hallo wie die überschrift schon sagt habe ich ein problem.
also als erstes meine versionen:
Dvd Rb 1.26.5 pro
encoder HCenc 0.22
avisynth 2.57
mein problem ist das der dvd rb beim rebuilden immer eine fehler meldung ausspuckt seit ich HCenc verwend:SOURCE IS CORRUPT: VTS_01 VOBID: 03/CELLID: 20 was not found in the VOB.
habe Vorher cce sp2 verwendet
habe es schon mit anderen quellen versucht um auszuschliesen das die eventuel defekt is aber eben genau das selbe prob
so nun noch die rebuilder log bitte um hilfe mfg Phantom2007
[16:45:39] Phase I, PREPARATION started.
- DVD-RB v1.26.5
- AVISYNTH 2.5.7.0
- HC v0.22.0.0 encoder selected
- Source: DOCUMENTS
- VTSM_01: 72.973 sectors.
-- Scanning and writing .D2V & .AVS files
-- Processed 4.823 frames.
-- Building .AVS and .ECL files
- VTS_01: 3.224.581 sectors.
-- Processed 228.523 frames.
- Reduction Level for DVD-5: 66,1%
- Overall Bitrate : 3.549Kbs
- Space for Video : 4.043.762KB
- HIGH/LOW/TYPICAL Bitrates: 7.552/1.638/3.549 Kbs
[16:49:29] Phase I, PREPARATION completed in 4 minutes.
[16:51:20] Phase II ENCODING started
- Creating M2V for VTSM_01 segment 0
- Creating M2V for VTSM_01 segment 1
- Creating M2V for VTSM_01 segment 2
- Extracting STILLS for VTSM_01 segment 3
- Extracting STILLS for VTSM_01 segment 4
- Extracting STILLS for VTSM_01 segment 5
- Extracting STILLS for VTSM_01 segment 6
- Extracting STILLS for VTSM_01 segment 7
- Extracting STILLS for VTSM_01 segment 8
- Extracting STILLS for VTSM_01 segment 9
- Extracting STILLS for VTSM_01 segment 10
- Extracting STILLS for VTSM_01 segment 11
- Extracting STILLS for VTSM_01 segment 12
- Creating M2V for VTSM_01 segment 13
- Extracting STILLS for VTSM_01 segment 14
- Extracting STILLS for VTSM_01 segment 15
- Creating M2V for VTSM_01 segment 16
- Extracting STILLS for VTSM_01 segment 17
- Extracting STILLS for VTSM_01 segment 18
- Extracting STILLS for VTSM_01 segment 19
- Extracting STILLS for VTSM_01 segment 20
- Creating M2V for VTSM_01 segment 21
- Creating M2V for VTSM_01 segment 22
- Creating M2V for VTSM_01 segment 23
- Extracting STILLS for VTSM_01 segment 24
- Extracting STILLS for VTSM_01 segment 25
- Extracting STILLS for VTSM_01 segment 26
- Extracting STILLS for VTSM_01 segment 27
- Extracting STILLS for VTSM_01 segment 28
- Extracting STILLS for VTSM_01 segment 29
- Extracting STILLS for VTSM_01 segment 30
- Extracting STILLS for VTSM_01 segment 31
- Extracting STILLS for VTSM_01 segment 32
- Extracting STILLS for VTSM_01 segment 33
- Extracting STILLS for VTSM_01 segment 34
- Extracting STILLS for VTSM_01 segment 35
- Extracting STILLS for VTSM_01 segment 36
- Extracting STILLS for VTSM_01 segment 37
- Extracting STILLS for VTSM_01 segment 38
- Extracting STILLS for VTSM_01 segment 39
- Extracting STILLS for VTS_01 segment 0
- Creating M2V for VTS_01 segment 1
- Creating M2V for VTS_01 segment 2
- Creating M2V for VTS_01 segment 3
- Creating M2V for VTS_01 segment 4
- Creating M2V for VTS_01 segment 5
- Creating M2V for VTS_01 segment 6
- Creating M2V for VTS_01 segment 7
- Creating M2V for VTS_01 segment 8
- Creating M2V for VTS_01 segment 9
- Creating M2V for VTS_01 segment 10
- Creating M2V for VTS_01 segment 11
- Creating M2V for VTS_01 segment 12
- Creating M2V for VTS_01 segment 13
- Creating M2V for VTS_01 segment 14
- Creating M2V for VTS_01 segment 15
- Creating M2V for VTS_01 segment 16
- Creating M2V for VTS_01 segment 17
- Creating M2V for VTS_01 segment 18
- Creating M2V for VTS_01 segment 19
- Creating M2V for VTS_01 segment 20
- Creating M2V for VTS_01 segment 21
- Creating M2V for VTS_01 segment 22
- Creating M2V for VTS_01 segment 23
- Creating M2V for VTS_01 segment 24
- Creating M2V for VTS_01 segment 25
- Creating M2V for VTS_01 segment 26
- Creating M2V for VTS_01 segment 27
- Creating M2V for VTS_01 segment 28
- Creating M2V for VTS_01 segment 29
- Creating M2V for VTS_01 segment 30
- Creating M2V for VTS_01 segment 31
- Creating M2V for VTS_01 segment 32
- Creating M2V for VTS_01 segment 33
- Creating M2V for VTS_01 segment 34
- Creating M2V for VTS_01 segment 35
- Creating M2V for VTS_01 segment 36
- Creating M2V for VTS_01 segment 37
- Creating M2V for VTS_01 segment 38
- Creating M2V for VTS_01 segment 39
- Creating M2V for VTS_01 segment 40
[18:25:26] Phase II ENCODING completed in 94 minutes.
[18:25:52] Phase III, REBUILD started.
- Copying IFO, BUP, and unaltered files...
- Processing VTS_01
- Reading/processing TMAP table...
- Rebuilding seg 0 VOBID 1 CELLID 1
- Updating NAVPACKS for VOBID_01
- Rebuilding seg 1 VOBID 2 CELLID 1
- Rebuilding seg 2 VOBID 2 CELLID 2
- Rebuilding seg 3 VOBID 2 CELLID 3
- Rebuilding seg 4 VOBID 2 CELLID 4
- Rebuilding seg 5 VOBID 2 CELLID 5
- Rebuilding seg 6 VOBID 2 CELLID 6
- Rebuilding seg 7 VOBID 2 CELLID 7
- Rebuilding seg 8 VOBID 2 CELLID 8
- Rebuilding seg 9 VOBID 2 CELLID 9
- Rebuilding seg 10 VOBID 2 CELLID 10
- Rebuilding seg 11 VOBID 2 CELLID 11
- Rebuilding seg 12 VOBID 2 CELLID 12
- Rebuilding seg 13 VOBID 2 CELLID 13
- Rebuilding seg 14 VOBID 2 CELLID 14
- Rebuilding seg 15 VOBID 2 CELLID 15
- Rebuilding seg 16 VOBID 2 CELLID 16
- Rebuilding seg 17 VOBID 2 CELLID 17
- Rebuilding seg 18 VOBID 2 CELLID 18
- Rebuilding seg 19 VOBID 2 CELLID 19
- Updating NAVPACKS for VOBID_02
- Rebuilding seg 20 VOBID 3 CELLID 1
- Rebuilding seg 21 VOBID 3 CELLID 2
- Rebuilding seg 22 VOBID 3 CELLID 3
- Rebuilding seg 23 VOBID 3 CELLID 4
- Rebuilding seg 24 VOBID 3 CELLID 5
- Rebuilding seg 25 VOBID 3 CELLID 6
- Rebuilding seg 26 VOBID 3 CELLID 7
- Rebuilding seg 27 VOBID 3 CELLID 6
- Rebuilding seg 28 VOBID 3 CELLID 7
- Rebuilding seg 29 VOBID 3 CELLID 8
- Rebuilding seg 30 VOBID 3 CELLID 9
- Rebuilding seg 31 VOBID 3 CELLID 10
- Rebuilding seg 32 VOBID 3 CELLID 11
- Rebuilding seg 33 VOBID 3 CELLID 12
- Rebuilding seg 34 VOBID 3 CELLID 13
- Rebuilding seg 35 VOBID 3 CELLID 14
- Rebuilding seg 36 VOBID 3 CELLID 15
- Rebuilding seg 37 VOBID 3 CELLID 16
- Rebuilding seg 38 VOBID 3 CELLID 17
- Rebuilding seg 39 VOBID 3 CELLID 18
- Rebuilding seg 40 VOBID 3 CELLID 19
- Updating NAVPACKS for VOBID_03
- Updated VTS_C_ADT.
- Updated VTS_VOBU_ADMAP.
- Updated IFO: VTS_01_0.IFO
- Updating TMAP table...
- Processing VTSM_01
- Rebuilding seg 1 VOBID 1 CELLID 2
- Rebuilding seg 2 VOBID 2 CELLID 1
- Rebuilding seg 3 VOBID 3 CELLID 1
- Rebuilding seg 4 VOBID 3 CELLID 2
- Rebuilding seg 5 VOBID 3 CELLID 3
- Rebuilding seg 6 VOBID 3 CELLID 4
- Rebuilding seg 7 VOBID 3 CELLID 5
- Rebuilding seg 8 VOBID 3 CELLID 6
- Rebuilding seg 9 VOBID 3 CELLID 7
- Rebuilding seg 10 VOBID 3 CELLID 8
- Rebuilding seg 11 VOBID 3 CELLID 9
- Rebuilding seg 12 VOBID 3 CELLID 10
- Rebuilding seg 13 VOBID 4 CELLID 1
- Updating NAVPACKS for VOBID_04
- Rebuilding seg 14 VOBID 5 CELLID 1
- Rebuilding seg 15 VOBID 5 CELLID 2
- Updating NAVPACKS for VOBID_05
- Rebuilding seg 16 VOBID 6 CELLID 1
- Updating NAVPACKS for VOBID_06
- Rebuilding seg 17 VOBID 7 CELLID 1
- Updating NAVPACKS for VOBID_07
- Rebuilding seg 18 VOBID 8 CELLID 1
- Rebuilding seg 19 VOBID 8 CELLID 2
- Rebuilding seg 20 VOBID 8 CELLID 3
- Updating NAVPACKS for VOBID_08
- Rebuilding seg 21 VOBID 9 CELLID 1
- Updating NAVPACKS for VOBID_09
- Rebuilding seg 22 VOBID 10 CELLID 1
- Rebuilding seg 23 VOBID 10 CELLID 2
- Updating NAVPACKS for VOBID_10
- Rebuilding seg 24 VOBID 11 CELLID 1
- Rebuilding seg 25 VOBID 11 CELLID 2
- Rebuilding seg 26 VOBID 11 CELLID 3
- Rebuilding seg 27 VOBID 11 CELLID 4
- Rebuilding seg 28 VOBID 11 CELLID 5
- Rebuilding seg 29 VOBID 11 CELLID 6
- Rebuilding seg 30 VOBID 11 CELLID 7
- Rebuilding seg 31 VOBID 11 CELLID 8
- Rebuilding seg 32 VOBID 11 CELLID 9
- Rebuilding seg 33 VOBID 11 CELLID 10
- Updating NAVPACKS for VOBID_11
- Rebuilding seg 34 VOBID 12 CELLID 1
- Rebuilding seg 35 VOBID 12 CELLID 2
- Updating NAVPACKS for VOBID_12
- Rebuilding seg 36 VOBID 13 CELLID 1
- Updating NAVPACKS for VOBID_13
- Rebuilding seg 37 VOBID 14 CELLID 1
- Rebuilding seg 38 VOBID 14 CELLID 2
- Rebuilding seg 39 VOBID 14 CELLID 3
- Updating NAVPACKS for VOBID_14
- Updated VTSM_C_ADT.
- Updated VTSM_VOBU_ADMAP.
- Correcting VTS Sectors...
[18:41:48] Phase III, REBUILD completed in 16 minutes.
Done.
Alles anzeigen
