madVR - high quality video renderer (GPU assisted)
  • http://madshi.net/madVR.zip
    madVR v0.12
    * rewrite of about 75% of the code
    * loads of bug fixes
    * improvements for DVD playback (macrovision complaints etc)
    * improvements for frame stepping during paused playback
    * re-added rendering stats to OSD
    features:
    - high quality chroma upsampling
    - high quality scaling (bicubic, mitchell, lanczos, spline etc)
    - high quality YCbCr -> RGB conversion
    - gamut & gamma correction for display calibration
    - full 16bit processing queue
    - final 16bit processing result is dithered down to RGB output bitdepth
    - bypasses graphics card's video (damage) algorithms
    - all work is done via GPU shaders
    - no shortcuts, highest quality has priority over anything else
    requirements:
    - graphics card with full Direct3D9 hardware support
    - at least 128MB of dedicated graphics card memory
    - Windows XP or newer
    disadvantages:
    - hardware accelerated video decoding (DXVA) is currently not supported
    - slightly slower startup when using 3dlut technology (96MB file must be read)[/QUOTE]
  • Who is General Failure and why is he reading my hard drive?
    madVR v0.12
  • madVR 0.13 released
    Einmal editiert, zuletzt von Tom Keller (21. März 2011 um 06:38)
    3 Mal editiert, zuletzt von Tom Keller (14. April 2011 um 20:37)
    2 Mal editiert, zuletzt von Tom Keller (20. April 2011 um 01:49)
    Einmal editiert, zuletzt von Tom Keller (28. April 2011 um 19:29)
    Einmal editiert, zuletzt von Tom Keller (8. Juni 2011 um 04:37)
    Einmal editiert, zuletzt von Tom Keller (25. Juli 2011 um 01:48)
  • OPERATIVE HEKTIK,ERSETZT GEISTIGE WINDSTILLE
    Einmal editiert, zuletzt von Scratty (26. Juli 2011 um 08:57)
    3 Mal editiert, zuletzt von Tom Keller (22. August 2011 um 20:29)
