SMPlayer - neue Oberfläche für MPlayer
  • 16.4
  • 16.6
    * Support for 2 in 1 computers with touch screens. SMPlayer includes now a 'tablet mode', available in the menu Options. When the option is turned on it makes some changes in the interface so that it would be easier to control SMPlayer by touching the screen. When the user changes the tablet mode in the Windows 10 action center, SMPlayer will detect it and ask if it should switch to the SMPlayer's tablet mode as well.
    * Option to send video to an external screen. Now it's possible to send the video to a second screen connected to the computer, while controlling the application in the computer's screen.
    * Support for high DPI screens. On high DPI (dots per inch) screens SMPlayer looked very tiny. Now the interface is automatically scaled so it looks correctly. There are also settings in Preferences -> Interface -> High DPI where you can adjust manually the scale factor or turn off this feature.
    * Global shortcuts. Now it's possible to use the media keys (play/pause, stop, volume+/-, etc.) as global shortcuts. That means that those keys will work even when SMPlayer is in the background. You can activate this option in Preferences -> Keyboard and mouse.
    * Settings are remembered for online streams too. This means that, for example, SMPlayer can resume playback or set bookmarks on YouTube videos or other online streams (as long as they are seekable).
    * SMPlayer is now built with Qt 5 by default.
  • 16.8
    * The playlist has been improved. Now it's possible to sort by any column. There's a new column, with the path of the file (or URL) (this allows you to sort the list by folder). Now it's possible to search (actually filter) in the playlist. And finally there's a new option to load a playlist from internet. As example, you can enter this URL: http://smplayer.info/onlinetv.php It will download a playlist with some online TV streams.
    * Bug fixes.
  • 16.9
    * New option to send the audio to the specified audio device. It can be useful to send the audio to a TV via a HDMI cable or wireless headphones via bluetooth.
    * Some improvements on the playlist. Now it's possible to hide any column (right click to see the options). The search field is also hidden by default, a new search button shows/hides it. This changes are intended to prevent the playlist window to be too wide. * Due to bugs and problems with Qt 5, the packages for Ubuntu are now built again with Qt 4 by default.
    * Bug fixes.
    http://smplayer.sourceforge.net/de/downloads
  • 16.11
    * More options in Preferences -> Playlist to better control the behaviour of the playlist. Changing some of the options makes easier to use the playlist for bookmarks.
    * New option 'Show info on OSD' in View -> OSD (shortcut Shift + I). It displays info about the current media (resolution, bitrate...) on the OSD.
    * Bug fixes.
  • 17.1
    * Experimental support to play videos on Chromecast.
    * Support for some of the #EXTVLCOPT options in m3u/m3u8 playlists. This may help to play online streams from playlists intended for VLC.
    * New options in the context menu of the playlist: "copy URL to clipboard", "open source folder" and "play on Chromecast".
    * Option to display bitrate information in the status bar.
    * Possibility to display the playback time with milliseconds in the status bar.
    * The option to add black borders on fullscreen is back (preferences -> general -> video).
    * The option to delete files from the disk in the playlist's context menu has been removed.
  • 17.2
    * Fix for YouTube.
    * The option to delete files from the disk in the playlist is back but it's disabled by default (you can enable it in Preferences -> Playlist -> Misc.
    * On Linux SMPlayer now uses a different web server, included in the packages, to serve files for Chromecast. If you installed the package webfs you can uninstall it now since SMPlayer won't use it anymore.
    * New translation: Norwegian Bokmål.
  • 17.4.2
    * New option (menu View -> OSD) to display the times with milliseconds.
    * New fix for the thumbnail generator that works also with older versions of mpv.
    * Bugfix: the position of the video is remembered when it's opened by drag & drop.
    * The Windows installer won't install mpv on Windows XP since mpv is not longer compatible with Windows XP.
    * New option to use the mplayer ffhevcvdpau decoder (Linux only).
    * Avoid some crashes from mpv.
  • 17.7
    * Add some options to configure the conversion of srt subtitles to vtt for Chromecast (Preferences -> Network -> Chromecast), like the position of the subtitles on screen.
    * Fix a crash that may happen in the playlist when trying to delete selected items.
  • 17.11
    * The video equalizer by software has been fixed.
    * The thumbnail generator is now more precise with short videos.
    * The audio quality of the audio equalizer has been improved.
    * The option "add black borders on fullscreen" has been fixed.
    * The option "AC3/DTS passthrough over S/PDIF" has been fixed.
  • 17.11.2
    * A crash that may happen on KDE when the global menus
    are activated has been fixed.
    * Fix: SMPlayer won't cancel logout in KDE.
    * The seek function in the MPRIS2 code has been fixed.
  • 17.12
    * Two new actions to take screenshots with or without subtitles (they only work when using mpv). Assigned by default to Ctrl+Shift+S and Ctrl+Alt+S.
    * New action which displays the filename in the OSD for 2 seconds. Assigned by default to Shift+O.
    * New option osd_bar_pos for smplayer.ini. It specifies the position of the OSD bar (0 = top, 100 = bottom).
    * The support for DVD menus has been removed. It never worked well and also mpv already removed support for it a long time ago.
    * The option to open an informative page after an upgrade has been removed.
