SMPlayer - neue Oberfläche für MPlayer
  • 18.2
    * Now it's possible to use a priority list of preferred languages for the audio and subtitles.
    * Now there's support for YouTube playlists. In the playlist window, click in the Load/save icon, select "Load playlist from URL" and paste the URL of the YouTube playlist.
  • 18.2.2
    * The option Open -> URL can now also load YouTube playlists.
    * New option in Preferences -> Subtitles to select the opacity of the background of the subtitles (available when the "border style" is set to "opaque box").
    * The options to select the preferred number of track for audio and subtitles are back.
    * (mpv) Now the direct3d is the default video output for Windows, since some users reported problems with the gpu output.
  • 18.4
    * Bugfix: the time displayed by a tooltip when the mouse is over the seekbar is now much more accurate.
    * There's now an option in Preferences -> Advanced to set the position of the OSD bar.
    * Now it's possible to turn off the use of the system native file dialog in Preferences -> Interface.
  • 18.5
    * (Windows) A problem which might prevent SMPlayer to open filenames with unicode characters has been fixed.
    * Fix: the cursor keys should now work in the playlist.
    * Now it's possible to select which multimedia keys should be used as global shortcuts (Preferences -> Keyboard and mouse).
    * (Windows) It seems on some systems the multimedia key events are sent twice, making some keys (like volume mute or play/pause) almost unusable. This version tries to detect it and prevent it.
    * "opus" has been added to to the list of audio extensions.
  • 18.6
    * On Windows 10 the key shortcuts for play next/previous left a "busy" mouse cursor on the screen. This is fixed now.
    * There's a new option in Preferences -> Playlist to choose the type of window for the playlist: dockable (as before) or just a normal window.
    * The library used by the web server for the chromecast feature has been updated. It looks like the old one had several vulnerabilities so it's recommended to update.
