  • 2024.06.09.1:
    *aded*
    • Vapoursynth: torch, ProPainter
    *changed*
    • Vapoursynth: torch, adjusted to DeOldify 0.3.5.3
    • Filtering: remove 'none' as auto deinterlacer handling option
    • Video: NVEnc support --tflevel --lookahead-level
    *fixed*
    • Vapoursynth: another EEDI3/EEDI3CL handling
    • Vapoursynth: Masking for RGBH filters
    • QSVEnc: remove '--tier' during hevc encoding
    • QSVEnc: set '--output-csp' (this is broken for most choices)
    • Jobs: QSVEnc av1 encoding in webm
    • Vapoursynth: torch, DeOldify fix FP16
    • Vapoursynth: TFM/VFM, fps refresh
    • Avisynth: custom with dual view
    • Avisynth: interlaced output + cropView
    • x265: 3.0 and 4.0 vbv values not set
  • 2024.06.15.1:
    *added*
    • Vapoursynth: support CPreview from hello_hello
    *changed*
    • Vapoursynth: torch, adjust to DeOldify 4.0.0
    • Vapoursynth: torch, adjust to vsRealESRGAN 5.0.0
    • Vapoursynth: reworked FillDuplicateFrames, FillDrops, ReplaceSingle into one class for stability
    • Vapoursynth: vs-mlrt, RIFE scale support optional requires 'onnx' in Vapoursynth/Lib/site-packages, see: https://github.com/AmusementClub/vs-mlrt/issues/94
    *fixed*
    • Vapoursynth: do not change color matrix on RGB content
    • Vapoursynth: fixed some unnecessary, popups during startup
    Ps.: deinstall old version before installing this one.
