Schon gesehen, dass diese "Version 0.9" (582 KB) kleiner ist als die Version 0.10 (586 KB), und deutlich kleiner als Version 0.86.1 (5.2 MB)? Ist dann wohl doch eher eine "Version 0.09"...
Die darin enthaltene AX-Datei stammt auch von Mai 2009.
Im doom9-Forum gibt es zumindest was zur im Moment wirklich aktuellen Version 0.86.1:
madVR v0.86.1
* added smooth motion frame rate conversion algorithm
* added settings page for smooth motion frc configuration
* added "trade quality for performance" option for smooth motion frc
* added test patterns to madTestPatternSource to test smooth motion frc
* fixed: RGB input with odd width/height is now accepted untouched
* fixed: IVideoWindow::put_Owner() failed when pins were not connected yet
* fixed: madHcCtrl.exe autostart registry entry was incorrect / not working
* fixed: occasional crash when using DXVA scaling with high-bitdepth content
* fixed: green line at the left image border when using DXVA scaling
* file "settings.bin" is not written into win7/8 "VirtualStore", anymore
* slightly improved multi monitor behaviour (when using DXVA or MPC-BE)
* improved exclusive mode presentation timing with jittery audio clock a bit
* filter enumeration timer is now only active during DVD playback
* extended logging for fullscreen exclusive presentation queue
* internal software video decoders are now disabled by default (again)
Alles anzeigen
