Hi zusammen,
ich habe ein Problem beim Brennen von DVD DL von VErbatim.
Brenner ist ein externe LG HD-DL-ST GSA E60L.
Ich versuche immer ein Film für die PS3 zu brennen und somit im UDF 2.5 Modus
Brennprogramm ist einmel Nero 8.1.10 bzw. ImgBurn 2.4.2.0.
Die Filme haben das Format m2ts und besitzen die Größe von 6,5 GB bzw. 6 GB.
Hier mal der Log aus ImgBurn
I 18:15:59 ImgBurn Version 2.4.2.0 started!
I 18:15:59 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 18:15:59 Total Physical Memory: 1.046.636 KB - Available: 441.312 KB
I 18:15:59 Initialising SPTI...
I 18:15:59 Searching for SCSI / ATAPI devices...
I 18:15:59 Found 1 BD-ROM/HD DVD-ROM!
W 18:16:43 Device Arrival Detected!
I 18:16:43 Searching for SCSI / ATAPI devices...
I 18:16:44 Found 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
I 18:17:38 Operation Started!
I 18:17:38 Building Image Tree...
I 18:17:41 Calculating Totals...
I 18:17:41 Preparing Image...
I 18:17:41 Contents: 1 File, 0 Folders
I 18:17:41 Size: 6.192.039.936 bytes
I 18:17:41 Sectors: 3.023.457
I 18:17:41 Image Size: 6.192.791.552 bytes
I 18:17:41 Image Sectors: 3.023.824
I 18:17:44 Operation Successfully Completed! - Duration: 00:00:05
I 18:17:44 Operation Started!
I 18:17:44 Source File: -==/\/[BUILD IMAGE]\/\==-
I 18:17:44 Source File Sectors: 3.023.824 (MODE1/2048)
I 18:17:44 Source File Size: 6.192.791.552 bytes
I 18:17:44 Source File Volume Identifier: Tropisch
I 18:17:44 Source File Application Identifier: ImgBurn v2.4.2.0
I 18:17:44 Source File Implementation Identifier: ImgBurn
I 18:17:44 Source File File System(s): UDF (2.50)
I 18:17:44 Destination Device: [0:0:0] HL-DT-ST DVD-RAM GSA-E60L 1.00 (D:) (USB)
I 18:17:44 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00) (Speeds: 4x; 6x; 8x; 10x)
I 18:17:44 Destination Media Sectors: 4.173.824
I 18:17:44 Write Mode: DVD
I 18:17:44 Write Type: DAO
I 18:17:44 Write Speed: 2,4x
I 18:17:44 Link Size: Auto
I 18:17:44 Test Mode: No
I 18:17:44 OPC: No
I 18:17:44 BURN-Proof: Enabled
I 18:17:44 Book Type Setting: DVD-ROM
I 18:17:44 Optimal L0 Data Zone Capacity: 1.511.920
I 18:17:44 Optimal L0 Data Zone Method: ECC Block Boundary
I 18:18:13 Filling Buffer... (40 MB)
I 18:18:15 Writing LeadIn...
I 18:18:47 Writing Session 1 of 1... (1 Track, LBA: 0 - 3023823)
I 18:18:47 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3023823)
I 18:18:47 Writing Layer 0... (LBA: 0 - 1511919)
I 18:28:48 Writing Layer 1... (LBA: 1511920 - 3023823)
I 18:38:12 Synchronising Cache...
I 18:38:35 Closing Track...
I 18:39:11 Finalising Disc...
I 18:39:24 Exporting Graph Data...
I 18:39:24 Graph Data File: C:\Dokumente und Einstellungen\Christian\Anwendungsdaten\ImgBurn\Graph Data Files\HL-DT-ST_DVD-RAM_GSA-E60L_1.00_FREITAG-9-JANUAR-2009_18-17_MKM-003-00_2,4x.ibg
I 18:39:24 Export Successfully Completed!
I 18:39:24 Operation Successfully Completed! - Duration: 00:21:40
I 18:39:24 Average Write Rate: 5.195 KB/s (3.8x) - Maximum Write Rate: 5.566 KB/s (4.0x)
I 18:39:24 Cycling Tray before Verify...
W 18:39:35 Waiting for device to become ready...
I 18:39:56 Device Ready!
I 18:39:57 Operation Started!
I 18:39:57 Source Device: [0:0:0] HL-DT-ST DVD-RAM GSA-E60L 1.00 (D:) (USB)
I 18:39:57 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: MKM-003-00) (Speeds: 4x; 6x; 8x; 10x)
I 18:39:57 Image File: -==/\/[BUILD IMAGE]\/\==-
I 18:39:57 Image File Sectors: 3.023.824 (MODE1/2048)
I 18:39:57 Image File Size: 6.192.791.552 bytes
I 18:39:57 Image File Volume Identifier: Tropisch
I 18:39:57 Image File Application Identifier: ImgBurn v2.4.2.0
I 18:39:57 Image File Implementation Identifier: ImgBurn
I 18:39:57 Image File File System(s): UDF (2.50)
I 18:39:57 Read Speed (Data/Audio): MAX / MAX
I 18:39:57 Verifying Session 1 of 1... (1 Track, LBA: 0 - 3023823)
I 18:39:57 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 3023823)
I 18:39:57 Verifying Layer 0... (LBA: 0 - 1511919)
I 18:44:46 Verifying Layer 1... (LBA: 1511920 - 3023823)
W 18:45:30 Failed to Read Sector 1512016 - Reason: Unrecovered Read Error
W 18:45:30 Sector 1512016 maps to File: \Tropic.Thunder.2008.DirCut.720p.BluRay.German.AC3D.x264-MDR.m2ts
W 18:46:04 Failed to Read Sector 1512017 - Reason: Unrecovered Read Error
W 18:46:04 Sector 1512017 maps to File: \Tropic.Thunder.2008.DirCut.720p.BluRay.German.AC3D.x264-MDR.m2ts
W 18:46:13 Failed to Read Sector 1512018 - Reason: Unrecovered Read Error
W 18:46:13 Sector 1512018 maps to File: \Tropic.Thunder.2008.DirCut.720p.BluRay.German.AC3D.x264-MDR.m2ts
W 18:46:20 Failed to Read Sector 1512019 - Reason: Unrecovered Read Error
W 18:46:20 Sector 1512019 maps to File: \Tropic.Thunder.2008.DirCut.720p.BluRay.German.AC3D.x264-MDR.m2ts
W 18:46:31 Failed to Read Sector 1512020 - Reason: Unrecovered Read Error
W 18:46:31 Sector 1512020 maps to File: \Tropic.Thunder.2008.DirCut.720p.BluRay.German.AC3D.x264-MDR.m2ts
W 18:47:34 Failed to Read Sector 1512021 - Reason: Unrecovered Read Error
W 18:47:34 Sector 1512021 maps to File: \Tropic.Thunder.2008.DirCut.720p.BluRay.German.AC3D.x264-MDR.m2ts
E 18:48:06 Failed to Read Sector 1512022 - Reason: Unrecovered Read Error
E 18:48:06 Sector 1512022 maps to File: \Tropic.Thunder.2008.DirCut.720p.BluRay.German.AC3D.x264-MDR.m2ts
E 18:48:06 Failed to Verify Sectors!
I 18:48:06 Exporting Graph Data...
I 18:48:06 Graph Data File: C:\Dokumente und Einstellungen\Christian\Anwendungsdaten\ImgBurn\Graph Data Files\HL-DT-ST_DVD-RAM_GSA-E60L_1.00_FREITAG-9-JANUAR-2009_18-17_MKM-003-00_2,4x.ibg
I 18:48:06 Export Successfully Completed!
E 18:48:06 Operation Failed! - Duration: 00:08:08
I 18:48:06 Average Verify Rate: 6.196 KB/s (4.5x) - Maximum Verify Rate: 21.202 KB/s (15.3x)
Display More
Die Brenngeschwindigkeit betrug nur 4fach bzw. 2,4fach.
Könnt ihr mir weiterhelfen?
Danke
