FFMS2 - FFmpegSource für Avisynth
  • FFmpegSource v2.13 ist da:
    Changelog:
    • Fixed a bug where the Avisynth plugin would drop the last frame when converting to CFR (lanwcp)
    • The Avisynth plugin will now attempt to detect and use NTSC fractional framerates for CFR files if applicable, instead of reporting something based on the average framerate (astrange, TheFluff)
    • The errorhandling parameter to FFIndex() will now actually do what the documentation claims it does (TheFluff)
    • Fixed a progress reporting crash when opening images (TheFluff)
    • Replaced the CMake build system with an autotools one that hopefully works better (Kovensky)
    • Fixed various compilation issues with MinGW (TheFluff)
    • Fixed h264 in mkv which was remuxed from bd sources, there are no longer decoding artifacts after seeking
    • Use pts instead of dts for seeking with lavf, fixes various timecode problems on mp4 files with certain obscure delay headers
    • Now compresses the index files with zlib to save space
    • Removed the boost dependency
    • Fixed the framerate calculation for AVC video in the RFF modes
    • Improved/fixed the NVOP detection in MPEG4 and how timestamps are calculated (lanwcp, Myrsloik)
    • Fixed an issue where the first 15 audio frames would never be redecoded if needed again
    • Fixed/added support for uncompressed video and audio formats in matroska, fixes Blank.Clip.720p.x264-darkhold.mkv (Emess)
    • The indexer and test is now statically linked so no extra runtimes are needed
    • FFmpeg is now compiled with runtime cpu detection, allows opterons and old cpus to work properly
    • Updated FFmpeg to rev 21782
    Download: http://ffmpegsource.googlecode.com/files/ffms2-2.13.7z
    Source code: http://ffmpegsource.googlecode.com/files/ffms2-2.13_src.7z
