DVD Encoding - FAQ
(Stand 06.01.2003) - (von Rasta21)
Wem es ums Kopieren geht, der kann das hier lesen:
Wie kopiere ich DVDs? - DVD9 & DVD5 -> DVD±R
01. DVD spezifikationen
02. CCE Tips&Tricks
03. Matrizensammlung
04. Womit encoden
05. Bitratenrechner
QuoteDisplay MoreDVD uses a subset of MPeg standards ISO/IEC 11172 (MPeg-1) and ISO/IEC 13818 (MPeg-2).
Restrictions
- Streams - 1 video, up to 8 audio
- Coding - MPeg-1 vbr/cbr, MPeg-2 MP@ML or SP@ML vbr/cbr
- Data rate
MPeg-1 maximum video 1856Kbps, maximum audio 384Kbps
Mpeg-2 maximum video 9800Kbps, maximum audio 912Kbps
note: audio options other than MPeg exist, see extensions- Image size
Mpeg-1 352x240 (NTSC) or 352x288 (PAL/SECAM)
Mpeg-2 720x480, 704x480, 352x480 (NTSC)
720x576, 704x576, 352x576 (PAL/SECAM)- Frame rate
coded - 24fps progressive, 29.97fps interlaced (NTSC only), 25fps interlaced (PAL/SECAM only)
displayed - 29.97 (NTSC) and 25fps (PAL/SECAM)- Color space
color primaries and transfer characteristics
NTSC - 4 (ITU-R BT.470 M) or 6 (SMPTE 170 M)
PAL - 5 (ITU-R BT.470 B or G)matrix coefficients (RGB to YCbCr)
5 (ITU-R BT.470 B or G) or 6 (SMPTE 170 M)- Audio sampling rate - 48KHz (MPeg audio only, other audio formats have their own rates)
- Aspect ratio - either 4:3 or 16:9
- GOP max
MPeg-1 18 frames (NTSC), 15 frames (PAL/SECAM)
MPeg-2 36 fields (NTSC), 30 fields (PAL/SECAM)
note: typical rate is .5 seconds, with one GOP per VOBU
note: GOP's are NOT optional- pack size - fixed at 2048 bytes, system stream level (one DVD sector)
- Low delay - not permitted
Extensions
- Private stream 1 (Audio and subpictures)
sub-stream 0x20 to 0x3f are subpictures
sub-stream 0x80 to 0x87 are audio (AC3, DTS, SDDS)
sub-stream 0xA0 to 0xA7 are LPCM audio- Private stream 2 (Navigation) - see PCI packet and DSI packet
Autor: mpucoder
02. CCE Tips&Tricks
An alle CCE Geplagte - Gesammelte Tips und Tricks Thread aus dem CCE forum by gerti67
kleine Matrizensammlung by YUV 4 2 0
04. Womit encoden/transcoden
cinema craft encoder
TMPGEnc
ReMPEG2 1.5.2 - MPEG2 Transcoder
bbMPEG 1.24b18 - latest beta, free MPEG-1/2 encoder
05. Bitratenrechner
CCEGuesser
powerbit
bitrate calculator spreadsheet Excel 97/2K/XP/OpenOffice 1.0 formats
DVD-R calculator
Fit2Disc (donate-ware)
