mist,.. ist es nicht,.. werde ich fixen
Hybrid 2011.05.19.2
*fixed*
- x264: broke 1pass modes when I added 2pass crf againCu Selur
Ps.: stelle fest, das Kompilieren aller Versionen dauert schon ne ganze Weile,..
Vielen Dank, jetzt gehts, aber es kommt eine Fehlermeldung, egal welche Datei ich lade
Hybrid: http://www.selur.de
Forum: http://forum.selur.de
analysing: D:\_record\_coden\_HD\PLANET_ERDE_D3-2.m2ts
grabbing audio ids ...
found audio ids: 4353 ### 4352
analysing audio streams...
analysing audio stream (4353) with tsMuxerR
analysing audio stream (4352) with tsMuxerR
grabbing video ids for: D:\_record\_coden\_HD\PLANET_ERDE_D3-2.m2ts
-> video ids found: 4113
analysing video streams...
Wrong encoding type constant rate factor (1-pass)
Analysing finished.LG
wurli -
AARGGGHhh,.. ich guck drauf
Sorry. -
Macht nüscht, alles halb so wild...;)
Hybrid 2011.05.19.3
*fixed*
so ist, jetzt hoffentlich auch gefixed,.. bin auf jeden Fall jetzt erst mal Schlafen.
Guten Morgen,
lüppt wieder, vielen Dank!!!:cheers: -
Hybrid rev 2011.06.18.1:
*changed*
- added warning when output path equals program folder
- allow vc-1 in m2ts container
- extract videostream from blu-ray before reencoding (add additional overhead, but fixes synch problems when mpls spans over multiple files)
*added*- using mp4fpsmod to extract mp4 timecodes (http://sites.google.com/site/qaacpage/junk)
*fixed*- a bunch of problems related to separate 2pass 1st and 2pass 2nd pass encoding
- autocorp: handling of raw h.264
- error popup when adjusting preset an bluray restrictions enabled,..
- problem with .mpls and autocrop
- missing color space conversion when changing frame rate and not doing any other filtering
- problem when extracting/importing chapters from non-dvd sources
- filtermodel not completely ignored when using passthrough
- fps of input ignored if video handling was set to 'passthrough' on input load and then changed to something else before adding a job
- adding -tmp TempPath to MP4Box muxing call to make sure that the right temp folder is used
- .dts-hd/.dtshd not detected as raw audio
- blu-ray synch problem
*updated*- windows packages/installer
- hobarrera started a archlinux package
Hybrid rev 2011.06.20.1:
*cosmetics*
- changed progress indication in title/taskbar
- Win7 32bit: progress in taskbar - accidentally build I didn't build the last Win32Bit build with Windows XP, not Windows 7
*fixed*- video passthrough bug
- x264: 2pass 1st pass calls not generated
Hybrid rev 2011.06.22.1:
*cosmetics*
- reworked the internal message system
*fixed*- when extraction Audio with tsMuxeR audio was moved to Hybrid home on rename
- cuda: force AVC Level 'auto' for 'cq'-encoding mode
Hybrid rev 2011.06.23.1:
*cosmetics*
- x264 encoding progress indication
*fixed*- video profiles import (bitrate adjustment)
Hybrid rev 2011.06.26.1:
*fixed*
- don't create output file in the 1st pass of a two pass encoding
- missing chapter DataNodes on some input files without chapters
Hybrid rev 2011.06.29.1:
*fixed*
- crash when importing .mkvs with multiple chapter sets (now the last one will be imported)
- subtitle handling for multiInput
- multiple stream source srt->ttxt
Hybrid rev 2011.06.29.2:
*fixed*
- problem when tsMuxeR output
Hybrid rev 2011.06.30.1:
*fixed*
- crash when extracting subtitle from DVD source
Hybrid rev 2011.07.01.1:
*fixed*
- problems crash when extracting subtitle from dvd/blu-ray source
woran könnte es liegen, dass ich kein Audio Reiter mehr habe?
Vor 1h hatte ich den noch bei einer alten Version. Dann hatte ich die neuste Version mit dem Installer Installiert.
Kein Audio mehr. Auch bei der alten Version kein Audio mehr.
NeroAACCodec hab ich.Komisch...
Der Audioreiter sollte nur dann nicht angezeigt werden, wenn:
a. Audio handling -> ignore
b. Audio handling -> passthrough all
-> vermutlich hilft es wenn Du das MainTabModel resettest,...Cu Selur
Stand auf Ignore. Peinlich...
DANKE! -
wie schaffe ich es, dass er bei jedem Start mein globales Profil lädt?
Also alle meine Einstellungen? -
Globale Profile sind wie die anderen Profile auch, sie beinhalten die Infos des Bereiches für den sie zuständig sind (globale für alles), werden aber nicht automatisch geladen.
Beim Start werden die Defaults geladen, keine Profile. -> wenn Du all deine Einstellungen speichern willst, dann speicher sie als Defaults.
Moin Moin,
ich habe wieder mein "too small" Problem. Nach einer Weile kommt dann die Fehlermeldung "too small". Ich habe mir wie damals die aktuelle mencoder.exe geladen, hilft aber auch nichts. Was kann das sein? Ich nutze die aktuelle 64 bit Version von https://gleitz.info/www.selur.de + aktuelle x264 Datei von x264.nl.
