has been released. Now SMPlayer is compiled with this version.
    According to the docs, Qt 4.3 provides a feature that maybe some users may find interesting: Qt applications running on Window Vista will look as native applications.
    SMPlayer
  • Kein mp4 Splitter dabei - keine Untertitel und Kapitel
    cu
    Joe
    __________________
    Freedom ist just another word for nothing left to loose.
  • JoeB
    Edit:
    Quatsch - 2 mal Unsinn !
    MP4 läuft über den MOV muxer. Untertitel gehen auch.Kapitel nicht.
    Allerdings ist das nicht das gelbe vom EI.
    Werde ich mal rvm schreiben...
  • JoeB
    Edit:
    Vielen Dank :)
    cu
    Joe
    __________________
  • update 0.5.8 verfuegbar
    Download
    wie sieht es denn mit dem mp4 Support aus? Wäre doch toll wenn integriert? :)
    cu
    Joe
    __________________
  • MPlayer unterstützt schon seit geraumer Zeit MP4 Dateien ;)
    Das ist natürlich klar :) Aber der smplayer hat einen mkv splitter welcher es ermöglicht die Kapitel zu sehen sowie die Namen der streams. Sowas wünscht man sich natürlich auch für mp4 - ist ja klar ;)
    cu
    Joe
    __________________
  • Version 0.5.10
    * Moved the denoise submenu inside the video filter menu.
    * (By user request) Added the option "AC3/DTS pass-through S/PDIF" in Preferences->General. It will simply add "-afm hwac3" to the command line.
    * Renamed "Yadif (mode 0)" to "Yadif (normal)", and "Yadif (mode 1)" to "Yadif (double framerate)".
  • update
    Download
