SMPlayer - neue Oberfläche für MPlayer
update auf 0.2.26
Zitat* New fullscreen mode. The code has been rewritten. Previously I used a different widget (window) for fullscreen. Now I use the main window (hidding all widgets except the video window).
The most important: now if you move the mouse to the bottom of the screen the control widget will appear (see screenshot). If you move it to the top of the screen the menu bar will appear.
And now opening another window (open dialog, video equalizer, the preferences dialog...) doesn't need to exit from fullscreen.
But as I said the code in completely new, so please test it and report bugs.
* Added an option who people with wide screens can find useful: 16:9 letterbox. If you play for instance a 2.35:1 movie, this option will add black borders to fit 16:9. The interesting thing is that subtitles will appear in the bottom border. -
Daily update: smplayer_update_0.2.34.zip (346 KB)
http://smplayer.sourceforge.net/download_en.php -
Daily update: smplayer_update_0.2.40.zip
New full packages for smplayer 0.3.0, with installer, are available:
smplayer_update_0.3.27
ChangelogZitatVersion 0.3.21 - 0.3.27
* A lot of internal changes: now QAction's are used for most of the menus, constants have been changed to enums. Due to the amount of changes it's possible that something could have broken. Please test it, specially audio and subtitle selection, aspect ratio options, and well... everything in the menus...
* The Gui class has been divided into BaseGui and DefaultGui. The intention of this it to allow to create alternative GUI's easily (when I say GUI in fact I mean the main window). The DefaultGui is less than 300 lines of code.
* The new GUI has been written from scratch and it has some toolbars. This GUI has been written today in a few hours and it's not finished yet. Unfortunately the "controlwidget over the video" from previous releases has not been implemented yet in this GUI.
* Updated the Italian, German, Hungarian and Russian translations.
* Added the Georgian translation.Download (Linux / Windows)
http://smplayer.sourceforge.net/windows/download_en.php -
* Added the Bulgarian translation.
* Updated the Polish translation.
* Qt 4: Made the repaint of the mplayer window more or less like Qt 3. At least this seems to fix some small cuts in the audio when resizing. But still the window is getting black after changing the language in preferences. I don't know why.
Report if you find problems with this (more flickering than before or something).
* Started to implement the system tray icon. You need Qt 4.2 to see it. -
smplayer_0.5.0 !
http://smplayer.sourceforge.net/windows/download_en.phpZitatThere aren't many changes since the last announcement here, mostly small fixes. Although now there's an option which could make that srt/sub subtitles could look much better (info here).
But the most important is that a new full package with installer is available (about 11 MB). It also includes a more recent mplayer build.
There are also a zip and a 7z packages (in this case without mplayer).
Full package for SMPlayer 0.5.2 is now available
ZitatWhy a new package so soon?
Because Qt 4.3 has been released. Now SMPlayer is compiled with this version.
According to the docs, Qt 4.3 provides a feature that maybe some users may find interesting: Qt applications running on Window Vista will look as native applications.
Kein mp4 Splitter dabei - keine Untertitel und Kapitel
JoeB
Edit:
Quatsch - 2 mal Unsinn !MP4 läuft über den MOV muxer. Untertitel gehen auch.Kapitel nicht.
Allerdings ist das nicht das gelbe vom EI.
Werde ich mal rvm schreiben... -
JoeB
Edit:
Werde ich mal rvm schreiben...Vielen Dank
update 0.5.8 verfuegbar
ZitatVersion 0.5.8
* Updated the Italian, Simplified-Chinese and Swedish translations.
* Added two new options in the Video->Deinterlace menu: kerndeint and yadif (mode 1). The latter option should give a much more fluid motion than the normal yadif option, but you need a really fast computer, as this option uses a lot of CPU.
Some videos require to change the field dominance to work properly, so an option for this will be added in the future. Meanwhile you can pass the option -field-dominance to mplayer if you need it.Version 0.5.7
* Added *.ac3 to the list of audio filters in the open dialogs.
* On startup, if the previous height of the window is less than 200, then the window is resized to the default size.
* Updated the Polish and German translations.
* Updated the instructions to make a deb package in Install.txt.Version 0.5.6
* Updated the German and Ukrainian translations.
* Changed the buttons in the floating control from QPushButtons to QToolButtons.
* Added an option in Preferences to enable or disable the cache. (Cache could be disabled by setting it to 0, but this is clearer).
The cache is disabled by default, as it seems this option causes some trouble with some video formats. As a side effect now videos start to play faster.Version 0.5.5
* Added in the audio menu an option to load an external audio file (and another one to unload it). This allows to watch movies on which the audio track is in an external file (mp3, wav...).
Note: if you play the movie again later, you'll see two audio tracks in the menus (the original one, and the external one), but changing tracks doesn't work. Strange things may happen if you do it.
* Added the option "dont_use_eq_options" in the config file, ([preferences] section). If set to true, smplayer won't pass the options -brightness, -contrast, -hue, and -saturation to mplayer. It seems that some graphic cards don't support them or have some kind of problem with them.
* Updated the German translation
* Added an empty icon for gamma (to prevent this slider to be higher than the rest).Version 0.5.4
* The size of the floating control can be changed, editing the config file.
Option floating_control_width under the [default_gui] section. The value is a percentage (100 = all screen width, 50 = half of the screen width). By default, 100.
* The size and position of the main window will be remembered.
* (Qt 4) The balloon that remembers you that the program is already running in the system tray will be shown only 5 times.Version 0.5.3
* Updated the Polish and Russian translations.
* New fullscreen control widget, smaller than the previous one. If using Qt 4 it's better not to use the CleanLooks style, its buttons are huge and look awful in this widget.
* Fixed bug #1729705 (I hope). This has required a lot of changes, so other bugs may appear. -
wie sieht es denn mit dem mp4 Support aus? Wäre doch toll wenn integriert?
MPlayer unterstützt schon seit geraumer Zeit MP4 Dateien
Das ist natürlich klar Aber der smplayer hat einen mkv splitter welcher es ermöglicht die Kapitel zu sehen sowie die Namen der streams. Sowas wünscht man sich natürlich auch für mp4 - ist ja klar
ich kann smplayer nach dem Update auf 0.5.8 nicht mehr starten. Kann das einer bestätigen?
News Bereich !!!
Fragen bitte hier : http://forum.gleitz.info/showthread.php?p=335470#post335470 -
Version 0.5.10
Zitat* Moved the denoise submenu inside the video filter menu.
* (By user request) Added the option "AC3/DTS pass-through S/PDIF" in Preferences->General. It will simply add "-afm hwac3" to the command line.
* Renamed "Yadif (mode 0)" to "Yadif (normal)", and "Yadif (mode 1)" to "Yadif (double framerate)". -
update
ZitatVersion 0.5.14
* Updated the Swedish, Ukrainian and Polish translations.
* I think for volume normalization it's best to have a global option, so I added a volume normalization option in Preferences->General. If checked the volnorm filter will be used for all files.
* Added an option in Preferences->General to set the maximum amplification level for softvol. By default 110. Valid range 10-10000.Version 0.5.13
* Updated the Ukrainian, German and Polish translations.
* (By user request) Now the mouse wheel can be configured to zoom the video (Preferences->Keyboard and mouse->Mouse).
Note: compatibility couldn't be kept, if you have previosly changed the behavior of the mouse wheel you'll need to change it again.
* Now the options in the menu Video->Size will always be executed even if the option is already selected. Useful if you resized the window. Also added shortcuts for Size->100% and Size->200% (Ctrl+1 and Ctrl+2) and I'm very sorry but these shortcuts can't be changed.
* (By user request) Added the option Audio->Filters->Volume normalization.
Note: this option only affects the current file, if you want the filter to be used for all files add "volnorm" to the audio filters field in Preferences->Advanced.
* (By user request) Clicking in the system tray icon with the mouse middle button pauses/unpauses the file.
* Now tooltips for QActions are explicitly created, to try to work around a bug in Qt 4.3.Version 0.5.12
* Updated the Swedish, German and Ukrainian translations (although changes I've just made could have broken them...)
* Reorganized a little bit the preferences dialog, by using several tab widgets. This prevents that sections grow to much.
* Better explained the "MPlayer language" section (I hope) and added regular expressions for Spanish, Italian, German and French in the comboboxes, taken from the MPlayer translation files (completely untested!).Version 0.5.11
* Updated the Ukrainian and German translations.
* Shortcuts for previous and next items in playlist didn't work in main window. Fixed.
* Added an option in Preferences->Subtitles to use the new -subfont option in MPlayer. In the future SMPlayer will try to autodetect when this option is needed.
* Added in Preferences a new section: MPlayer language, where the user can change some of the texts that SMPlayer looks for. Intended in case that MPlayer displays its messages in another language. (Unfortunately MPlayer can't change language at runtime). -
