SurCode DTS encode button
    ich wollte mit Eac3to und als DTS Encoder: Surcode DTS Encoder eine DTS zu DTS wandeln in einer etwas niedriger rate und zu PAL.
    Nachdem demuxen der einzelnen kanäle, kam dies:
    eac3to v3.16
    command line: eac3to.exe "G:\Bearbeiten\track_4.dts" "G:\Bearbeiten\AudioFile_83.dts" -speedup -768 -29800ms
    DTS, 5.1 channels, 1:16:40, 24 bits, 1509kbps, 48khz
    The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
    Decoding with libav/ffmpeg...
    Remapping channels...
    Applying RAW/PCM delay...
    Changing FPS from 23.976 to 25.000...
    Reducing depth from 64 to 32 bits...
    Writing WAVs...
    Creating file "G:\Bearbeiten\to mux\AudioFile_83.SL.wav"...
    Creating file "G:\Bearbeiten\to mux\AudioFile_83.R.wav"...
    Creating file "G:\Bearbeiten\to mux\AudioFile_83.LFE.wav"...
    Creating file "G:\Bearbeiten\to mux\AudioFile_83.SR.wav"...
    Creating file "G:\Bearbeiten\to mux\AudioFile_83.L.wav"...
    Creating file "G:\Bearbeiten\to mux\AudioFile_83.C.wav"...
    Encoding DTS <768kbps> with Surcode...
    Found Surcode DTS Encoder version 1.0.29.0.
    Surcode says/asks: "At least one valid source file must be specified to encode.".
    Pressing the Surcode "Encode" button didn't seem to work...
    Closing Surcode...
